Cruise Control
Old Sep 19, 2005 | 10:44 PM
darrick04's Avatar
Cruise Control
I was traveling down the interstate where I use the cruise control quite a bit and as I went thru the motions, I discovered my "Cruise" light comes on but not the "Set" light... It has stopped working. How would I get the cruise control to work again? Is it a wiring/fuse or some electrical issue or what does anyone think the solution could be...?
Old Sep 20, 2005 | 07:21 AM
foodmanry's Avatar
Da Roller Coaster!
How fast were you going? If you were going over 90MPH cruise control will not engane. I think the actual MPH is 92 or 93...but if you were going over that the car won't let you use it.
Old Sep 20, 2005 | 03:21 PM
cmoore135's Avatar
i have the same problem. it happened when i installed ce angel eye projectors.
Old Sep 20, 2005 | 04:01 PM
jimmycapp's Avatar
89mph.....
Old Sep 20, 2005 | 04:09 PM
AcerX's Avatar
I still can't get my cruise control to set either, probably shouldn't matter to me anyway since I probably have one of the more 'leaded' feet on the forum.
I forgot, I remember reading somewhere that on some cars (big help right ) that the cruise won't engage if the overdrive is on due to the fact that the computer isn't programmed to operate the cruise at those constantly higher rpms.
Old Sep 20, 2005 | 08:52 PM
darrick04's Avatar
In the range of 45 to 70mph, it worked once today on the way to work, turned off the car to go in to work and on the way home tried to set it in a speed trap area and once again, didn't work... Is there some kind of misread in the computer or what? or is there a fuse that may need to be changed?
Old Sep 20, 2005 | 09:16 PM
LA02MAX's Avatar
check down by your clutch pedal if you're a standard and there is a button that senses if the clutch pedal is depressed or not thereby cancelling the cruise if it ever is depressed...either your clutch travel is adjusted to the wrong point, or this button is broken...or if you are an auto, there is a button behind the brake pedal rather than the clutch pedal (since you dont have one, of course)
Old Sep 21, 2005 | 04:35 AM
jimmycapp's Avatar
Originally Posted by AcerX
forgot, I remember reading somewhere that on some cars (big help right ) that the cruise won't engage if the overdrive is off due to the fact that the computer isn't programmed to operate the cruise at those constantly higher rpms.
I know mine will work in second at pretty high rpm's.
Though I have a 6MT
Old Sep 21, 2005 | 02:44 PM
darrick04's Avatar
ok so randomly, i have tried using cruise control every time i have turned the car off/on and it has worked every time... i am hoping it was some kind of temporary issue that has since been worked out. thanks for the replies
Old Sep 21, 2005 | 06:40 PM
Fezzik's Avatar
Mine wont kick on beyond 3000 rpms when i was in 6th gear
Old Sep 22, 2005 | 03:03 PM
BewstAdd1ct's Avatar
which would be 89 mph...
darrick, the next time it doesnt work, make sure your foot is completely off the clutch/brake pedal, and if it still doesnt work, put your foot behind the pedal and lift the pedal lightly and try again.
Old Sep 22, 2005 | 08:52 PM
darrick04's Avatar
thanks cuz it didnt work again, but if it fails tomorrow or thereafter i will apply what u said...
Old Sep 24, 2005 | 03:11 PM
cmoore135's Avatar
well itried mine for the first time in awhile. i turned it on and tried to set it but no go. it did flash set for awhile after a few minutes. don't now why
Old Sep 24, 2005 | 08:44 PM
darrick04's Avatar
i did the same thing, it flashes but nothing works, oh well, i guess i will just have to drive w/out cruise
Old Sep 25, 2005 | 07:55 AM
BG's Avatar
BG
I have the exact same problem. It is extremely intermitten, but every couple weeks I won't be able to set the cruise. The cruise light stays on and the set light flashes with me. I have tried several things, but the only cure seems to be stopping the car and turning it off for a few seconds and restarting it.
Old Sep 25, 2005 | 12:03 PM
darrick04's Avatar
Yeah same here and doing all that can get extremely inconvenient especially when you are in heavy traffic flow.. You don't want to have to pull over, turn the car off, wait a few seconds, then start it back up!!! If more than just two or three people have had or are having this problem then obviously there is a glitch in the system... Wished I knew how to permanently fix it though
Old Sep 28, 2005 | 10:50 PM
darrick04's Avatar
cruise control hasn't been working the last few times i have tried to engage it, and i tried the whole lifting from behind the brake petal slighlty and it didn't help... what else is next w/out consulting a dealership
Old Sep 29, 2005 | 04:43 AM
BG's Avatar
BG
Originally Posted by darrick04
cruise control hasn't been working the last few times i have tried to engage it, and i tried the whole lifting from behind the brake petal slighlty and it didn't help... what else is next w/out consulting a deealership
Thats the problem... the problem is so intermitten that a dealership would never acknowledge it. Plus the amount of time it would take to track it down. How would you ever know that you had fixed the problem?
Old Sep 29, 2005 | 06:14 PM
this is true...
i was looking through the svc manual for a self-test procedure but couldnt find one.
that reminds me of something, though...
how many times does the set light blink, guys?
Old Sep 29, 2005 | 08:50 PM
darrick04's Avatar
it doesnt stop, it annoys me so i always just canel and thats when it stops... so what does that mean
Old Sep 30, 2005 | 04:44 PM
dunno... i was hoping that it might blink out a code... then i can go for a drive, and apply brake pedal or clutch switch while engaging the cruise and see if they blink different for different 'faults'
hmm.
Old Sep 30, 2005 | 06:12 PM
cmoore135's Avatar
mine is a constant problem. i can't set it at all.
Old Sep 30, 2005 | 10:26 PM
darrick04's Avatar
so the question remains... what do the ones who are experiencing this issue do? consulting a dealer being the last option, what are the other choices we have? i just want mine to work because i travel long distances on the highway and i need to keep my lead foot off the pedal... anyone who has any links, advice, knowledge about this subject please let us know
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
