For those who think blowby is minimal....
Old Jul 26, 2005 | 07:00 PM
  #81
Jay_pee99's Avatar
But would that set a check engine light? Is there a hands on way to check the PCV valve?
Old Jul 26, 2005 | 07:02 PM
  #82
irish44j's Avatar
retired moderator
pull it out...see if you can blow through it...it's basically a little ball-bearing valve thingy. Forget that....just go buy one from Autozone or Advance Auto, they're like 5 bucks....then you don't have to worry about if its working or not.
Old Jul 26, 2005 | 09:31 PM
  #83
00SEMAX19's Avatar
Thats a really good idea! I have a 5.5 and I've also had my intake off and it's really obvious how much oil is dumping on the valves. My mechanic told me that i would eventially burn a valve. I'm gonna get started on this right away, It will be an easy mod. Thanks to whoever thought this out!!!
Old Jul 26, 2005 | 09:34 PM
  #84
00SEMAX19's Avatar
Originally Posted by Nomad
hell no I don't think so much oil would pass in IM
I burn through a good two to three quarts of oil every 3000 miles. I have no oil leaks either, I don't think that much is going in the intake but a good portion of it is. Think my driving style eats the oil, been like that in most my cars
Old Jul 27, 2005 | 05:32 PM
  #85
panda_1's Avatar
the brass fittings that screw into the inlet and outlet sections on the reservoir, are they 1/4 inch npt fittings? or soemthing else?
Old Jul 27, 2005 | 06:49 PM
  #86
spiromax's Avatar
Seoul Man
You'll generally find two different sizes of air compressor filters at Lowes or Home Depot. One size has 1/4'' NPT (Female) ports and a small reservoir while the other size has 3/8'' NPT (Female) ports and a larger reservoir. If you go to Walmart, you will only find small ones. I can't tell for sure, but from the pics it looks like Irish is using the smaller filter. The first setup that 2002 Maxima SE posted is also using the smaller filter (he has switched his setup to a catchcan with a larger metal reservoir).
I went out and bought the parts to build my own catch can setup tonight. In fact, I just finished mine about twenty minutes ago, and it works fine. The parts list that I'm posting below may not be the same list that some of the other guys have used, but it's the simplest combination of fittings that I could scrape together from what was on the shelves at my local Home Depot and Lowes. It is ENTIRELY possible that there is a way to do this with fewer fittings, but not with what I had available to me at my local hardware stores.
If you buy the smaller filter with two 1/4" NPT (Female) ports, you'll need two fittings on each port for a total of four fittings. The fittings you'll need on each side are a male to male 1/4'' NPT connector and a 1/4'' NPT (Female) to 3/8'' hose end connector.
If you buy the larger filter with two 3/8'' NPT (Female) ports, you'll need three fittings on each port for a total of six fittings. The fittings you'll need on each side are a male to male 3/8'' NPT connector, a 3/8'' NPT (Female) to 1/4'' NPT (Male) reducer, and a 1/4'' NPT (Female) to 3/8'' hose end connector.
You may be wondering why anyone would go to the extra trouble and extra cost of using the larger filter and extra fittings if you're just going to end up with the exact same internal diameter on each of the hose ends. The answer is that I did not choose the larger filter for better flow (the stock tube wasn't that big to begin with). I chose the larger filter because it has a larger reservoir, so it shouldn't need to be emptied as often.
Old Jul 27, 2005 | 07:13 PM
  #87
irish44j's Avatar
retired moderator
I didn't see any larger filters (and I looked at several places)...could you provide a pic of the filter/packaging?
Old Jul 27, 2005 | 08:14 PM
  #88
MaxGordon7's Avatar
Ive never really seen any oil in my intake, but i will check it out. I have changed my pcv last month and i dropped the old one down below the engine and intake manifold so i couldnt get it out!! I hope it just melts a little from the heat and falls out of there! Great mod tho, ill give it a try if i feel up to it.
Old Jul 27, 2005 | 08:47 PM
  #89
Glude's Avatar
I need to do this on my 04.
