Progressive RSB-How To?
Old Aug 28, 2005 | 11:21 AM
skinyc15's Avatar
Progress RSB-How To?
Looked all around for the Progress RSB_ How to? Can anybody help.
Thanks..
skinyc15
Old Aug 28, 2005 | 11:51 AM
goldmaxNYC's Avatar
Originally Posted by skinyc15
Looked all around for the Progreesive RSB_ How to? Can anybody help.
Thanks..
skinyc15
for one thing its Progress .. isnt it?
Old Aug 28, 2005 | 11:55 AM
skinyc15's Avatar
woops yea..
Old Aug 28, 2005 | 07:30 PM
Puppetmaster's Avatar
What do ya need to know? 2 brackets go on the beam, as far apart as possible, and then 2 on the trailing arms (1 each side). You'll have to pull out the stock brackets that are there that hold the ABS lines and just ziptie the lines to the trailing arm AFTER you bolt the clamps.
This isn't for a Progress RSB, but its close enough:
http://www.moodym.com/maxima/tech/addcorsb.html
Let us know if ya have specific questions about the install...
Old Aug 28, 2005 | 07:49 PM
SEmy2K2go's Avatar
Go BUCKS!!!
with that write-up. Also as Puppet mentioned, you will need to remove the ABS brackets.
Old Aug 29, 2005 | 05:22 AM
ICULookN's Avatar
You don't have to remove the brackets necassarily. After hearing about the brackets rubbing against the brakelines, I bought some clear tubing from lowes and cut it down the middle and put it around the brake lines to prevent it from rubbing. So far, so good.
Old Aug 29, 2005 | 05:38 AM
SEmy2K2go's Avatar
Go BUCKS!!!
It also depends on which position you actually mount the RSB brackets. For some applications, the ABS brackets are in need of being removed to allow clearance for the RSB brackets themselves.
Old Aug 29, 2005 | 06:02 AM
juniper9803's Avatar
Just Remove And Use Tie Straps
Old Aug 29, 2005 | 11:46 AM
skinyc15's Avatar
Thanks for the help now I have a starting point. I lost the original "how to" from Progress.
Maxima_Joe
Nov 25, 2015 08:19 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Stagnet04
Sep 13, 2015 09:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
