Cattman Coilovers?
Old Sep 16, 2005 | 11:39 PM
NiZMo1o1's Avatar
Cattman Coilovers?
Does anyone have the Cattman coilovers?
Ever since I put them in theres a Creeking sound when I turn the wheel to the Right .. its comming from the Passenger side. I cant figure out what to do.. I feel like WD-40 the whole stupid suspension.
My parents just Came to visit from England and Dads Bishing about how its making noise.. gee im still getting bish at age 28... the noise is getting annoying now...
Anyone have some suggestion ? Thanks in advance.
Old Sep 17, 2005 | 12:15 AM
NYPD-Arnold's Avatar
Z
Check:
Bearings
CV Boot/Joint
Axle rod
Make sure that the axle rod is tight. You can check this by lifting the car and seeing if the front wheels will move around if you push on them in and out.
Old Sep 17, 2005 | 09:29 AM
NiZMo1o1's Avatar
^^ above Ive already just replace the whole suspension.. the noise seems more from the coilovers itself...im thinking the pillow mount needs a rubber thingy
Old Sep 17, 2005 | 09:54 AM
Z
Well you said it makes a noise when you turn to the right and that's a symptom of what happens when the aforementioned three issues are screwy. Coilovers don't replace CV Boots or Axle rods or even bearings (as far as I know)...so again, I suggest you have those three checked out.
I had that same creaking noise too.
Old Sep 17, 2005 | 08:55 PM
Deac's Avatar
Normal
What set of coilovers do you know of that DONT creak? I have the Cattman Gen 2 coilovers and they creak & ping like crazy.... I heard that his lastest version of coilovers were supposed to be alot quieter but.... for the most part with any brand of coilover.... they are noisy dude.... get used to it.
Deac
Old Sep 17, 2005 | 10:10 PM
NiZMo1o1's Avatar
^^ really I did not know that Cattman makes differnt version .. Gen 2 I suppose is to make it sound better because of the problems the 1st one had?
im not even sure which gen I have but it does comes with the Camber looking thing and AGX adjustables
This is acutally my 1st set of Coilovers Ive ever own on any car.I just WD - 40 the hell out of it this moring and it seems to stop for now..Thanks Tho... And Thanks NYPD .. I forgot to mention that I had all those other things replace./
Old Sep 18, 2005 | 11:11 AM
upstatemax's Avatar
Originally Posted by PRO - 1
.I just WD - 40 the hell out of it this moring and it seems to stop for now.../
I would try something other than WD-40, its really best used as a de-greaser, to break loose bolts and cleaner.... thats why you are not supposed to use it on things like bike chains.
I would use actual grease, take them appart, grease the hell out of them and put it back tegeather.
KabirUTA13
19
Oct 17, 2015 02:15 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
Chaka
Sep 17, 2015 09:53 AM
