Rim Question...19's
Old Jul 14, 2005 | 08:11 AM
NJDevil210's Avatar
Rim Question...19's
hey guys...im not getting to many hits in the tires and wheels forum so i was wondering if you guys could help me out...im planning on ordering 19" Axis Hiro's for my car pretty soon but i dont really know much about wheels...im not going for a staggered setup i am just going to get 4 19x8.5...these will fit fine right? i was thinking about going with a 235/35/19 tire..but i dont want to have any rubbing...also if you guys have any opinions on tires to fit these i would appreciate any info...im planning on lowering the car on progress and illuminas soon too so i hope that wont be a big problem...sorry for all the questions just trying to find out some info before i drop some big money...thanks aloy guys
doug
Old Jul 14, 2005 | 08:15 AM
joebangaa's Avatar
245/35/19 works too, and obviously that's wider
Maxrider24/7's Avatar
Well personally i have 19" wheels on my car.....but i went with a P225/40R19 cuz i wanted the extra sidewall cuz the roads suck but, i have no rubbing and its dropped with eibach and tocikos good luck.....
Old Jul 14, 2005 | 08:21 AM
ICULookN's Avatar
What does the first and second numbers mean? I know what the last number means.
Old Jul 14, 2005 | 08:26 AM
joebangaa's Avatar
first is the width of the tire in MM. the second is the profile, which is derived from the width of the tire (first number). The profile (2nd number) is a percentage of the width. HOWEVER, for some reason, on multiple occasions, I've seen tires of the same size with different sidewall sizes, AND i've seen a 215/50/17 look taller than 225/50/17 (our stock size). so i guess the type of tire and manufacturing has to do with that too, but in general those numbers are standard.
Old Jul 14, 2005 | 08:27 AM
The first number is the width of the tire in (mm) and the second number is the height of the sidewall in (mm) which is also a percentage of the width......
Old Jul 14, 2005 | 08:28 AM
Yeah that is true i wonder why that is????????
Old Jul 14, 2005 | 08:37 AM
joebangaa's Avatar
height of sidewall is not given in MM. believe me, i've seen 25 series tires fatter than my 50 series...
Old Jul 14, 2005 | 08:45 AM
SEmy2K2go's Avatar
Go BUCKS!!!
For 19x8 and 19x8.5 wheels, most guys are running 245/35/19 (including myself).
Old Jul 14, 2005 | 08:47 AM
ICULookN's Avatar
Thanks for the advice guys but I have another question. I'm buying 20x8.5 rims with a 35 offset, tirerack recommends a 245/30/20 tire which I think is a problem. I was thinking about buying the tires off the 300 SRT8 which has Goodyear F1's that are 245/45/20 in the front and 255/45/20 in the rears. I want the thickest(height) tread possible to avoid the bent rim syndrome, if I get these tires will I rub the wheels?
Old Jul 14, 2005 | 08:50 AM
NJDevil210's Avatar
so SEmy if i put on a 245/35/19 tire and drop it with the progress springs i shouldnt have any problems?
doug
Old Jul 14, 2005 | 08:52 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I've been running that tire size and my car lowered on Maxspeeds for over 1.5 yrs and it hasn't rubbed one time. I'm now on Tokico Blues w/Maxspeeds and it hasn't rubbed since installed.
Old Jul 14, 2005 | 08:53 AM
BLKMAX005SPD's Avatar
The 19's will fit fine on your car...a ton of ppl on here have 19's. I would go with tein s-tech springs...makes the car looks like its sitting right... i think i had 245 35 19's on the front...can't quite remember
Old Jul 14, 2005 | 08:59 AM
NJDevil210's Avatar
good deal...thanks for the help guys...will i have to worry about like offsets or anything ( which i know nothing about ) and any recommendations on tires you might be running?
doug
Old Jul 14, 2005 | 09:31 AM
ICULookN's Avatar
Any advice?
Old Jul 14, 2005 | 09:44 AM
Woo Cho's Avatar
I was riding on 19' Axis Crux with 245x35x19 with Tein S tech it doesn't rub unless I cut the wheels all the way, not many pple will know that cuz u can't see the inside of ur fender but when I took the wheels out to get my brakes done u could def tell that it rubbs......other than that 19's like the best way to go.....also u gotta be extra careful on driving if u don't want ur wheels end up like this from running over curb......I had to choose to run over curb or my other option was to hit the Bus......
sorry fo the terrible pix......hope this will help u becareful driving after u get the wheels......but nice choice on the wheel......dang......sorry again for long a$$ post.
