Is alignment needed after wheel bearings
Old Oct 24, 2005 | 07:12 AM
boondoxmax's Avatar
I got my front right wheel bearing replaced at the dealer under warranty and now my alignment is off. With the steering wheel straight the car drifts to the right. So my question is after wheel bearing replacement is an alignment needed
Old Oct 24, 2005 | 07:46 AM
whazzzzuup's Avatar
Yes. Anytime you replace your stock suspension, drivetrain conponent, etc., the alignment will be altered. If the car is pulling to one side, that is a clear indication that you need an alignment.
Old Oct 24, 2005 | 07:49 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Yes... spend like $45 on it and save $$$ in new tires
Old Oct 24, 2005 | 08:16 AM
boondoxmax's Avatar
THANKS! don't understand why the dealer didn't tell me. I know they did the bearing under warranty so i would have gladly paid for alignment!!
Old Oct 24, 2005 | 08:24 AM
Maximam's Avatar
Where the strut attaches to the spindle has a bit of "play". This will cause the alignment to be out when put back together.
Old Oct 24, 2005 | 08:53 AM
Lontar1's Avatar
they won't probably cause you will go back with another stuff so they can slam you or charge the Warranty....
Old Oct 24, 2005 | 08:59 PM
BewstAdd1ct's Avatar
the alignment should have been covered under warranty with the bearing replacement.
Old Oct 25, 2005 | 05:11 AM
maximo-SE's Avatar
hey boondox, whats the function of the wheel bearings? do you need to replace them regularly?
Old Oct 25, 2005 | 08:02 AM
Jasovanni's Avatar
I second that notion
About how many miles are the bearings good for?
Old Oct 25, 2005 | 09:30 AM
upstatemax's Avatar
You would replace them as they need replacing....
You would hear a humming sound from the bad bearing while driving, if it gets bad enough you will hear it pop when you take certain turns.
You can sort of test for it by jacking the car up, grabbing the tire on the top and bottom and push and pull on it; if there is a lot of play... you most likely have a bad bearing.
Old Oct 25, 2005 | 09:33 AM
boondoxmax's Avatar
Yeah humming noise that gets louder with speed. Also causes the wheel with the bad bearing to move around. I would figure that the alignment should have been part of the warranty repairs as my car wasn't out of alignment when i took it in for service... I am not gonna cry over 50.00 dollars.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
