2001 O2 Sensors
Old Aug 11, 2005 | 12:30 PM
fourthrail's Avatar
2001 O2 Sensors
I recently had my 2001 in at the Nissan dealer for an inspection (with the SES light on, mind you), and I was told that I needed 2 front oxygen sensors. So I had to ask ... $695 installed ... so I declined, paid the diagnostic, and left.
How hard are these to change? Anyone have a procedure and/or photos from when they did this? I was able to find the sensors online for $107 each. Thoughts?
Thanx...
Old Aug 11, 2005 | 12:52 PM
njmodi's Avatar
Do I get a tax break?
You might want to read the stickies and go hide before a mod finds you.
In answer to your question - easy to do yourself, that price seems reasonable - might be lower at www.oxygensensors.com.
Old Aug 11, 2005 | 02:35 PM
BewstAdd1ct's Avatar
sensors list for 137.43 and labor to replace both fronts is 1.8hrs, plus 1hr diag.
so about 3 hours labor at $90 (or whatever rate your shop uses) = $270 + 137.43 x 2
so about $540 range is what you should have been quoted.
Old Oct 12, 2005 | 01:55 PM
fourthrail's Avatar
Anyone have any pics or information before I give this a shot?
Old Oct 12, 2005 | 04:46 PM
Rob01ski
First off its nissan they WILL RIP YOU OFF unless your an old white guy, trust me i seen it in person.
Ah what you need is only one main sensor, and a simulator. Only one of the sensors does anything, thats the first one it monitors air/fuel tells comp to adjust. The other is just a downstream, basically check if everything running ok it does not control anything, its just a monitoring sensor. Oh yeah never go to nissan if you dont have a warranty. Dude go to autozone and tell us what codes you got, then check the stickys for the code. So we know exactly what it is cause nissan is a bunch of bullsht.
Oh yeah if your car has less then 60k this should be covered by the warranty if not ask for manager make ALOT OF NOISE in front lobby so customers look at whats going on, they will fix your problem right away.
Old Oct 12, 2005 | 05:07 PM
upstatemax's Avatar
I know on my 00 there are two primary (front) O2 sensors, one on the front manifold and one on the rear, both are needed. I have my secondary O2 sensors simulated.
Making alot of noise at the stealership will get you no where other than out the door and asked not to come back.
I know the primary on the front manifold is easy to replace. The rear as I remember is a little harder to get to. They are simply unscrew old and scew new one in. I would also unplug your battery before you change them so you clear the codes.
i got one of my O2 sensors from THIS place, they were the cheapest I could find and they had fast shipping.
Old Oct 12, 2005 | 05:14 PM
Puppetmaster's Avatar
From the FSM:
Hope that helps...
Old Oct 12, 2005 | 07:29 PM
BigFly_2K2SE's Avatar
I just changed one of my O2 sensors on my 2K2 yesterday. A "how-to" shouldn't be needed.
- Find the correct sensor using Puppet's linked drawing.
- Use a 7/8" wrench or preferably on O2 sensor wrench to remove the sensor at the sensor end of the wires.
- Use needle nose pliers to disconnect the electrical harness at the electrical connection end.
- Remove wire clips holding the wire in place at various locations (4 or 5 in total).
I am by no means mechanically inclined and I managed it although I won't say it wasn't without any difficulty. The wire clips in some spots are EXTREMELY hard to get at and therefore hard to get out. In most cases I ended up grabbing on the wire and pulling it until the clip either came out or broke. This usually ended up with me scraping my hand. The new sensor has new clips so you don't need the old ones. There might be a "tool" or "technique" that I am not aware of that could help with this, but the locations are not good so unless you remove some other stuff first, I doubt it.
Also, I recommend that you install the new sensor as you pull the old one out so you don't forget about the locations where some of the clips go.
Old Oct 12, 2005 | 07:57 PM
its not nissan, its the individual dealer, and race or age has nothing to do with it.
as for the rest of your post, its either incorrect, or a bunch of
depending on wihch part of it youre reading.
