g35 wheels
Old Sep 7, 2005 | 05:28 PM
maximus2k2's Avatar
g35 wheels
anyone know if G35 coupe rims will fit on 2002 maxima??
Old Sep 7, 2005 | 05:29 PM
NYPD-Arnold's Avatar
Z
They will.
Old Sep 7, 2005 | 05:31 PM
maximus2k2's Avatar
the G35 is a rear wheel drive tho?
Old Sep 7, 2005 | 05:34 PM
bugbite77's Avatar
yes they will they are the same off set at the 350Z and my sig will do the rest of the talking, just get 225/45/R18 as tires and you will never rub, check out my cardomain site
Old Sep 7, 2005 | 05:40 PM
irish44j's Avatar
retired moderator
read, and be educated:
http://forums.maxima.org/showthread.php?t=422495
Old Sep 7, 2005 | 05:43 PM
cutter's Avatar
Is there anywhere to purchase the rims. I know ebay, but it is all replica rims. I want brand new rims, with no road rash. Do I just have to wait and get lucky?
irish44j's Avatar
retired moderator
by the way, 235/40/18 is more in spec for stock diameter and a 8" wide wheel (which the G35 18's are)....
225 would look TOO narrow on this wheel IMHO. I have 235/40/18.....which sits perfectly with the rim lip....
Old Sep 7, 2005 | 05:45 PM
bugbite77's Avatar
these 350Z rims fell into my lap for $100, they were a little curbed up and i had my fiends autobody shop reweld the lips and paint them, for only $350, u just gta wait for it to fall in your lap
Old Sep 7, 2005 | 05:46 PM
maximus2k2's Avatar
Thanks for all the info... gonna pick up some rims tomorrow...
Old Sep 7, 2005 | 05:47 PM
Z
Get the eBay ones, IMO. Same quality, same building plant, same manufactured specs. My TE rims are from eBay, the only difference is the seller applies their own color, so my TE rims are actually shinnier than OEM (which is a HUGE plus; they look so f-ing beautiful in motion). I weighed my OEM 17s with the TEs I got from eBay and they weighed in within .4lbs of each other.
Old Sep 7, 2005 | 06:39 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I'm looking for the same wheels....need to replace my 01 SE ones.....
Old Sep 7, 2005 | 06:50 PM
OOmaxSE's Avatar
there are a couple of differences with the OE G35 wheels and the replica ebay ones.
1) the offset for OE is +30mm and ebay's are +35mm i believe.
2) width of OE is 8.0 in and ebay's are 7.5 in.
Old Sep 7, 2005 | 07:14 PM
irish44j's Avatar
retired moderator
That is for the 18's....he is asking about the sedan 17's
The G35 SEDAN 17's stock are 17x7 with 40mm offset
The G35 COUPE 17's stock are 17x7.5 and 17x8(r) with 30mm and 33mm offset (a bit "deeper dish" than the sedan 17's)
The G35 COUPE 18's stock are 18x8 with 30mm offset
The EBAY G35 COUPE 18's are 18x7.5 with 35mm offset...
Old Sep 7, 2005 | 07:19 PM
Z
Josh, need your zip code, dude.
Old Sep 7, 2005 | 07:22 PM
cutter's Avatar
I really want the OEM 18" G35 coupe rims. Will the 19" fits on our max's?
Old Sep 7, 2005 | 07:37 PM
Puppetmaster's Avatar
I'm sure they will, since I assume the bolt pattern is the same, but you'd probably have to get different tires... the rears are 245/40/19 and may rub... most people have 245/35/19 (19x8.5) or 235/35/19 (19x8) tires I believe...
Old Sep 7, 2005 | 08:00 PM
cutter's Avatar
Do you guys recommend a drop with the G35 rims or will they look fine with the stock suspension?
Old Sep 7, 2005 | 08:03 PM
Z
Drop. The gap will look even worse.
Old Sep 7, 2005 | 08:04 PM
irish44j's Avatar
retired moderator
a good rule of thumb is that the bigger your rims are, the bigger your wheel gap will "look" (it's a visual illusion of sorts)...
but yes, I would suggest at least a mild drop (Maxspeeds or H&Rs)...
