Manual tranny….oil…
Old Sep 27, 2005 | 04:36 PM
DrKlop's Avatar
Driving is the next best thing
Manual tranny….oil…
I am changing manual tranny oil in my car. Neither, me nor my mechanic do not know how to drain the fluid. Stealership wants $128 for that. I’d appreciate if someone can explain how it can be done. Maybe I’m blind but I cant find this info in stickies
Also is there any other lubricant that could be used? How much better is it? Do I have to flush it or I can just drain it and fill it up?
Old Sep 27, 2005 | 05:13 PM
southeast_first's Avatar
http://forums.maxima.org/showpost.ph...82&postcount=1
http://www.greghome.com/Greg's%20Garage/2002MaxSE/MT-90.htm
if your mechanic doesn't know how to change your gear oil, get a new mechanic.
Old Sep 27, 2005 | 06:17 PM
DrKlop's Avatar
thanks, seems like that's all I need
Old Sep 27, 2005 | 06:27 PM
Champ2433's Avatar
The drain plug in your car is actually partially blocked by the shifter linkages. It's towards the back(rear) of the tranny on the right side looking up a it.
Old Sep 28, 2005 | 09:26 PM
nytrida's Avatar
Your mechanic doesn't know how to put new fluid in the tranny? That's quite weird, there are only two plugs on the tranny, drain and fill. What does he do on your car? Just engine oil changes?
Old Sep 29, 2005 | 12:31 PM
nicks79's Avatar
I thought linkage was on the left.. anyways..
I have a question.. about to change the clutch..
What oil do you guys use: Redline MT-90 or MTL...????
Old Sep 29, 2005 | 01:13 PM
nicks79's Avatar
Come on guys.. Dissy or Missy??? MT-90 or MTL..>>
Can't find anything about these 2 in particular. Everyone says to use Redline..
Old Sep 29, 2005 | 01:22 PM
Bobo's Avatar
Go with straight dino gear oil and make sure its GL4, not GL5 or a GL4/5 blend, or you'll ruin your transmission bushings. Use 80w90 or 75w90. I got mine replaced in February at Mr. Lube and it cost less than an oil change. I wouldn't bother replacing it myself or paying a mechanic for what it costs at a lube joint. I think the jury is out on using Redline gear oil. I question the benefit of using synthetic gear oil in a manual transmission.
Old Sep 29, 2005 | 01:29 PM
nicks79's Avatar
Could you be specific what is Dino gear oil? I can't find anything around here that is GL-4 except for Redline.
Dave B told me that some stealers have this non synthetic oil for tranny, specifically for 5speeds.
But since I will have to do it myself, I need to buy it in quarts.
Old Sep 29, 2005 | 01:40 PM
samsonite's Avatar
I just changed mine with 80-90 gl4 from o'riley and it shifts awesome. It feels much much smoother than before. Im pretty sure it had gl-5 in it. I had to replace a cv seal so i figured i would drain it all (via gear sensor) and change it. The gl4 is super cheap too. I bought a gallon and 1 quart for about 15 bucks. Can't beat it. Good luck.
Old Sep 29, 2005 | 01:50 PM
Bobo's Avatar
By dino gear oil I mean just regular gear oil. Don't bother with synthetic. However, you MUST use GL4. Go to a lube joint as they will have it. I couldn't be bothered changing it myself. I paid Cdn$34.19 including all taxes at Mr. Lube. For US$25 to $30 why be bothered with the mess and disposal problem.
Old Sep 29, 2005 | 04:27 PM
DrKlop's Avatar
Those write-ups suggest to tighten the plugs to the specific amount of torque. Does it mean that I have to use the torque wrench to do that?
Old Sep 29, 2005 | 04:31 PM
Bobo's Avatar
How else would you know the specific amount of torque? Having fun yet?
Old Sep 29, 2005 | 05:46 PM
DrKlop's Avatar
nah, I haven't started yet lol, but really what's ganna happen if I just tighen them using standard wrench just like when changing engine oil?
Old Sep 29, 2005 | 05:57 PM
you're supposed to tighten the oil drain plug to a specific torque, too :-)
you need a torque wrench, or access to one, to work on your car. period. in a lot of cases, as long as you're close, it won't make a huge difference, but don't risk it. just do it right the first time.
Old Sep 29, 2005 | 06:09 PM
DrKlop's Avatar
what, never heard that someone would use a torque wrench to tighent engine oid drain plug.
Old Sep 29, 2005 | 06:15 PM
fsm says 22-29 ft-lbs... probably to keep from crushing the drain plug washer. or if you go really crazy, the oil pan itself :-0
Old Sep 29, 2005 | 06:44 PM
BewstAdd1ct's Avatar
the only cars i used a torque wrench on the oil drain plug and filter were Porsches...
labor time to change trans fluid is 0.5hrs. they were quoting you for a transmission flush, for an auto tranny. what dealer was this, and who did you speak to. im in a fcck'd up mood right now
time to have some fun.
Old Sep 29, 2005 | 07:06 PM
DrKlop's Avatar
how much do you think it should be? It's Staten Island Nissan. The girl was like "just a sec" and then she comes back and tells me that it's $128 it's a manual tranny though.
btw:I PMed you on some different topic just now, thought you might have not noticed that you got a new pm lol
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
