eibach and tociko blues work or will blow the shoks? or oem spings with blues?
Old Oct 4, 2005 | 05:27 PM
super6's Avatar
im looking to get the eibachs matched with tociko blues or GR2, but as i underfstand these springs are too stiff for these soft shoks and will blow them. so am i forced to go with h&r springs for these shoks? and if i just get new shoks with oem springs will i feel any difference in handeling??? thanx.
Old Oct 4, 2005 | 06:49 PM
Puppetmaster's Avatar
Eibachs match well with GR-2s but will be a somewhat stiff ride and H&Rs/Maxspeeds with Blues, according to what I've seen on the .Org.
For opinions on OEM springs with Blues see:
http://forums.maxima.org/showthread.php?t=423595
Old Oct 4, 2005 | 06:58 PM
Ammi's Avatar
350 Detroit Muscle
You'll be fine w/ blues. Blues are soft and little bouncy though
Old Oct 4, 2005 | 07:11 PM
DrKlop's Avatar
Driving is the next best thing
If you are considering eibachs you must be a hardcore enthusiast because they give you probably the best handling but are very stiff.
So, for someone like you, I’d recommend something sportier than blues or GR2
Also, stiff springs and OEM replacement struts might give you somewhat bouncy ride (like pogo stick,) which in not quite good in neither handling nor comfort department.
Old Oct 5, 2005 | 09:26 AM
chr0nos's Avatar
are blues less stiff than oem struts?
why does everyone recommend switching struts to aftermarket after upgrading springs?
if blues are softer than oem, wouldnt oem struts hold out better and longer than blues?
Old Oct 5, 2005 | 11:53 AM
Blues are stiffer than OEM, but only slightly. You can use aftermarket springs with a minor drop (ie. Maxspeeds and H&Rs) with OEM/Blues, but it also depends on the spring rates. Eibachs with Blues are not a good idea because the Blues aren't stiff enough to match the stiffness of the Eibachs. The springs will thus be jerking the struts up and down (mostly up in the case of Blues) resulting in a bouncy ride. I felt exactly that with my Progress and Blues.
Old Oct 5, 2005 | 11:57 AM
2k1seae's Avatar
I have Eibach and Tokico blues and the ride is pretty good. Potholes and rough railroad crossing are pretty harsh but otherwise I'm very satisfied. The blues are stiffer than stock and match with the Eibach very well IMO. I've had mine on for 3 years and not bouncy. Just my experience...
Old Oct 5, 2005 | 01:19 PM
chr0nos's Avatar
mmkay, sounds good. the correct part numbers for blues are on their way now. hopefully the merchant shipped me the correct ones this tyme.
Old Oct 5, 2005 | 03:23 PM
PearlWhtMaX2000's Avatar
id say go w/ eibachsand GR-2's Thats what im running, and am very happy w/this set up, ride isnt to rough, and handling is great.
Old Oct 5, 2005 | 04:40 PM
Ammi's Avatar
350 Detroit Muscle
go w/ eibachs and illuminas.
Old Oct 6, 2005 | 07:05 AM
super6's Avatar
id love that, but to much $$$. i ordered blues and ill just use eom springs. i dont really want it lowered anyway, just figured may as well do it all together but just decided to replace my old shoks.
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
kenc15
Aug 5, 2015 08:29 AM
