Brake bleed pattern???
Old Nov 7, 2005 | 09:14 AM
import_rcr's Avatar
I did a search and came up with mixed answers. I have swap out bad calipers and now I need to flush brake system. My question is the pattern Right-rear, Left-rear, Right-front, Left-front? Also since I have not powered ignition up do I have to bleed ABS and how since there was nothing on ABS bleeding that I could find. If this has been discussed please link thread for me since Google search turned up nada.
Old Nov 7, 2005 | 09:15 AM
NmexMAX's Avatar
dot dot dot ...
That's the way I do it on my 2003 and 1995.
Old Nov 7, 2005 | 09:29 AM
import_rcr's Avatar
I just wasn't sure if Max had a crossover system or not. Just make me feel better to have confirmation. Thanks!
Old Nov 7, 2005 | 10:24 AM
ColdSHO's Avatar
its best to bleed with the car running, it keeps the preassure higher, itll show if u have leaks better, glad i did this, i did it once with the car onn acc, and then agian with the car on, as soon as we built pressure with the car on, i noticed a leak i otherwise wouldnt have noticed.
Old Nov 7, 2005 | 10:46 AM
Larrio's Avatar
The Definitive AE Master
A good way to remember this is to usually start at the wheel farthest away from the brake master cylinder, which is at the front left of the car between the throttle body and your steering wheel (thats the way I picture it)
hence the rear right, then left
and then the front right, then left
Old Nov 7, 2005 | 05:46 PM
BewstAdd1ct's Avatar
Originally Posted by Larrio
A good way to remember this is usually start at the wheel farthest away from the brake master cylinder,
corrected for accuracy
Old Nov 7, 2005 | 07:15 PM
Larrio's Avatar
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
