View Poll Results: Did you regret for cutting your springs???
Yes
0%
No
100.00%
I wish I would've never done it.
0%
No I'm very pleased with it.
0%
Voters: 3. You may not vote on this poll
People with cut springs.
Old Nov 28, 2005 | 07:19 PM
shurik's Avatar
Does anyone here cut their springs to meke their ride lower, lowering springs, or the the stock ones? I did the research and couldn't find anyone who did this for a maxima. I was wondering about the side effects that you had after cutting the springs. I know it's suppose to make the springs stiffer, but did it mess up your spring rate at all? Just was wondering about this. Thanks.
Old Nov 28, 2005 | 07:27 PM
Progress's Avatar
It's business time.
Isn't it an unsafe practice? I don't know why you'd go through all the effort of taking the springs out without replacing them with superior aftermarket springs.
Old Nov 28, 2005 | 07:37 PM
NmexMAX's Avatar
dot dot dot ...
Because most of us are not idiots.
Is messes a lot of things up.
Old Nov 28, 2005 | 07:40 PM
irish44j's Avatar
retired moderator
just get some actual aftermarket springs....the ride AND handling will be better than cutting your stockers. You can get some maxspeeds for under $100.....
cutting OEM springs is always dumb and results in crappy ride, bounciness, and poor handling.
Old Nov 28, 2005 | 07:49 PM
DrKlop's Avatar
Driving is the next best thing
Very few people do this because it is very hard, you are much better off getting some aftermarket springs.
Edit: it's not that it's hard but you have to know where to cut and what to do after it's cut, to get satisfactory results.
Old Nov 28, 2005 | 07:51 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Invalid poll because nobody would cut theirs. Just buy some aftermarkets like Irish mentioned.
Old Nov 28, 2005 | 07:59 PM
Puppetmaster's Avatar
to what everyone has said.... get proper lowering springs or coilovers.
Old Nov 28, 2005 | 08:03 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
that's some rice Honda crap.....
Old Nov 28, 2005 | 08:05 PM
NmexMAX's Avatar
dot dot dot ...
Not if you do it right
Old Nov 28, 2005 | 08:11 PM
Lontar1's Avatar
cool...do it then and send me some pics of your new destryed suspension.....
Old Nov 28, 2005 | 08:12 PM
roll4life's Avatar
cutting the stock springs is always ****ty but i don't know anything on cutting aftermarket ones, prolly better than cutting oem but not by much? who knows man!?
Old Nov 28, 2005 | 08:18 PM
He was being sarcastic.
infinity30's Avatar
Sorry to hijack this thread, but I am a newbie and can't start a new thread. I was wondering you folks know is the suspension from 2000 Maxima will work on my 98? ie springs, struts, shocks the whole set up? Someone local is offering a whole set for cheap. thanx
Old Nov 28, 2005 | 08:20 PM
RA030726's Avatar
I'm nutty for Nissans
yes and no
Old Nov 28, 2005 | 08:32 PM
DrKlop's Avatar
I'm pretty sure that it is possible to cut you original springs and get good results but is not a job for some backyard mechanic. Basically you have to reengineer the way your springs work – which requires multiple measurement tools and a degree in mechanical engineering.
Old Nov 28, 2005 | 08:33 PM
NmexMAX's Avatar
dot dot dot ...
The mispelled the word Infinti ...
Old Nov 28, 2005 | 08:34 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Eh, it's only his username
Old Nov 28, 2005 | 08:37 PM
NmexMAX's Avatar
dot dot dot ...
I guess I didn't give him the benefit of the doubt.. didn't look outside the box.
Old Nov 29, 2005 | 05:36 AM
Stephen Max's Avatar
I think you just owned yourself.
Old Nov 29, 2005 | 05:38 AM
NmexMAX's Avatar
dot dot dot ...
I always do that...Infiniti.
Old Nov 29, 2005 | 07:08 AM
shurik's Avatar
More about this...
Hey guys thanks for the responses, but I'm already droped on Eibach, and Tokiko Blues. Not planning on cutting my OEMs at all. I was just wondering about this. I wanted to hear more about cutting aftermarket springs then stock ones. Just wanted to know if anybody has done this at all and what effects you had afterwards.
Old Nov 29, 2005 | 07:19 AM
PIONEER's Avatar
Springs for maxima are cheap and a whole bunch of brands available in the market. You cut springs when you own a car and no one has springs for it here in the U.S or the only thing you can do is import coilovers from Japan, ie the Q45 I havn't done that yet
Old Nov 29, 2005 | 08:38 AM
spiromax's Avatar
Seoul Man
misspelled
Old Nov 29, 2005 | 08:48 AM
infinity30's Avatar
well It's only a username and Infiniti was already taken so I had to use infinity
Old Nov 29, 2005 | 08:50 AM
infinity30's Avatar
Originally Posted by JSutter
yes and no
can someone explain a bit please. Is it a direct bolt on swap w/o modifying anything? thanx
Old Nov 29, 2005 | 09:29 AM
mtrai760's Avatar
'Trynna' is not a word
People have already told you, you end up with crappy, unsafe handling. Springs NEED to be a certain length, to expand and take up the slack when th suspension becomes unloaded. If you cut your springs, you get rid of that built in tension holding your strut assembly together, and you spring can dislodge from the strut assembly, causing severe steering and suspension issues. In other words, you can die, and kill others on the road around you. Do not cheap out, if you want to go lower, buy springs that allow it. Cutting springs is dangerous no matter which way you try to do it, stock or aftermarket, there is no 'Proper Way' to cut springs.
Old Nov 29, 2005 | 09:30 AM
mtrai760's Avatar
NO, its not a direct bolt on. And next time, wait until you can start your own thread, and do not reply to this one further. Threadjacking =
Old Nov 29, 2005 | 10:56 AM
shurik's Avatar
Ok thanks everyone. I'm not planning on cutting the springs anytime soon, and don't know if I would at all in the future.
thanks anyways.
Old Nov 29, 2005 | 01:36 PM
RA030726's Avatar
well i will finally chime in. i have 3 sets of lowering springs so i decided to chop the intrax, they stink IMO. I cut 2 coils off the front and it rode the same on my car. you know why? because they are designed like azz. the ride was never good. the rear was saggy and always bottomed out on the stock bumps and mounts. now they are on my cousins car and they ride like compleat azz. i cut his bump stops and the ride went stright to poo. basically they always rode on the bumps even before they were cut so the ride never got any worse.
but if i only had 1 set of springs i wouldnt cut them. its just not a good idea. the only benifit is being lower. there are way to many cons, like the springs falling out and loosing control.
cutting the stock springs is a compleat joke since they have way less coils already. ive seen it and its not pretty.
In a nutt shell dont cut them.
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
