Anyone with 2k1 maf in a 5.5gen run rich?
Old Sep 6, 2005 | 05:10 PM
BumpnMaxima's Avatar
The amf in mny 02 went bad so i chaged it with the updated 2k1 and added the iat from my 02. the car smells liek its running rich now and i get a bit of smoke on initial start. i reset the ecu when i installed the new maf, but do i need to get it reprogrammed?
Old Sep 6, 2005 | 07:51 PM
BewstAdd1ct's Avatar
i didnt do mine, but its suggested. mine doesnt seem to be rich, and startup maps are fixed fueling and timing.
have you taken an a/f measurement?
Old Sep 6, 2005 | 07:59 PM
OOmaxSE's Avatar
what are the symtoms of having a car run rich? i have a 2k1 in my 00.
Old Sep 6, 2005 | 08:14 PM
generally poorer throttle response, poor fuel mileage, black smoke from exhaust, fouled plugs, over time... saturated crankcase excessive carbon buildup, catalyst failure, etc... ck engine light if it gets bad enough.
Old Sep 6, 2005 | 09:52 PM
im thinking maybe my Apexi safc is ****ed up. i might lean it out a bit and see if it makes a diffrence. its set to stock now. anyone have an idea baout what percentage to lean it out by?
Old Sep 7, 2005 | 03:22 PM
lololol... you have an afc.
thats probably the problem, especially if you were tuning it to a failing MAF. if you were attempting to compensate, or doing so unknowingly for a lean condition, then a proper maf with that same adjustment would have you running a little rich
Old Sep 7, 2005 | 08:48 PM
MaxBoost925's Avatar
Drug Money
CRAP. I had a blown 2K MAF in my 2K (sprayed throttle body cleaner on it [don't ask]) it was running really rich (black smoke out the exhaust and it smelled like gas) but when I replaced it with a new MAF (2K1, it was ok). I think your MAF is screwed up
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
AT978
Sep 6, 2015 10:31 PM
