STS is hard to shift?
Old Jul 23, 2005 | 05:11 PM
godlyone's Avatar
ahhh! cliMAX!
I checked out a car today with a STS [short throw shifter] installed
It actually took hard pulls to shift.
Is that normal for a short throw one? It was B&m i think..
I am used to being able to move the shifter with one finger.. not pulling on it with a decent amount of force.
Is the stock shifter "easy" like you can move with one finger? I think if I buy the car I will swap the stock one on.
Is the change possible to do without getting the car on the lift?
thanks.
Old Jul 23, 2005 | 06:09 PM
rmh3093's Avatar
Only gentoo powered Maxima!
short shifters come in 2 styles:
style 1. changes the fulcrum point to achieve a shorter throw but keeps the stock length
style 2. changes the fulcrum point and reduces the lenght of the shifter
the larger the distance from the fulcrum to the shifter ****, the easier it is to shift (more torque) but you have to move the shifter a farther distance
you should be able to do the install with a decent jack
Old Jul 23, 2005 | 06:21 PM
godlyone's Avatar
ahhh! cliMAX!
it was style #2.. but it was alot harder to shift .. thats normal for a sts right?
Old Jul 23, 2005 | 07:29 PM
godlyone's Avatar
ahhh! cliMAX!
also, how long would it take to change back to the stock one?
Old Jul 23, 2005 | 07:56 PM
crispykid717's Avatar
Bigger than Jesus
My stock shifter was hard to shift. After installing the Hp Autoworks STS it did not make the shifts any easier.
Old Jul 23, 2005 | 08:04 PM
roll4life's Avatar
my stillen sts is way stiffer than the stock one..but i like it a lot more
godlyone's Avatar
ahhh! cliMAX!
this is a 2000 btw..
is the stock one easy though? crispy.... are you an isolated incident?
Old Jul 23, 2005 | 11:51 PM
ChromeSE5's Avatar
the new shifter bushing from larrio and *** is suppose to help with the stiffness of the shifting.
Old Jul 24, 2005 | 12:05 AM
Mr_Red's Avatar
has the crossover linkage been adjusted recently? (left to right not front to back)
I only know that when I installed my STS in my '02 I disconnected the adjustment for the x-over linkage to put in the shifter base bushings. Shifting was so bad that my wrist became so inflamed that I could barely shift.
I just recently readjusted my linkage and now it shifts smooth like butter.
Old Jul 24, 2005 | 12:53 AM
OOmaxSE's Avatar
i took off my stillen sts because it was too nochy, now i have stock and it took me about 1.5 hours on a lift to change. i couldn't take apart the stillen so i just used a dremel and cut the stick. but i honestly hate rowing the boat with the stock.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
