Auto Climate Not Regulating
Old Jul 6, 2005 | 03:30 PM
Maxima2000SE's Avatar
I searched on google but I don't know how exactly someone posted it before so I couldnt find it. The air coming out of my vents is either at 65 or 85 and never anything in between. When I turn the dial from 65 to 75 the temp coming out doesn't change...the fan speed turns down and the air switches to face and floor. how do i fix this problem...is it a sensor? I know this has been brought up before....but any help or links to fix the problem would be greatly appreciated.
Old Jul 7, 2005 | 10:42 PM
jeremykedel's Avatar
Mine wasnt working right either. I cleaned the sensor and started working great, it was dusty , I used alcohol and a qtip. Worked perfect since.
Old Jul 8, 2005 | 02:44 AM
MIXXMAX's Avatar
There's a sensor on the bottom right hand corner of the gauge cluster trim. There should be a grille like thing on the trim. It sits behind there. I believe it's the temperature sensor which regulates the amount of air flow and adjusts to the inside temperature of the car. Try cleaning it off. It's prone to get real dusty after a while.
Old Jul 8, 2005 | 06:37 AM
Ammi's Avatar
350 Detroit Muscle
I'll have to try that
Old Jul 8, 2005 | 07:22 PM
i used compressed air to blast out any dust in there and a lot of dust shot out of there...but it still isn't adjusting the temperature properly...would it be okay to spray a little electrical component cleaner in there?
Old Jul 10, 2005 | 07:52 AM
Yeah electrical cleaner should be fine to spray in there. I used rubbing acohol, it turned a completely different color, the sensor is actually like a copper color that is what it should look like.
Old Jul 10, 2005 | 09:07 AM
wngan9447's Avatar
Chicken Feet Croo!
I wish this was in the stickies... nice write-up by Dr.Roy about testing the sensors that make the auto climate work..
http://forums.maxima.org/showthread....ighlight=a%2Fc
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
gavin68
Sep 18, 2021 12:36 PM
BobTX10
Oct 7, 2015 08:43 AM
