Replacing O2 sensors HELP please
Here is the deal. I know that my rear Oxygen sensor is dead. So I jacked up the car got under it but can not find it where I expected it to be, on the cat. I have also located three other sensors which look very much like Oxygen sensors on my y-pipe closer to the manifold. I would really appreciate if you guys can explain me where I can find that REAR O2 sensor. The model is 2k SE California spec. max.
Heated O2 sensor might be problem. You will see it when you look at the engine bay behind the radiator fans. I believe its a blue wire. But It could be any of these problem areas as well : MAP sensor output / Injector / Fuel pressure / Intake air leaks /
I recently got a P0153 code - Sensor Circuit Slow Response (Bank 2 Sensor 1) on my maxima 2K. Can any of you tell me the corresponding part number for this particular sensor. I'm trying to get the part from partsamerica.com so that I can pick it up locally, but I can't figure out which particular part to buy at. the listing is at: http://www.partsamerica.com/ProductL...Sensor&ptset=C
Would certainly help me if someone could tell me the bosch part I need to buy.
http://forums.maxima.org/showthread....95#post3116895
P0153 = sensor 1, bank 2
Call a dealer, parts dept, and ask what p/n it corresponds to... That's what I did :-)
Thanks guys, it turned out that both rear sensors where dead and the reason to that was bad injectors. It feels like I bought a new car after cleaning my injectors and replacing the sensors.
i changed out my bank 1 o2 sensor on sunday, got a p0139 and p0138, the o2 on the cat is can be found for like 80 bux but the ones on the y-pipe are in the hundred range.
did your ses light come on, i have an 2000 GLE 77k miles on it i poured a fuel additive in when getting gas and a day or two later my lught came on and the mechanic is saying its the upstream bank 1 catalytic code coming up not sure which that is
Ask the mechanic for the exact code, then come back here and look up what sensor that would be... If you read through the FAQ, and stickies it will tell you where to find codes and troubleshooting tips...
I think the factory has a recall for the O2 sensors if they are triggering your check engine light. I got mine done for free after getting it done time after time at a repair shop and having the check engine light come back on every time.
mrc00l88
Jan 25, 2024 01:14 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
