A33 Series 2000-2001 APEXi S-AFC II Pin Location On ECM
Old Oct 9, 2005 | 09:36 PM
JUICED's Avatar
A33 Series (00-01) APEXi S-AFC II Pin Location On ECM (411 Inside)
I know I've seen the wiring set-up for 4th Gen's, but I didn't see a wiring set-up for the 5th Gen's (00-01 - not including 02-03 models). So I thought I'd share in case anyone out there needs it:
You can also refer to page 29 in the wiring diagram book from APEXi under CEFIRO/A33/VQ20DE/N8-a as it is the same.
*Pin Terminal *Wire Color *Item
93-----------W----------Knock Sensor
25-----------W/G------- Tachometer
61-----------W----------Mass Air Flow Sensor
73-----------B---------- Mass Air Flow Sensor Ground
63-----------W--------- Oxygen Sensor 1 (Front) (Bank1)
91-----------L/W--------Throttle Position Sensor
110----------R/G-------- IG Power
48---------------------- ECM Ground/Engine Ground
Old Oct 9, 2005 | 09:43 PM
upstatemax's Avatar
I was looking for this before...
Then I sold it and was told to get one later... damn my ball and chain
Old Oct 9, 2005 | 11:54 PM
mingo's Avatar
are you asking a question or telling us that that's the pinout, because from looking at the diagram those pins are correct.
Old Oct 9, 2005 | 11:59 PM
Mass_Media's Avatar
Mass_Media™
I think he is telling us the pinout
Old Oct 10, 2005 | 12:04 AM
mingo's Avatar
oh ok.. then in that case.. then i verified it from looking at the fsm.. since most of those pins are the ones i am using for the greddy emanage ultimate
Old Oct 10, 2005 | 06:29 AM
JUICED's Avatar
It's not a question. Since I didn't find the pin locations for the S-AFCII any where on this site besides the 4th Gen's and 5th Gen's (02-03), I thought I would put this out there for those of us with A33 00-01 Max's. Hope it helps!
Old Oct 10, 2005 | 11:17 AM
import_rcr's Avatar
Thanks a million! I posted for this a month or so ago and no one responded with correct info so I gave up plus it was HOT AS HELL!!! Now I'm ready to install. I'll post my results as soon as I'm done. Had it in my Talon and my hybrid civic's with positive results.
Old Oct 10, 2005 | 11:27 AM
Deckdout2's Avatar
Play with my balls
I don't have one, but heard there were a few wires not used. Would you provide which ones so there are no confusions as there sometimes are here. Thanks.
Old Oct 10, 2005 | 11:30 AM
Deckdout2's Avatar
Play with my balls
Jime has also had this diagram for you 2k2/2k3 guys up on his site for a while.
*Note.....Isn't A33 2k2/2k3 models?
Old Oct 10, 2005 | 01:59 PM
JUICED's Avatar
Deckdout2, that specific diagram that JIME provided is not for the 5th Gen's (00-01 model year). On the other hand it is for the 5th Gen's (02-03 model year). The two wires off the S-AFCII harness that aren't used is the Pink & Orange wires. import_rcr - I'm glad I could help! BTW, remember to wire the brown and black ground wires off the S-AFCII harness 1 cm apart with the brown wire closest to the ECM. In addition, the yellow wire (MAF output) must go towards the ECM and the white wire (MAF input) must go away from the ECM. In order to accomplish this you must cut the wire at Pin 61 off the ECM. Also remember "not" to use crimps or taps when wiring into the ECM. Only solder each connection and than of course wrapping each connection seperately in electrical tape or heat shrink tubing.
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
