Random Insane SR20 thought
Old Aug 22, 2005 | 07:22 AM
khynex's Avatar
i was randomly thinking this weekend and i know to turbo the 3.5 is a *****. But i was thinking if u could sorta fit a sr20det in our 5th gens which im sure we can cuz there not that big and also what tranny would be able to bolt-on to it... Would our stock tranny bolt on 2 the sr?
Old Aug 22, 2005 | 07:29 AM
NmexMAX's Avatar
dot dot dot ...
No ... No ... No...
Old Aug 22, 2005 | 07:43 AM
khynex's Avatar
lol it was wortht he random thought
d00df00d's Avatar
Old enuf to pick his own gears
Why is turboing the VQ35 so hard? How much power do you want to make?
Old Aug 22, 2005 | 07:45 AM
NmexMAX's Avatar
dot dot dot ...
Just because the sr2det has more aftermarket support, does't mean it'sbetter to turbo than the 3.5L.
Old Aug 22, 2005 | 07:46 AM
khynex's Avatar
im just saying this since that turbo 3.5 from ssr has been going on 4 awhile, i just got the idea of an sr20 in a max....i know the sr20's can hold on power. Ive seen some sick se-rs...i was jsut wondering if any1 ever thought of that
Old Aug 22, 2005 | 07:47 AM
khynex's Avatar
im not saying the sr20 is better or worse then a 3.5 im jsut saying what if
NmexMAX's Avatar
dot dot dot ...
Putting a sr20 into a Max would probably be harder than custom fitting a turbo on the 3.5L ...
Old Aug 22, 2005 | 07:48 AM
NmexMAX's Avatar
dot dot dot ...
I would rather have turbo'd 3.5L personally.
Old Aug 22, 2005 | 09:21 AM
SR20RACER's Avatar
Do it man. Viva SR20.
Old Aug 22, 2005 | 09:52 AM
d00df00d's Avatar
People think of it all the time. They also ask about it every 2 or 3 weeks here, and get the same answers:
1. It'd be too much effort for the power you'd get
2. The power curve would be worse
3. It's easier to make power with a VQ35
Old Aug 22, 2005 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
Small 4 cylinder + big heavy car = no good.
Old Aug 22, 2005 | 10:05 AM
Daily Driver2k2's Avatar
Question.....how deep are your pockets?
But for real , anything is possible.....the boys at Zfever in Tampa are putting a SR20DET in a 240Z. So i will have to say it is possible with creative modification. But in the end i am sure if you did get it to work , your S20DET 5th gen Max would probally be no faster than a stock 5th generation Max.It would be only worth it if you were going to build the SR20DET up.
Much cheeper to add a S/C and tune it properlly than the route you want to go.
Old Aug 22, 2005 | 10:08 AM
Jeff92se's Avatar
I'm needing a caw
And sr20det into a 2,000 lb car is much diff than a sr20det into a 3,500lb car. Especially when the 3,500lb car already makes more hp than the sr20det stock for stock.
Old Aug 22, 2005 | 10:12 AM
chr0nos's Avatar
yup. this kinda reminds me of gay **** sex. things going where they were never ment to be put.
i think it defeats the purpose, putting a 2.0L engine into a 3300lb car.
kinda like a 4 cyl camry.
the sr20 was meant to be in a much lighter car. the fact that its so powerful when modded is a big bonus for centra guys.
Old Aug 22, 2005 | 10:17 AM
Jeff92se's Avatar
I'm needing a caw
In the camry's defense, there IS a factory turbo that will drop right into it. So that swap is not really out of the question. Would be an interesting swap into an older 4 cylinder version. Especially the AWD 4 cyl na version. I don't think the older 4 cyl camrys weighed in at 3300lbs though.
Old Aug 22, 2005 | 10:22 AM
d00df00d's Avatar
Yikes, man... ease up...
Old Aug 22, 2005 | 11:41 AM
chr0nos's Avatar
heh yeah, sorry. i just felt this was an appropriate coparison.
i also have a 99 v6 camry, and its very similar to 4th gen maximas.
engine output is nearly identical, so is curb weight, etc. i really like the car for what it is. the 1mfze engine is awsome, by no means worse than 4th gen maxima engine. too bad the camry does not have too many v6/5spd cars out there, or strong aftermaket support. it would have been a formidable competitor to 4th gen guys.
Old Aug 22, 2005 | 02:30 PM
maxgangsta02's Avatar
how bout a VE+T that makes this much power and its not tuned yet!
http://www.sr20forum.com/showthread.php?t=127194
Old Aug 22, 2005 | 02:37 PM
Jeff92se's Avatar
I'm needing a caw
Can't really tell where the powerband is though. Yeah I could build a 1500cc F1 motor to make 2-3x that much power. Would I want it in a heavy chassis? Not really. 24lbs of boost?? Why not use 1/2 that boost and get the same numbers WITH torque in the low rpm range? But go ahead. It's not my car.