Ah what you need is only one main sensor, and a simulator. Only one of the sensors does anything, thats the first one it monitors air/fuel tells comp to adjust. The other is just a downstream, basically check if everything running ok it does not control anything, its just a monitoring sensor. Oh yeah never go to nissan if you dont have a warranty. Dude go to autozone and tell us what codes you got, then check the stickys for the code. So we know exactly what it is cause nissan is a bunch of bullsht. and what happens when you have a REAL problem, like one that autozone cant fix?
sure they will... except o2 sensors arent covered under the 8/80 warranty. YOU will be paying out of pocket. id like to see you try that one, and get it on video.
Old Oct 13, 2005 | 02:11 AM
Maxi113's Avatar
OMG for the love of God not another sensor question!!!
Old Oct 13, 2005 | 05:42 AM
Deckdout2's Avatar
Play with my balls
This post is unnecessary, dumb, unhelpful, and stupid......as well as all your other post.
Old Oct 13, 2005 | 03:33 PM
Stardust's Avatar
F---ing Kangaroos
OMG not another stupid post from you.
Old Oct 13, 2005 | 05:00 PM
Old Oct 13, 2005 | 05:12 PM
Rob01ski
ACTUALLY making alot of noise does help especially when theirs customers around, i did it when this old white guy was their buying fully loaded maxima. He came to see what was going on and they were like oh sht, hes looking. After that they were all nice and loud in saying oh sorry for the mix up sir our mistake blah blah blah.
Old Oct 13, 2005 | 05:18 PM
Rob01ski
Yeah it was late i forgot to say TWO SENSORS instead of one
lol rofl ahahahhaa right dude are you and immigrant or black. If not then you have nothing to complain about cause they dont bother you but since im an immigrant i do. Ask any other polak in here they probably been ****ted around by nissan too. Man my friend got same bullsht from nissan they wanted to make him pay for the rental car that was covered by the warranty. Until we went inside made alot of noise, infront of customers and oh wow somehow the manager was their. The guy looked like he was gonna **** his pants. Both me and my friend are 6'2 and this guy was like 5'6 looked like he was about to cry, man makeing alot of noise infront of customers when you're their always helps.
Old Oct 13, 2005 | 05:25 PM
Rob01ski
AHh screw it who cares blah blah blah yes i know im retarded THANK YOU
Old Oct 14, 2005 | 03:56 PM
not to mention banned.
i fix cars, and i dont or cant adjust the price based on age or race. only the amount of time in SLT manual. i dont care who pays for it either, warranty, third party or customer, i diagnose what the car needs, report the condition and provide an estimate if its CP or aftermarket warr.
im glad you can fabricate and base an argument on how you catch flak for your race, when you have NEVER been apart of another race, and have nothing to compare it to. i wont miss you... i dont think im alone.
another note... making noise will only have the conversation move to the svc managers office. where no one can hear you whine. besides, if you have a legitimate argument, theres no need to scream, and bystanders know this. unfotunantely the svc manager you were dealing with didnt, but im not going to be the one to make a broad generalization based on one incident.
autozone cant swap an engine in their parking lot... under warranty or otherwise, so if a dealer cant bring in enough business (yes, thats you) to stay afloat, they simply change makes, sell, or move. where ya gonna take your warranty work when your local nissan dealer changes to a chevy dealer?
its not about how the dealer screws you and whomever else you believe, its how to get the best out of your svc visit, which is one of the reasons this board is up.
i cant tell you how many times ive posted suggested labor times and part prices. /rant
the original question has been answered... but the o2 sensor is a 22mm. not too hard to swap. most new ones come with anti sieze already applied to the threads.
g/l
Old Oct 14, 2005 | 08:09 PM
Correct on the 22mm, my apologies. A 7/8" wrench might work for you though if you don't own a 22mm wrench (like me).
g/l
Old Oct 14, 2005 | 10:56 PM
nismo_star's Avatar
Typical lemming response. Oxygen sensors are covered 3/36, and possibly in bulletins issued by NNA in regards to reprogramming, as necessary for 8/80 so like the other lemmings on the board, lets get the "stuff" straight.
As for MAKE A LOT OF NOISE, "G T F O H."
People on the forums like you who are ignorant.
You'll probably be arrested or make a situation worse by doing that kinda childish action.
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Tmax78
Sep 25, 2015 09:07 PM
