RPMs drop and car turns off...
Old Aug 7, 2005 | 10:20 AM
xplosive9z's Avatar
2k auto gle... i changed my spark plugs, (NGK)... and today i turned my car on, the RPMs dropped slowly and the car just turned off...!?!?! also, usually the heat & gas that comes out of my exhaust is smooth and steady... but now i noticed that it "puffs"... meaning it's puffing out gas like every .5 seconds instead of the usual smooth and steady release...
what should i do?
Old Aug 7, 2005 | 10:54 AM
BewstAdd1ct's Avatar
run a fuel pressure test.
Old Aug 7, 2005 | 12:05 PM
xplosive9z's Avatar
thanks bewst...
any other suggestions?
update: i went to autozone to see the error codes from the SES light...
p0171 - engine too lean, bank 1
i put my stock intake back in... and i ordered a new MAF, i'm guessing i have to get it updated (ECU)?
Old Aug 7, 2005 | 01:12 PM
check for intake leaks. seriously, it sound like youre running out of fuel after startup.
Old Aug 7, 2005 | 08:55 PM
shurik's Avatar
Maybe you didn't put the spark plugs the right way or something like that, but who knows, you should know better then us the way you changed them.
Old Aug 7, 2005 | 09:14 PM
Emaxxima's Avatar
check ur intake
Old Aug 8, 2005 | 10:32 AM
super6's Avatar
agree with all of above, plus cpould be one of the bank 1 O2 sensors...but that wouldnt cause the car to shut off, sounds like a maf problem, but since u just changed the plugs it may be related to that.
Old Aug 25, 2005 | 02:27 PM
kam1luv's Avatar
Check the throttle wire and all the connections on the ignition coil.
Old Aug 25, 2005 | 03:52 PM
Mr. Ryte's Avatar
Were the plugs gapped to the right specs?
I say check that first.....
Old Aug 26, 2005 | 12:05 PM
Mr_Red's Avatar
one way to help rule out the MAF (actually it simply rules out a sensor problem) is to simply disconnect your MAF. ITs easy to access. Without the MAF signal the car will switch to limp mode. The car should run quite fine but will not rev over 2200 or so RPM.
If it doesn't run fine, it's not your maf or O2.
Old Aug 26, 2005 | 05:13 PM
did you ever figure out what it was? did you run fuel pressure test to eliminate that?
will it stay running if you hold the gas pedal a bit?
Lakersallday24
Jun 16, 2019 01:35 AM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
mrgooch
Aug 9, 2015 11:00 AM