Old Jul 27, 2005 | 09:51 PM
  #90
spiromax's Avatar
Seoul Man
CLICK THE IMAGE TO ENLARGE
Both were available at Home Depot. It also turns out that Husky brand filters are manufactured by Campbell Hausfeld, so if you buy the Campbell Hausfeld filter at Walmart (they only have the smaller one), you're getting the same thing as the Husky.
The larger filter's reservoir is bigger and it's a metal reservoir with transparent polycarbonate windows instead of a completely transparent polycarbonate reservoir. The larger filter also has a large valve on the bottom that you can twist to drain its contents easily (not that the small filter's valve is hard to use).
Old Jul 27, 2005 | 10:14 PM
  #91
Gears & Crosses's Avatar
Originally Posted by NewLoveI30
Thanks for the suggestion. I think Im just gunna wait till I get my PR/Cattman intake, then I can just rotate the filter in it's holder and Ill have a straight shot to the inlet :
No problem. Again nice setup, and it is very nice to look at. I like that pipe strap setup also.
Good luck with your new intake / car,
Gears
Old Aug 7, 2005 | 09:11 PM
  #92
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I just did this mod and I have a question for those who have done it on a 4th or a 5th gen. Did you guys noticed a more prounced hissing sound? My hoses are farther off then most that I have seen in this thread so I dunno if that has to do with it? My idle seems fine and everything runs good. Any feedback will be great.
Old Aug 8, 2005 | 04:44 AM
  #93
2002 Maxima SE's Avatar
^^ Yup, mine hiss. I thought I had a leak.
Old Aug 8, 2005 | 03:31 PM
  #94
irish44j's Avatar
retired moderator
I haven't noticed any hiss......
Old Aug 8, 2005 | 04:12 PM
  #95
nirvana4all's Avatar
still looks like a great mod for saving your engine
Old Aug 8, 2005 | 06:18 PM
  #96
irish44j's Avatar
retired moderator
By the way, I did see that large filter the other day at Home Depot...that thing is pretty freaking big.....and was like $30.....may have to "upgrade" eventually to the big one
of course, I'll have to paint it chrome and gold so it will look "bling"
Old Aug 8, 2005 | 06:57 PM
  #97
spiromax's Avatar
Seoul Man
I hear a very faint noise that I guess can only be described as a light hiss. I don't think it's a problem. It's just that you're now running the output from the PCV through a much longer hose and a filter element (it used to run through a straight tube that's only a few inches long).
Old Aug 8, 2005 | 07:26 PM
  #98
LOL^
No dude, you have to paint that thing blue and put some "NOS" stickers on it. Then tell those slow Honda street racers that the reason your car is faster than theirs is because you found a new way to inject Nitrous into your engine. Call it the Super Shot direct engine port fogger system.
I can hear you scam them now: " Its an experimental system thats on loan to me from Nitrous Oxide Systems." " I like this system a lot, but when you hit the button the power hits so hard... I'm on my second set of CV joints!!!"
Just kidding of course,
Gears
Old Aug 8, 2005 | 07:44 PM
  #99
irish44j's Avatar
retired moderator
Originally Posted by Gears & Crosses
LOL^
Gears
I'm thinking of putting some radioactive stickers on it, and then I can tell them either:
- it's a small nuclear reactor that gives me WAAAYYY more boost than a turbo or NOS...or...
- it's my "flux capacitor" (anyone here younger than 20 will probably not get the reference)
Old Aug 8, 2005 | 09:11 PM
  #100
Iilac's Avatar
Cool, thanks for the response everyone. Also 2002 Maxima SE, I got the same catch can you did off of ebay.
Old Aug 8, 2005 | 11:35 PM
  #101
spiromax's Avatar
Seoul Man
1.21 GIGAWATTS?!
Old Aug 9, 2005 | 05:35 AM
  #102
bkucera's Avatar
That's amazing. Is this something everyone should do?
