ATTN 6 Speeders...CLUTCH BLEED is AMAZING
Old Sep 5, 2005 | 09:01 AM
jeepik's Avatar
ok here is the story, my clutch has always been a POS to get used to, then last week the pedal went all the way to the floor,
i decided to bleed the clutch this morning, and let me tell you..
first of all this takes at the most 10 minutes with the right tools, and second i had a lot of air bubbles in my clutch lines
i only bled the lines this time, i did not bleed the booster on the clutch itself, thats next
ITS pure amazing, like a whole new car, clutch engages effortlessly, no jerking no notchiness...
i would reccomend that all of you do this, it'l make you love your car once again
Old Sep 5, 2005 | 05:20 PM
00SEMAX19's Avatar
Your car should of always felt the way it does now. Either you had a repair done on the clutch and they didn't bleed it out properly or you have either a bad clutch master, slave cylinder or a loose fitting somewhere. If problem isn't fixed your clutch pedal will soon feel like **** again
Old Sep 5, 2005 | 07:50 PM
BewstAdd1ct's Avatar
was the fluid low? i suppose you could just get small amounts of air in over time, though it might be a rare thing... either that or fluid was leaking out, which the level would be low.
Old Sep 5, 2005 | 07:51 PM
JohnnyJet's Avatar
Mines is like butter........better than my vette
Old Sep 5, 2005 | 08:01 PM
steven88's Avatar
Need A Light?
Yup mine goes in smoothly after I added the stainless steel clutch line....adding new fluid and bleeding does help...
spazma7ik
Jan 12, 2017 09:38 PM
mikeg75
Nov 30, 2015 05:12 PM
MannyMonroe
Sep 24, 2015 08:45 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