Old Sep 7, 2005 | 08:05 PM
It depends on how big of a wheel gap you want... if you want the 10 finger wheel gap and 4x4 look, then leave it... if you want a smaller gap, then drop it. 18s have less rubber and will "increase" the wheel gap.
Old Sep 7, 2005 | 08:10 PM
MaxEvil6speed's Avatar
G35 rims should fit across the board, but i just found a set on Ebay...and DA*N they are PRICEY!!
only 11 more posts till i can make a thread
Old Sep 7, 2005 | 08:12 PM
cutter's Avatar
Link? I found a couple on ebay and one or two of the rims are all curbed up and I want them MINT, with little to no curb rash.
Old Sep 7, 2005 | 08:13 PM
irish44j's Avatar
retired moderator
PEOPLE!!!
read this thread and you will have the answer to your questions, including EVERYTHING that is known about the real and ebay G35 rims, as well as where you can buy them (besides ebay)
Old Sep 7, 2005 | 08:14 PM
PEOPLE!!!
x 92835760286020.1
irish44j's Avatar
retired moderator
by the way MaxEvil6speed, what the hell is going on with that clusterfuk over
< there
under your name. You don't need to list all of your car's options there
Old Sep 7, 2005 | 08:16 PM
cutter's Avatar
Yea I have read that thread, sorry, but I thought since this dude asked some questions I mine as well ask some instead of creating a new thread. Since I couldn't find that G35 rim thread.
Old Sep 7, 2005 | 08:19 PM
irish44j's Avatar
retired moderator
it's a sticky thread at the top of the wheels/tires forum
Old Sep 7, 2005 | 08:25 PM
And here it is one more time for those of ya who missed it several posts up:
Old Sep 7, 2005 | 08:32 PM
MaxBoost925's Avatar
Drug Money
I want some G35 wheels too. I have the OEM 17" 2000 SE wheels. Why will the tires on the 18's rub?
Old Sep 7, 2005 | 08:35 PM
irish44j's Avatar
retired moderator
Well, let's think about this for a second.....why in the world would the tires rub? hmmm.....could it be that they are too big?
the stock rear tires that come with the G35 coupe are 245/45/18, which are quite a bit larger in diameter than the size that the maxima should use with those wheels, 235/40/18. They will rub if you use the G35 tires on them, not if you get the correct size.
Old Sep 7, 2005 | 08:45 PM
Lumbee1's Avatar
They will not fit. The offset is wrong and the bolt pattern is different. I was able to hammer some on and they rubbed the inside and outside of the fender. They also make horrible noises at speeds above 42mph.
Old Sep 7, 2005 | 08:47 PM
irish44j's Avatar
retired moderator
you were the OG with the G 18's.....then there were just a few of us. Now everyone wants them
Old Sep 7, 2005 | 08:51 PM
I don't... the G35C rims are turning into the new MM Evo 5/Allesio F1...
Old Sep 7, 2005 | 08:52 PM
irish44j's Avatar
retired moderator
BITE YOUR TONGUE!!!
Old Sep 7, 2005 | 08:54 PM
BITE YOUR TONGUE!!!
Isn't this past your bedtime, old working man?
Btw, I didn't say I didn't like em rims, they're just becoming too common....
Old Sep 7, 2005 | 09:00 PM
Talyan03's Avatar
get 245/40/18
Old Sep 7, 2005 | 09:03 PM
cutter's Avatar
Hey irish how is the ride with your maxspeeds and illuminas? My friend has a riced out civic with a drop and I hate his ride, I like the stock ride. Are these as close to the stock ride you can get? thanks.
Old Sep 7, 2005 | 09:10 PM
Yes, they are.
http://www.innerbean.com/housecor/sp..._decision.html
Old Sep 7, 2005 | 09:22 PM
cutter's Avatar
damn, sorry guys. I have been on housecors site a lot before and never saw that before. Maybe it was because I wasn't looking for that. Sorry for the hassle I know how annoying it is.
Old Sep 8, 2005 | 06:37 AM
2K3MAX2NV's Avatar
&quot;tse-tse fly&quot;
ALL HAIL PUPPETMASTER and IRISH44j without them the org would be a 16 year old virgin
