Cant get shift knob off? how do I do it?
Old Oct 10, 2000 | 07:30 PM
I want to get a new **** on my car but I cant get it off. I tried using a wrench but it just tore my shifter up. ayudame!
Old Oct 10, 2000 | 07:48 PM
ChaCha's Avatar
I know how you feel !
I spent about 30 minutes turning and pulling with no results. I was told by a friend that his 00 civic has clips inside the ****, which required a device resembling a fork to remove the ****. His dealer took care of it free of charge. So, I took my Max to the Nissan dealer and found out they had no such tool. They just called the biggest guy over and 5 minutes later he got it off. Only problem, the factory **** was destroyed. Oh well, its a crappy ball of plastic.
Old Oct 10, 2000 | 07:55 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
You'll have to cut the OD wires... then it'll slide right off.
Old Oct 11, 2000 | 05:07 AM
Confused's Avatar
Permanent Maxima.org Resident
5spd=use strap wrench, auto ??
Old Oct 11, 2000 | 05:50 AM
Maximizd's Avatar
Yes, the 5 Speed you need...
a strap wrench or if you don't have one, use a channel lock and put a rag or towel around your ****. You will probably damage the one coming off, but if you have a new one, no big deal. You have to twist it to break a glue seal, then just keep screwin'! The new one I put on was self threading, but I used some epoxy in there just to make sure it wasn't going to get loose at a bad time!
Old Oct 11, 2000 | 07:16 AM
dave's Avatar
with the 5 speed...
twist counter-clockwise, correct?
Old Oct 11, 2000 | 07:41 AM
Paul6speed's Avatar
Oh, you can't disconnect the OD wire? That's too bad. I guess you have to splice the new connection? Do most shift kits include the connectors?
Old Oct 11, 2000 | 08:18 AM
Y2KevSE's Avatar
Yup!
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
