Radiator Fan
Old Nov 1, 2005 | 03:41 AM
josel1138's Avatar
Radiator Fan
My passenger-side radiator fan motor bearings are squeeking and nearing death. Isn't this kind of early for an '03 Max? Has anyone had this happen so soon?
THX,
JL
Old Nov 1, 2005 | 03:49 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
nope...... put some lubricant and see what happen.... if not www.car-part.com
Old Nov 1, 2005 | 03:11 PM
josel1138's Avatar
radiator fan
Thanks for the help........I don't think lubricant is going to help this........it looks very sealed..........I'll check out the link...........JL
Old Nov 1, 2005 | 03:33 PM
Love_00_Max's Avatar
I had a different problem, the fan was rattling when it got turned on. Now, if you look carefully the fans motor casing is made of brass and around the circumference you will see slots where the casing is held to the fan itself. Using a screwdriver push open the slots and then use a hammer to tap to disengage the motor brass casing and the fan.
Let me tell u it is quite a sync motor in there. There are cyclinderical 1-2 inches long slots which are held by springs which if dislodged they can be hell to put back. In my case a spring had popped out, put it back together and it works just fine now.
Old Nov 2, 2005 | 08:00 AM
josel1138's Avatar
radiator fan motor
Wow......you're right.........I looked at mine and it is a complicate mess in there............my springs appear intact..............you were brave to tackle this............JL
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RWCreative
Sep 21, 2015 11:01 AM
