How do I remove the door panels to install speakers?
Old Jul 27, 2005 | 03:05 PM
StrongIsleMax's Avatar
I am trying to remove the door panels to install speakers, but I ahve no idea how to take of the doors panels. How do I do it?
Old Jul 27, 2005 | 03:27 PM
nismo0604's Avatar
pop the trim off around the door handle i believe theres a screw in there somewhere, and then there is clips around the whole door
Old Jul 27, 2005 | 04:39 PM
UGAd13's Avatar
There is a screw in the pocket right under the window controls. You have to pop off the little tab with a flat head then remove the screw w/ a phillips head. Then stick your fingers or a screw driver in the slot on the bottom of the door panel and pop it off.
Old Jul 27, 2005 | 04:46 PM
shoman94's Avatar
http://maxima.theowensfamily.com/tsb/NTB99-045.pdf
Old Jul 27, 2005 | 05:59 PM
speaker install
I figured out how to open the panel, thanks for the help. There is no wiring harness available for the car so crutchfield says I need to splice it in. How can I determine +/- on the original speaker. More generally, how do I do splice the harness in? BTW I do not have bose
Old Jul 27, 2005 | 06:12 PM
Bensmax00's Avatar
The best way to do it is to get the wiring diagram for the speaker and hook it up taht way--If you do get a wiring diagram if there is a blue wire or something like that NISSAN use L for blue the rest is good (for example a wire with L/R would be a blue wire with a red tracer) hope that helps
The way I do the splicing is to create a harness for the speaker--find some connectors that fit into the speakers and soldier the wires to those connectors(cut the wires from the nissan connectors) also would use some shrink tubing to put around the soldier spots. But thats just the way I would do it.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Stelianos
Aug 19, 2015 02:07 PM
Abdelrhman
Aug 17, 2015 12:16 PM
kirkhilles
Aug 8, 2015 10:53 AM
