Is it normal for the gas mileage display to be too high?
Old Sep 28, 2005 | 07:37 AM
bkucera's Avatar
When I bought the car a month ago, the gas mileage readout said 17 mpg. I figured that was because it had been test driven a lot lately, and test drives are probably bad for gas mileage.
I was right, it steadily climbed as I drove the car. By the time I refilled the tank, it was reading 23MPG. Cool! Except by my calculations I only got 20MPG. Now, the second time I filled the tank, it reads 25.3MPG, and I actually still only got 20MPG.
What gives? Also, anything I should do to improve gas mileage besides keeping the tires to the correct pressure and a clean air filter? I'm going to check both of those after work tonight. Car has around 39,000 miles.
Old Sep 28, 2005 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
That trip computer is as innacurate as the tachometer.
Use real world measuring devices, i.e the pump readout and a calculator.
TXT-1's Avatar
Biggest thing for immediate improvement in MPG is go easy on the pedal. And yea, that trip computer is always way too optomistic. Nothing is wrong with your car, it's normal.
Old Sep 28, 2005 | 08:05 AM
MaximaPolak's Avatar
Why is the TacoMeter not accurate?
Old Sep 28, 2005 | 08:23 AM
NmexMAX's Avatar
dot dot dot ...
As a Great Wizard once said "They're calibrated by third graders"
Old Sep 28, 2005 | 08:26 AM
E55AMG2's Avatar
Wat
The tachs can be anywhere from 200 to 600 rpm too fast depending on whether you got the class clown or the valedictorian. The fuel computer in the car is hopelessly inaccurate because it only samples once every 30 seconds.
Old Sep 28, 2005 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by E55AMG2
The tachs can be anywhere from 200 to 600 rpm too fast depending on whether you got the class clown or the valedictorian. .
For teh win
Old Sep 28, 2005 | 08:35 AM
jimmycapp's Avatar
Does anyone know how our computer actually calculates the mileage? I know in my old jetta, it used the injector pulses to calculate it. I didn't feel it was very accurate either.
James
Old Sep 28, 2005 | 08:41 AM
AcerX's Avatar
To be honest with you I don't think it calculates anything at all with the way ours "works". Think of it more as an electronic lotto spinner that just randomly draws 1 of 5 pre-programmed numbers.
Old Sep 28, 2005 | 08:44 AM
E55AMG2's Avatar
Wat
IIRC it is the injector pulses.....but sampled once every 30 sec. Almost as accurate as a blind man telling time by the sun.
Old Sep 28, 2005 | 09:20 AM
myMAXse's Avatar
mine also displays about 2 mpg higher than actual.
Old Sep 28, 2005 | 09:26 PM
Derrick2k2SE's Avatar
Mine is about 2 or 3 MPG optimistic. If your car is a manual you can cruise a very low RPM in city driving. The 3.5 doesn't seem to mind staying well below 2000 RPM as long as no strong acceleration is required. I've improved my milege that way. I could never get away with that in my old Hondas.
Old Sep 29, 2005 | 07:10 PM
MaxBoost925's Avatar
Drug Money
How come I don't have a gas gauge?
Old Sep 29, 2005 | 07:22 PM
TXT-1's Avatar
Didn't start until 02 models
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
