Brake line damage from rsb?
Old Jul 4, 2005 | 10:14 PM
Shogunsc4's Avatar
Anyone has brake line damage or malfunctioning from their RSB pressing against it in the rear? My mechanics told me it is rubbing and pressing against the line but it is nothing serious. Should I get a set of goodridge SS lines? Is it a noticable improvement over stock in performance? Thanks in advance.
Old Jul 5, 2005 | 01:25 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
if it's damage replace them for your safety, and remove the bolt and put it in the other way. I'm assuming you have the Stillen one.....
Old Jul 5, 2005 | 07:46 PM
Maximax2's Avatar
To make sure this didn't happen, I bought some poly tubing from home depot, cut it to size then slit it open. It wraps nicely around the brake line, and has stopped all wear.
This is for a Cattmann RSB.
Old Jul 5, 2005 | 08:45 PM
SEmy2K2go's Avatar
Go BUCKS!!!
No rubbing from my Progress/Cattman RSB in over 1.5 yrs.
Old Jul 5, 2005 | 09:01 PM
ICULookN's Avatar
I bought some 1/4 inch clear vinyl tubing from Lowe's and wrapped it around my brake lines in the rear and the stainless steel brake lines in the front to prevent rubbing. I heard about this problem before so I was little proactive from the get go.
Old Jul 5, 2005 | 09:18 PM
Shogunsc4's Avatar
there was no damage with the brakelines as we checked today but the brakelines were pourly relocated causing inner rear brake pads to be slightly engaged and were slightly rubbing against the disc causing my pads to disappear every 10-15k miles.
Old Jul 5, 2005 | 09:28 PM
E55AMG2's Avatar
Wat
Ive had an RSB since new...and the lines should be zip tied out of the way
Old Jul 5, 2005 | 09:30 PM
Talyan03's Avatar
yap i done the same
Old Jul 5, 2005 | 10:06 PM
Shogunsc4's Avatar
cool...i'll try that but will zip ties melt?
Old Jul 5, 2005 | 10:08 PM
E55AMG2's Avatar
Wat
no......no they do not
Old Jul 5, 2005 | 11:13 PM
crispykid717's Avatar
Bigger than Jesus
Just reverse the brackets so the longer screw is facing the opposite way. Then problem solved.
Old Jul 5, 2005 | 11:26 PM
joebangaa's Avatar
mine touch the stillen brackets but theres no pressure whatsoever. i constantly inspect my brakes and i've had the rsb forever w/o probs
Old Jul 5, 2005 | 11:43 PM
Larrio's Avatar
The Definitive AE Master
are you talking about the brake line or the abs line. For the stillen rsb, the abs sits inside the grooves of the rsb brackets against the trailing arms and the brake line is behind the trailing arm and should not have any problems if you reverse the one bolt so that the head and not the threaded side comes into contact with it
Old Jul 6, 2005 | 04:33 AM
MaxSE03's Avatar
Or....you can just install a little rubber gromet and your good too.
Old Jul 6, 2005 | 04:48 AM
ICULookN's Avatar
I was talking about the abs line, my mistake.
Old Jul 6, 2005 | 10:12 AM
joebangaa's Avatar
yep, my abs line is tucked inside the bracket
BkGreen97
Apr 2, 2016 05:47 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Johnny9595
Sep 16, 2015 07:20 PM
