e-brake "brake light"
Old Jul 11, 2005 | 04:19 AM
ikalinin's Avatar
yesterday my "brake" light started to turn on.. and blink, and on and off again, with every light touch to the ebrake, the light blinked.. you need to hold the brake down w/ some force for the light to stay off... but it blinks with every drive i make. Brake fluid level is at max, and i don't know if there is anything i can do to fix this easlily and quickly.
any ideas?
Old Jul 11, 2005 | 06:15 AM
Maxrider24/7's Avatar
It could be the contact switch for the ebrake, i don't know what else it can be good luck
Old Jul 18, 2005 | 10:25 AM
ikalinin's Avatar
it went away, and today again.. lit up!
any idea?
Old Jul 18, 2005 | 01:56 PM
GBAUER's Avatar
Your brake fluid is low. The light has two duties: e-brake and low fluid.
Old Jul 18, 2005 | 05:19 PM
JustinMKN's Avatar
Yup get more fluid
Yea fill the fluid up, I had the same problem over the winter and just added some fuild and never had problems since.
Old Jul 19, 2005 | 06:39 AM
ikalinin's Avatar
checked level.. brake fluid at max!
Old Jul 19, 2005 | 06:49 AM
AcerX's Avatar
Since I'm fairly certain that a Cel code would be thrown in place of a rotor problem, the light should only come on in the case of a bad e-brake sensor or if the e-brake is engaged (knock on wood). But since you can tell if you're e-brake is up or not I wouldn't worry about it. Just remember to check the brake fluid level every now and then. And check other fluids while you're at it.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