Old Aug 22, 2005 | 02:52 PM
im with you i wouldnt do it either, but the SR20 guys in fla are nuts!
Old Aug 22, 2005 | 10:33 PM
bonzelite's Avatar
SR20 is designed to rev really high under boost. it's perfect for racing applications. to put that into a 5th gen would be pretty insane. in a sort of retarded way. however, pondering it, and being that the 5th gen is FWD, you'd need to get the n/a FWD version, with tranny, of the SR20 out of the G20 Infinity, then turbo that.
then, once you have that, you have to mate up somehow the half-shafts of the G20 FWD drivetrain up to the Maxima. you would need to custom-fabricate a way to have the SR20 half-shafts work with the Maxima knuckles/ spindles. for that matter, you'd need to actually use the entire driveline/ hubs/ axles/ spindles of the G20 and put them onto the Maxima.
then you have a dilemma because the G20 is 4-lug. so, then, you'd have to do a 4 to 5 lug swap. and i don't really know how G20 guys do that swap, but i'm sure there are threads and forums out there about that.
THEN you must build up the SR20 in order for it be worthy of pulling the 4000lb 5th gen Maxima pig boat: you'd have to probably tear down the SR20, port it out, and put a stroker kit in it for the engine to even "matter."
you'd have to have at least a 20g size turbo, and that will necessitate upping the fuel injection to around 770cc. you'll need fuel rails for that, as well as a SX FPR type of setup with an SAFC. you'd have to basically set the car up as a pure race car for an SR platform to make any sense --with downpipe, FMIC, tranny cooler, oil cooler, bulletproof tranny gears, wiring harness, the list is endless. you'd spend $30k easily.
were it me, i'd take a G20 and just turbo that. you'd get more power with less modification. and you'd have one sweet ride. and the drivetrain and chassis would be perfectly balanced --true to "tuning."
Old Aug 23, 2005 | 04:47 AM
chr0nos's Avatar
2003 maxima se: Curb weight 3,220 lbs (from cars.com). this is with the 3.5l engine.
but i still think its silly to put a small engine like this into a max.
Old Aug 23, 2005 | 07:48 AM
d00df00d's Avatar
It's all about torque, guys. Jeff92se said it perfectly: smaller engines can make however much power you want, but they'll do it all with revs and it'll all be on the high end. Bigger, heavier cars need more progressive and linear power delivery.
Old Aug 23, 2005 | 07:50 AM
Ephraim's Avatar
bonzelite destroyed anyones hopes of putting in an SR20
Old Aug 23, 2005 | 07:58 AM
Jeff92se's Avatar
I'm needing a caw
Actually don't they make FWD SR20DETs? I see them in sentras etc.. all the time. The SR out of the Sunny GTI-r for instance.
Old Aug 23, 2005 | 09:57 AM
FWD de-Ts came out of the nissan bluebirds..the older altimas that we have in the states. the gtir came out of the 4wd PULSAR GTIR, that came with a gigger turbo(t28) 444cc inj, lower comp, and diff intake manifold and some other crap i cant recall...
Old Aug 23, 2005 | 10:05 AM
SPiG's Avatar
SomePsychoGuy
http://forums.maxima.org/showthread.php?t=421183
Wow what a random thought!!!
Yes they make FWD SR20DETs. They are in the GTi-Rs and in the Bluebird SSS ATESSA (AWD SR20DET 1st gen Altima).
Would it be worth the trouble in any way, shape or form? No
If you started with a smaller car with either an SR20DE or a less powerful engine then yes you might consider it. Doing it in a maxima would be stupid. I would rather do a VQ30DET swap in a 240SX or an old Z or something that would actually be fast.
Old Aug 23, 2005 | 10:28 AM
bonzelite's Avatar
chronos --"2003 maxima se: Curb weight 3,220 lbs (from cars.com). this is with the 3.5l engine. but i still think its silly to put a small engine like this into a max."
yes. the max is still too heavy for a high revving, short-stroked engine like the SR20DET. it is true, though, that shorter-stroked engines can potentially produce HIGHER peak HP than longer-stroked ones, but sacrifice low-end torque in the process. and you would want good low-end torque on demand to pull that 5th gen ahead quickly.
dood --"It's all about torque, guys. Jeff92se said it perfectly: smaller engines can make however much power you want, but they'll do it all with revs and it'll all be on the high end. Bigger, heavier cars need more progressive and linear power delivery."