Old Jul 14, 2005 | 10:46 AM
xtantmaxima's Avatar
Any advice?
no chance. Those cars can fit 22's. Our cars can fit 20's. Some might say that doesn't matter but it does. The overall diameter of the Daimler-Chrysler RWD platform is about 3" larger than the pre 6th Gen Maxima.
[edit]
not, NO chance. With some modification, it could work, but not stock/no rubbing.
[/edit]
Old Jul 14, 2005 | 11:03 AM
ICULookN's Avatar
Originally Posted by xtantmaxima
no chance. Those cars can fit 22's. Our cars can fit 20's. Some might say that doesn't matter but it does. The overall diameter of the Daimler-Chrysler RWD platform is about 1.5" larger than the pre 6th Gen Maxima.
[edit]
[/edit]
I'm sitting on GR2's/maxspeeds. I plan to get 15mm spacers as well.
Old Jul 14, 2005 | 12:18 PM
I'm only talking about the tires. You will not be able to use the 255/45-20 inch tire. If you get the 245/30-20 You'd be alright and 245/35-20 and you might rub under heavy loads.
Old Jul 26, 2005 | 02:31 PM
Icondapython's Avatar
Hey guys, i just bought a 2001 Maxima SE a week ago, and my friend told me about this site/forum. Its really cool, anyways, by reading all your posts 19's are perfect for the max?? I was thinkin about getting 20's but i guess they will rub... if i am wrong anywhere please correct me, thanks. One more thing, i was lookin around the forums and the only Lip kits i have seen are like the Stillen one and one more, are there any more lip kits for the 5th generation max. Thanks again guys.
Old Jul 26, 2005 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
STFU Post in the appropriate forum .. and 20s wont rub if you use the correct size tire
There are more lip kits, but why don't you put a Y-pipe first. ..
BIGBZ's Avatar
245/45 are just a little too tall, they will most likely rub when turning, i have 245/35, and they fit perfect, my car isn't lowered though, also i am running a 20x9 wheel, but that probably doesn't make a diffence.
Old Jul 26, 2005 | 03:35 PM
Thanks for the worm welcome , next time try harder so you can impress me.... Just cuz you've been on this forum since 2000 or w/e that dont mean you cant act that way. I do have respect for you cuz you know better than me but why be like that? Anyways, i aint here to argue, thanks for the advice on the Y-pipe tho. and one more thing, how bout a side wall 35 for a 20' rim? would that be alright?
Old Jul 26, 2005 | 03:40 PM
NmexMAX's Avatar
dot dot dot ...
Depends on the tire width .. Visit the wheel/tire forum, there's some useful information in there, or www.tirerack.com, and read the section "Tire Tech" .. it helped me .. Iw as in a bad mood, didn't realize it was your first post...
IMO 20's are on Maximas.
Old Jul 26, 2005 | 03:55 PM
aiight thanks man, appriciate it.
Old Jul 27, 2005 | 09:58 AM
MaximaPolak's Avatar
I have 245/35/19s on my 19s. No rubbing issues at all and I have S-tech springs.
Old Jul 27, 2005 | 11:45 AM
00MaxSE's Avatar
Pointy Elbows
I'm running 19x8.5's with 245/35 rubber dropped on Progress/Illuminas. No rubbing. You should be fine. Just watch out for those curbs and potholes.
Old Jul 27, 2005 | 12:08 PM
ICULookN's Avatar
Would 245/40/20 be alright?
Old Jul 27, 2005 | 12:16 PM
NmexMAX's Avatar
dot dot dot ...
That's almost 2" taller than stock .. Probably not ...
do the math
All in mm (metric)
245 x 0.4 x 2 = 196
20 x 25.4 = 508
Convert to inches
508 + 196 = 704/25.4 = 27.72" stock is 25.86"
www.tirerack.com for further information, as I stated above
Old Jul 27, 2005 | 12:27 PM
I'd say 245/30/20
Old Jul 27, 2005 | 01:23 PM
fornimage's Avatar
doug
I have a 2002 SE dropped on H-techs(~1.5") & Tokico Illuminas running 245/35/19's(40mm offset) wrapped in Falken Azenis ST-115's and I have no rubbing issues at all. Only thing is I wish I chose a lower offset to fill in the fenders more.
The lower the number offset of the rim, the more the rim will stick out towards the fender. And the higher the offset number, the more the rim will seat inwards. As long as you stay within that tire size and stay above ~32mm offset, you will be fine.
Old Jul 27, 2005 | 06:53 PM
stevay's Avatar
245/35/19 on jic's
sorry for big pics
Old Jul 27, 2005 | 07:33 PM
seventy5impala's Avatar
Nice thread..... as im lookin too get 19s soon myself...question tho.....is 19x9.5 completly out of the question???? what about staggered 9.5 rear 8.5 front???......
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