Old Aug 9, 2005 | 02:45 PM
  #103
irish44j's Avatar
retired moderator
it can't hurt, it can only help (oh, and it's nice and cheap)
Old Aug 20, 2005 | 02:06 PM
  #104
RA030726's Avatar
I'm nutty for Nissans
I have had mine installed for about a year now. Today I changed some plumbing but it looked like this .
Now its hidden behind the intake mainfold.
According to the SRT4 write up, taking out the filter catches more oil. Ill have to try that.
ALSO: be advised, the catch can states that bowl failure may occure with synthetic oils. I have been keeping an eye on it since I use mobil 1 synth. No problems yet.
Old Oct 6, 2005 | 07:57 AM
  #105
Updates from the newly inducted?
Old Oct 6, 2005 | 11:29 AM
  #106
maseo77's Avatar
subscribed
Old Oct 6, 2005 | 03:08 PM
  #107
steven88's Avatar
Need A Light?
Will a broken PCV valve still shoot out oil to the catch can? I have about 42k miles and was wondering if my PCV valve is still okay or not....After pulling off the hoses, does the PCV Valve just come off with a small tug? What signs do I look for in a broken PCV valve?
Old Oct 6, 2005 | 03:32 PM
  #108
RA030726's Avatar
just shake the pcv and it should rattle. that means its working.
Old Oct 6, 2005 | 11:06 PM
  #109
hesham1's Avatar
Newbies Get All The Chicks
since my warranty is just about over this doesnt apply to me, but if a dealer saw this would it void a warranty? i guess it would be pretty quick to remove the whole set up before taking it to a dealer....
also does anybody have any pictures of a crankase breather filter setup?
Old Oct 7, 2005 | 01:55 AM
  #110
spiromax's Avatar
Seoul Man
I've had my catchcan on for over a thousand miles now, and I've had no problems with it. I've only had to empty it once, and it's half way to full again (I'm using the larger inline air compressor filter rather than the small one that many others are using).
I'll post pics later.
Old Oct 7, 2005 | 12:11 PM
  #111
hesham1's Avatar
So whats the final word on which is better - Catch Can or Air Compressor Filter? No problems with damage from heat so far? The catch cans from ebay do not have filters in them correct?
Old Oct 7, 2005 | 12:34 PM
  #112
igzy's Avatar
I Know Kwaliti
I have an in-line compressed-air filter and it works fine. Will try to post a pic later this evening on my set up...
Old Oct 7, 2005 | 02:48 PM
  #113
RA030726's Avatar
i took out my filter and it catches more oil
Old Oct 7, 2005 | 04:08 PM
  #114
igzy's Avatar
I Know Kwaliti
Just currious, which filter have you taken out?
Old Oct 7, 2005 | 04:10 PM
  #115
igzy's Avatar
I Know Kwaliti
Thanks to Irish's help and as promised here is a photo of my setup. The oil separator is on a slight angle to ensure that the oil stays in:
Old Oct 11, 2005 | 04:22 PM
  #116
Maxima 5-0's Avatar
i got big Husky filter from home depot. my setup was a bit more expensive ($65) ...cdn. funds and all.... but it was really easy to install. thanks Irish for the pics and write up. I'm still running the stock air box so finding a place to mount the big husky is proving to be a challenge...
Old Oct 11, 2005 | 04:46 PM
  #117
irish44j's Avatar
retired moderator
Since I re-installed my factory air box I didn't have room either, so I re-mounted it on the other side of the engine, using the bracket that used to hold the under-the-hood horn (it's now behind the grille), and a piece of metal extension and c-bracket. Had to get longer hose though....
Old Oct 11, 2005 | 05:06 PM
  #118
RA030726's Avatar
the one inside the water separator for an air compressor.
Old Oct 11, 2005 | 05:38 PM
  #119
igzy's Avatar
I Know Kwaliti
I went there too, but you can get a much cheaper filter at Princess Auto. I got mine there for CDN $12 and is smaller and easier to install. See my photo above...
Old Oct 11, 2005 | 05:39 PM
  #120
igzy's Avatar
I Know Kwaliti
Holly smokes... How difficult was that?
