Cleaning the IACV
Old Jul 28, 2005 | 11:24 AM
2248's Avatar
Cleaning the IACV
Does anyone have a write-up on cleaning the IACV? I tried searching around on the org, but wasn't able to find anything. Thanks everyone!
Old Jul 28, 2005 | 11:27 AM
Gennady7's Avatar
I think you have to get it replaced, it does not get cleaned. 200 or so on courtesy nissan site.
Old Jul 28, 2005 | 11:42 AM
HenryNYC1's Avatar
Do not attempt to clean it. Cleaning it may actually damage it and cause it to stop working properly. If you must just replace but not worth it if it is working and you just wanted to clean it up. Wish someone answered this question for me when I did it to my other car lucky it was only 70 bucks and not 200
Old Jul 28, 2005 | 11:45 AM
Gennady7's Avatar
Where did u get it for 70?
Old Jul 28, 2005 | 11:46 AM
GaMax97GLE's Avatar
It's only $175 at www.pinnaclenissan.com (and I got mine next day shipped).
Ordered at 6:30pmEST
Received at 10:30amEST
I just changed mine last night and it came with all the parts (IACV, sensor, screws & gasket).
This is how I did it...I didn't have a write-up to follow and it could be the wrong way:
1) Remove stock air box (6 or so bolts) and MAF tube
2) Remove accordian looking tube between throttle body and part of air box
3) Unplug 2 sensors on TPS (throttle position sensor on throttle body)
3) Unbolt 4 bolts holding Throttle Body in place
4) Remove two tubes from IACV (on to the left and one under). These leak fluid (coolant I assume)
5) Unplug sensor to IACV
6) Remove TB and IACV as one unit. Take to work bench
7) Flip over entire unit and unscrew 5 screws securing IACV to TB (careful, I stripped last one and had to wiggle the two piece around to loosen the screw)
8) Detach and set aside IACV. You're done with it and the sensor
9) Remove gasket from TB and any junk left from it
10) Clean TB with TB cleaner and wipe down butterfly valve
11) Place new gasket in groove
12) Set IACV in place and hand tighten the 5 new screws
13) Tighten screws with flat head screw driver (I did like you would lugnuts, alternating every other one)
14) Bring new unit back to engine bay
15) Re-install both fluid tube to IACV
16) Plug in sensor to IACV
17) Bolt TB to manifold with 4 long bolts (make sure gasket threre didn't fall)
18) Re-install accordian tube
19) Re-install air box
20) Double check all bolts
Mine is still throwing a code but my buddy said I had to bring it back to him at Nissan anyway. I was having problems with my TPS before and we had adjusted the throttle cables to get me running again. Now that eveything has been replaced, we're going to get all the codes looked at again and cleared.
Hope that helped.
Eric
**EDIT**
I'm not sure you clean it. Mine wasn't dirty...mine was bad from a SES code.
Old Jul 28, 2005 | 11:54 AM
Gennady7's Avatar
Hope that helped.
Eric
What was the reason you had to change it, what was the code or error?
I got something simulair. I think you gotta replace ecu
Old Jul 28, 2005 | 01:01 PM
GaMax97GLE's Avatar
-ECU was replaced last year when Nissan fried it while replacing MAF
-Last month TPS gave error...replaced it last week
-Then IACV gave error...replaced yesterday
Yeah, if it still has and error then I might need the ECU replaced and I'm going to be pissed. But original guy that fried it will do under warranty...but then I'm still out $300 (for TPS & IACV) IF they were indeed ok. But they're bound to fail at some point right?
Old Jul 28, 2005 | 02:06 PM
2248's Avatar
Ecu
How did you know that your ECU needed to be replaced, symptoms? Also, how much and where did you get it from? Thanks!
Old Jul 29, 2005 | 06:26 AM
GaMax97GLE's Avatar
Me? Mine was done free under warranty since the Nissan tech fried it when he hooked up the OBDII and it lost power while reprogramming the ECU.
But the ECU should be covered under the Federal Emmissions Warranty of 80,000 miles or 8 years...same as catalytic converters...right?
http://www.epa.gov/otaq/consumer/warr95fs.txt
Old Jul 30, 2005 | 11:26 AM
Gennady7's Avatar
Still wondering where I can get it for 70 posted ^ by HenryNYC1
Old Aug 1, 2005 | 09:01 AM
HenryNYC1's Avatar
Sorry haven't checked here for a bit. The $70 was for my other car and it wasn't a Max, It was for my 97 Dodge Avenger V6.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
