LTB vs. FSB
Old Jul 21, 2005 | 10:26 AM
ScholaR?'s Avatar
LTB vs. FSB
Sorry to bring this up, but the "Reduce roll" thread closed before I could ask my question.
QNS: How does the LTB differ from the Front Sway Bar (FSB)? Reading the description of the LTB it sounds an awful lot like an FSB. Would a larger diameter FSB have the same effect as an LTB?
Please comment
Old Jul 21, 2005 | 10:30 AM
Jeff92se's Avatar
I'm needing a caw
LTB = chassis stiffness
FSB = Sway bar? Roll stiffness
FSB = strut tower brace? Chassis stiffness
I don't think they make an aftermarket front swaybar for the 5 gen
Old Jul 21, 2005 | 10:32 AM
GBAUER's Avatar
LTB: Lower Tie Bar
FSB: Front Sway Bar
Lower tie bars are already on the max. This is the bar that connects the two tires and turns them equally. The Front Sway Bar is a bar that is added and increases the regidity of the LTB. They both essentially do the same thing.
Old Jul 21, 2005 | 10:33 AM
GBAUER's Avatar
You beat me to it. And, just for reference, i've never seen a FSB for the 5th gen.
Old Jul 21, 2005 | 10:42 AM
Jeff92se's Avatar
I'm needing a caw
wtf? Did I stutter or something?
Old Jul 21, 2005 | 10:48 AM
ScholaR?'s Avatar
Sorry 1 more Qns?
Can one go TOO far with the sway bars, tie bars and such? I guess this is more of a fundamental question. But if these "bars" improve handling w/o reducing ride quality, why would all manufacturers make huge lower tie bars for their "sporty" models.
Just Brainstorming here:
- Is it because their IS a loss with the improved roll characteristics? (ie. reduce ride quality)
- Is it a cost issue? seems unlikely considering how cheaply BlehmCo, Stillen and such sell parts for
I guess what I am ultimately asking is what are the drawbacks (negatives) with adding strong swaybars/ LTBs (I am aware of the oversteering issue with the RSBs)
Just curious. thanks for the info in advance.
Old Jul 21, 2005 | 10:49 AM
ScholaR?'s Avatar
Jeff,
Sorry about that...Just reread the whole thread.
OK no more questions from me today. Thanks guys
Old Jul 21, 2005 | 10:52 AM
Jeff92se's Avatar
I'm needing a caw
Chassis can never be too stiff. And you CAN go too far with springs/shocks/sway bars. But for one NO one makes a frt sway bar for the 5-gen that I know of. And if they did, I really doubt it will be designed TOO big. They usually error on the soft side perse. Rear bar. I don't think there is actually a rear bar that is TOO far. It's the rear beam design that kills you guys, not a too stiff rear bar.
Old Jul 21, 2005 | 10:58 AM
E55AMG2's Avatar
Wat
the FSB thats already in there is f'n huge...
Old Jul 21, 2005 | 11:03 AM
GBAUER's Avatar
No. I was typing and entered my post seconds after you did.
Old Jul 21, 2005 | 11:05 AM
Jeff92se's Avatar
I'm needing a caw
Just for reference. The 3-gen oem bar is hollow. The ST stiffer bar is the same dia but solid.
Old Jul 21, 2005 | 11:07 AM
E55AMG2's Avatar
Wat
Ours is solid (5th gen) IIRC
Old Jul 21, 2005 | 02:52 PM
irish44j's Avatar
retired moderator
let me clear a few things up:
1. The lower tie bar comes in two types:
- stage 1, which connects the control arm bush pin assemblies.
- stage 2, which conntects the control arms AND the front subframe.
The tie bar doesn't "stiffen the ride," it provides better steering input/respons, and less "twist" of the front subframe (which in turn flattens the front end out without altering the suspension itself).
The reason manufacturers don't install LTBs: it reduces ground clearance, since it goes UNDER the tranny.
As noted above, the front SWAY bar on the 5th gens have no aftermarket replacement at this time (though you can put poly bushings on it).
the front STRUT TOWER BRACE (FSTB) has a much more subtle effect and doesn't really effect the "lean" of the car. It is (like the LTB) a frame brace/stiffener, but just not as effective as a LTB.
All in all, the LTB is a great addition unless you are lowered alot, or live in areas with uneven roads/raised manhole covers/etc...
Old Jul 21, 2005 | 02:55 PM
irish44j's Avatar
retired moderator
Originally Posted by GBAUER
LTB: Lower Tie Bar
FSB: Front Sway Bar
you have them backwards, donkey. There is an FSB stock. There is NO LTB stock...
go back to paining the old engine cover George.
Old Jul 21, 2005 | 03:42 PM
LA02MAX's Avatar
you beat me to it...
Matt93SE
May 24, 2019 02:58 PM
ItchyRichy
May 8, 2001 03:20 PM
jaxima
Apr 23, 2001 05:56 AM
jaxima
Feb 3, 2001 06:45 PM
bad2rock
Jan 10, 2001 10:11 AM