-correct --what i elaborated on above. the SR20 is about high revs, as i said. as this is often the crux of the "KA v SR" debate, ie, why some opt to turbo the KA, as it makes more torque = fun.
jeff --"Actually don't they make FWD SR20DETs? I see them in sentras etc.. all the time. The SR out of the Sunny GTI-r for instance."
no USDM SR20DE, GA16DE, or QR25DE (SE-R) Sentra ever came with turbo. but, jeff, you are correct about the GTI-r. regardless, whomever still wants the SR20 in the 5th gen, i would simply forget it.
here are the nissan engines' HP and torque ratings for comparison:
GA16E - 110hp, 108tq
GA16DE - 115hp, 108tq
SR20DE(USDM) - 140hp, 132tq
SR20DE(JDM) - 150hp, 132tq
SR20DET - 205hp, 190tq
SR20DET GTi-R - 230hp, 205tq
SR20VE(1998-2000) - 187hp, 154tq
SR20VE 20v(2001+) - 205hp, 160tq
SR20VET - 280hp, 230tq
SR16VE - 175hp, 116tq
SR16VE N1 - 197hp, 125tq
QR25DE(Spec-V) - 175hp, 180tq
KA24DE(240SX) - 155hp, 160tq
VG30E(198?-94 Maxima) - 160hp, 180tq
VE30DE(1992-94 Max SE) - 190hp, 180tq
VG30DE(300zx na) - 222hp, 198tq
VG30DETT(300ZXTT) - 300hp, 283tq
VQ30DE(1995-99 Max) - 190hp, 205tq
VQ35DE(2000-01 Max) - 222hp, 217tq
VQ35DE(02-03 Max) - 255hp, 246tq
VQ35DE(350&G35) - 287hp, 274tq
VQ35DE(350&G35) - 298hp, 260hp
VH45DE(91-96 Q45) - 278hp, 292tq
VH41DE(97-01 Q45) - 266hp, 278tq
VK45DE(2002+ Q45/M45) - 340hp, 333tq
RB25DET - 300hp, 295tq
RB26DETT - 320hp, 300tq
Old Aug 23, 2005 | 10:37 AM
Jeff92se's Avatar
I'm needing a caw
He was mentioning the DET version. Which you can get from Japan that were in FWD configuration. But the title of the thread mentions only SR20. Sort of confusing. But we will assume he ultimately means sr20det.
Old Aug 23, 2005 | 10:42 AM
AcerX's Avatar
[QUOTE=bonzelite]chronos --"2003 maxima se: Curb weight 3,220 lbs (from cars.com). this is with the 3.5l engine. but i still think its silly to put a small engine like this into a max."
00-01's are VQ30DE
(not sure but I read somewhere that our torque was 212 instead of 217?!)
Old Aug 23, 2005 | 10:44 AM
bonzelite's Avatar
sure. SR20DET. it is confusing.
but regardless, a stock SR20DET is too torque-weak. even the mighty GTI-r with 205 lb/ft of torque is a step down. you'd have to build up that engine.
and the other factors for the swap, like wiring, and engine mounting, and axles, is just a wall of discouragement. unless you're Jay Leno.
Old Aug 23, 2005 | 10:47 AM
bonzelite's Avatar
[QUOTE=AcerX]
00-01's are VQ30DE
thanks for that correction. my bad.
still doesn't make an argument for the SR.
Old Aug 24, 2005 | 06:46 AM
SR20RACER's Avatar
They never made a FWD DET. They were AWD.
Old Aug 24, 2005 | 08:51 AM
SPiG's Avatar
SomePsychoGuy
Yes but they were transverse and could easily be mounted in a FWD configuration with a normal SR20DE US 5 spd tranny.
Bottom line:
Is it possible? Yes
Would it be worth it? No
An RB swap would be a different story.
Swapping anything besides a VQ into something that has a VQ in it stock is stupid. The SR has a lot of aftermarket support, but you would have to take full advantage of it just to get it to a comparable modded VQ. Any other discussion about this has probably already been covered in at least the thread I posted earlier if not in 10 other threads about swapping some other engine into a maxima that doesn't belong there.
Old Aug 24, 2005 | 05:20 PM
MaximaPolak's Avatar
It's been done for the 350Z so it can have more ummph to drift. It was a silver one with red things on it.
For the Maxima, it is very pointless unless you like going slower.
Old Aug 25, 2005 | 01:01 PM
Mass_Media's Avatar
Mass_Media™
Keep the 3.5....put a turbo on it...I bet it would be the same price....sr20 in a max=
Old Aug 25, 2005 | 01:11 PM
Derrick2k2SE's Avatar
Why not yank the 3.5 and put in a 3.0 from an 00 or 01 Maxima. It would be an easy swap and there are several forced induction options for the 3.0. You could probobly find someone in the All Motor forum who would do the swap just for the motor.
Old Aug 25, 2005 | 02:00 PM
DesiGLE's Avatar
The Boy Wonder
how bout an M45 engine in a 5.5 gen lol jk
I have a 4 cyl camry, and I hate damn near everything about it from handling, engine response, acceleration, braking, the interior etc.(i only like mileage and reliability)
Old Aug 25, 2005 | 03:27 PM
bonzelite's Avatar
now that is underpowered. wow. 4cyl in a camry? i bet the sticker price was pretty low, though. you can always think of turboing it.
