How in HELL do you take this bolt out
Old Jul 2, 2005 | 09:42 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I'm changing the springs in the rear of my 01 and the bolt wont come out. It seems that is all stripped and no way to take it out. Help before I put everything back together and sell the springs with the Illuminas..... Pic ina minute. The bolt and the lock moves att he same time and it has metal pieces in th emiddle so I cannot use pliers to hold the bolt in place.
Old Jul 2, 2005 | 09:46 AM
ttumaxima's Avatar
if it's stripped, then you need to buy the sockets that are made specially to remove stripped nuts and bolts.
i have the craftsman set, i bought it at sears awhile back.
nismology's Avatar
Stick a flathead screw driver in between the nut on the other side and the bracket thing. That will keep the nut from turning. It's better if one person does that, while the other actually tries to break if free. Also, PB blaster is your friend.
ddpack's Avatar
Are the bolt threads stripped or is the head of the bolt stripped? If the bolt threads are stripped, I would suggest cutting it off with a sawzall. If the Head of the bolt is rounded off, you can get a pair of vice grips and find a pipe big enough to go around the handles of the vice grips and take it out that way. I did my 03's and had to put a 20" breaker bar w/ a pipe to get mine out. Good luck
Old Jul 2, 2005 | 09:54 AM
Lontar1's Avatar
the threads are ok.. the problem is that the lock moves with the bolt.. I'll try the screwdriver, if it doesn't work.. I just leave the drop in the front...
Old Jul 2, 2005 | 10:42 AM
kpr10is's Avatar
Air tools took it right out Studman had a very similar problem when installing mine.
Old Jul 2, 2005 | 11:45 AM
Lontar1's Avatar
Yes but I don't have air tools, so it will stay like it is until I find someone that can take them out.... Kevin do you have access to air tools?
Old Jul 2, 2005 | 12:00 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
those have to be the most hardest bolts to take out anywhere on the car.. air tools is a most definitely needed item..
I will not even attempt to take off any suspention part without them.. try and get some LONTAR or you will have a heck of a time trying to take it off...
Old Jul 2, 2005 | 12:48 PM
Lontar1's Avatar
I put everything back together.... I gave up..... I wil talk to a friend from the office and see if he has air tools....if not I will have to take it to Walmanrt or sopmeplace so they can loose them up...
Old Jul 2, 2005 | 01:15 PM
nismology's Avatar
It can be done without air tools. You all give up too easily...
Old Jul 2, 2005 | 02:01 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Of course it can, most would just rather not.
Old Jul 2, 2005 | 02:09 PM
kpr10is's Avatar
Nope, I just know people who do. Not many maxima people though, and not in orlando.
Old Jul 2, 2005 | 02:29 PM
Lontar1's Avatar
well if anyone in Orlando or in Florida.. I'll drive don't really care, can help me loose the FU%&$ing bolts. I really want to finish the drop
Luis
Old Jul 2, 2005 | 04:31 PM
maxgangsta02's Avatar
that bolt is a PITA. on the drivers side on my 02, i had an electric impact gun and it worked..the pass side it was so tight. i ended up using like a 3' breaker bar to bust it loose. it sucks..we all been there done that
Luis
Old Jul 2, 2005 | 04:56 PM
Lontar1's Avatar
where can I get an electric impact gun? Can i rent one?
Old Jul 2, 2005 | 05:48 PM
i borrowed my buds...try a tool rental place
Old Jul 2, 2005 | 07:00 PM
upstatemax's Avatar
I take mine out quite frequently to adjust my D2's????
They come out really easy for me. I just use a torque wrench to break them free and a 1/2" drive to finish taking them out. usually once it is free from the nut you can pull up on the rear brake and slide it out.
Old Jul 2, 2005 | 07:02 PM
upstatemax's Avatar
Luis
If you want to drive to Upstate New York I will happily remove them for you....
Old Jul 2, 2005 | 07:15 PM
Lontar1's Avatar
Ahh let me see... thanks but it is too far from me.. don't you think
Old Jul 2, 2005 | 07:46 PM
Tek-Niq's Avatar
yea this could be the cheapest way LONTAR, I also have a torque wrench to do stuff with.. I would get one with a long handle so you have more leverage and be able to unscrew it easier..
Old Jul 2, 2005 | 08:35 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Using a torque wrench in place of a breaker-bar is not the best idea, unless you like buying torque wrenches all the time. Torque wrenches are precision tools, not meant to be used as a leverage tool.
Old Jul 3, 2005 | 12:15 PM
upstatemax's Avatar
It has a lifetime warranty on it... if it breaks, I just get a new one for free...
Old Jul 3, 2005 | 12:34 PM
njmodi's Avatar
Do I get a tax break?
Are you sure it's a lifetime warranty? Craftsman torque wrenches, for example, are not lifetime warranty like most of their other handtools. They only have a 1yr warranty. I know this because I just bought a TQ wrench a few weeks ago.
Old Jul 3, 2005 | 12:37 PM
Lontar1's Avatar
But guys the problem I have is the lock turning inside the metal falnges or whatever you guys called them. The bolt spins and the lock to. So I know a Torque wrench won't work , I need something that will keep the lock form turning...
Old Jul 3, 2005 | 12:50 PM
upstatemax's Avatar
your should be like mine... I would hope so.
Just find something to jam inbetween the nut and the metal the surrounds it so it cannot spin. just see if ou can stick an old screw driver in there.
Old Jul 3, 2005 | 12:57 PM
nismology's Avatar
Some people don't read. Sheesh...
Old Jul 3, 2005 | 12:58 PM
Lontar1's Avatar
I think I'm going to have to remove the caliper and everything in betwen so I can reach that bolt. I wil be doing this soon.. one last try.
I did and it still spins... I gave up and wil see what else can I think.. I tried pliers, screwdrivers, even a bolt, and nothing the lock still spins..... so the full drop will not be finish.......
Old Jul 3, 2005 | 02:13 PM
JdoubleOe703's Avatar
teddibear703
yo nismology.. you get any of my messages? just wondering whats up? call me...
Old Jul 3, 2005 | 03:21 PM
X-Vert's Avatar
aww man, that sucks... I hate when ppl give up
Old Jul 3, 2005 | 03:57 PM
ColdSHO's Avatar
i just took mine to my local muffler shop, $25 bucks and it was out, i even stripped it a lil, i did my whole suspension with the stock jack and a handful of random wrenchs, that bolt on the pass side was the only problem i had.
Old Jul 3, 2005 | 04:40 PM
ZIPPIN's Avatar
Mauja He Mauja
i took it off with a breaker bar
Old Jul 3, 2005 | 05:14 PM
Lontar1's Avatar
good idea... I'll do that instead of killing myself.... I'll go to Midas or some shop to loosen the bolt......
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
