Is this an emergency?!(inst panel lights)
Old Aug 4, 2005 | 06:30 PM
instil's Avatar
Today i drove to 7-11. No problems with that 2 minute ride. I get back to car,start it up, and the following lights lit up and stayed on when i started the car: ABS,SLIP,& TCS OFF (obviously traction control,i hit the switch manually to make sure i didnt hit it on accident, but it didnt do anything)
This was earlier today, and theyve stayed on all day.
Whats the consensus on this? Urgent issue,or give it a day? Also, im assuming this would be something covered under warranty correct?( my pads and rotors are ok,btw)
Old Aug 4, 2005 | 06:36 PM
instil's Avatar
side note: are there any sensors which would be related to this problem near the muffler. My muffler and the connecting pipe are bouncing around like crazy this week,maybe they banged into something?
Old Aug 4, 2005 | 06:45 PM
BewstAdd1ct's Avatar
if you car is still under warranty, then yes, it should be a covered repair.
could be one of several things, from a WSS to a failed module... you might check for chafed or otherwise damaged wires, but its easiest just to pull codes and go from there.
Old Aug 4, 2005 | 06:57 PM
instil's Avatar
whats a WSS?(off the top of my head....wheel speed sensor?) Tomorrow I'll check for damaged wiring,it was too dark by the time i got home. I should add, no Check Engine Light, just the 3 related ABS/TCS lights.
Old Aug 4, 2005 | 07:14 PM
yes, wheel speed sensor.
take a look and make sure any aftermarket parts didnt cause it. you dont have neons of aftermarket stereo or anything, right?
Old Aug 4, 2005 | 07:32 PM
instil's Avatar
You think my strobing rainbow ground-effect neons are messed up?!!! Nah,just kidding,all stock as far as exhaust,pipes,electrical wiring. I wasnt even sure if the problems were related,but that would be a big coincedence if both went wrong in the same week (dashboard lights for a brake problem, and loose hanging exhaust.) I wanna look real quick before i take it in,just for the hell of it. Good lookin on the helpful responses.
Old Aug 4, 2005 | 07:42 PM
nooooo prob
Old Aug 4, 2005 | 08:04 PM
instil's Avatar
only two semi-newbs can help each other? I figured for at least one veteran response,and one witty (but actually Not Funny) comment from somebody.
Old Aug 5, 2005 | 07:36 AM
im not a n00b, just to this board
ive been working on cars since i was 16, i currently hold SEVERAL certifications on 3 differenct makes of vehicle, and im a site moderator over at www.southfloridaracing.com
Old Aug 5, 2005 | 07:43 AM
instil's Avatar
word. i just meant your not on this board often.
Old Aug 5, 2005 | 10:23 AM
yes, well im buying a 5.5 this weekend, and my 91 hasnt really given me any problems.
and you guys cant help me with my truck issues
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
