Random Tech Cat
Old Jun 2, 2001 | 12:12 AM
PhatGuy
Here is the latest info I received from Random Tech....
"Part number 822530 is a direct fit high flow converter for your Maxima (assuming it's the same as US models). Installation time should be 1/2-hour or less. This converter sells for $204 and has a 2-bolt flange on each end. You should see an increase of 7-10 horsepower at the wheels. We do ship to Canada."
Those HP numbers correct? 7-10hp at the wheels is amazing for $200 bucks!
Old Jun 2, 2001 | 12:14 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Originally posted by PhatGuy
...Installation time should be 1/2-hour or less. ...
It would take 1/2 hour if you don't break any bolts or can get the nuts loose (should be simple because our cars are still new).
7-10 @ wheels? Doubt it.
Old Jun 2, 2001 | 06:57 AM
Fast Walker's Avatar
I just put the RT CAT on my 2k SE I feel no difference at all. The Maxima has a high flow cat as standard equipment.
the only difference is the RT cat is about half the weight of stock. 7- 10 hp No Way....also if you get RT order install kit fo 14.00 it gives u the bolts and gaskets.
Best regards,
Fast Walker
maxinout93
Oct 31, 2015 02:04 AM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
