DDE Problem, temporary, or i gotta change?
Old Nov 29, 2005 | 11:45 AM
rkyat's Avatar
I did search but couldnt find.
After this wave of coldness we had my driver side smaller ring DDE when starts off gives like a purple color and refuses to warm up. even today was like around 50º+ and it still happens to stay purple. looks like my car has pink eye. Bugbite77 or goldmaxnyc please chime in if you have any idea as well.
Old Nov 29, 2005 | 11:54 AM
jeepik's Avatar
mine does it all the time too
no explanation
i am kind of tired of changing the ballasts too
if you have a solution let me know
Old Nov 29, 2005 | 11:55 AM
rkyat's Avatar
no explanation
so if i change the ballast it'll work again? cause i have a spare ballast.
Old Nov 29, 2005 | 12:35 PM
bugbite77's Avatar
This purple is normal in the cold weather, but only for a max of 2 mins, they should be normal color by then. There are a few things you should check.
1) your ballest is fine since your angel eyes are infact turning on.
2) your angeleyes may still remain purple if the car is not running, this is because the angeleyes might not be getting enough power.
3) Check all your wireing on your driverside DDE's, even if they seem tight, i assume you cut thoes cheesy connectors off that came with the kit and hard wired everything. make sure the red and brown wires from the ballest are connected good, un connect them and re connect them. use heat shrink wrap to reconnect them
4) do the same with all 4 white wires, un connect them one by one and re connect them and use heat shrink wrap to ensure a water tight seal (do these one by one to ensure that you dont reconnect one white wire to a wrong white wire.)
5) if you used the driverside parking light as your accessorie on, make sude that quick tap is doing its job, if its not connecting the wires, it may cause one side angeleye to light up purple.
Please let me know how everything goes, PM me if this does not work.
ALSO MAKE SURE BOTH YOUR BALLEST ARE SEALED WITH SILLICONE OR GOOP (FOUND IN HOME DEPOT IN THE GLUE SECTION) TO MAKE SURE WATER NEVER GETS IN.
Old Nov 29, 2005 | 12:39 PM
rkyat's Avatar
thanks bugbite ill try. Goldmax did my installation but i guess i could try what you said. aint no harm in trying. sucks driving around like your car got pink eye. lol.
Old Nov 29, 2005 | 12:46 PM
bugbite77's Avatar
where do you live? never mind ill take this convo to PM's
Old Nov 29, 2005 | 02:55 PM
MaximaPolak's Avatar
You should hardwire the DDEs to the ballasts to fix that. If that doesn't work, there is a bad ground somewhere.
Old Nov 29, 2005 | 07:50 PM
rkyat's Avatar
My baby's sick, she's got pink eye.
Old Nov 29, 2005 | 09:12 PM
ICULookN's Avatar
Is this fix guaranteed to fix the problem? I have the original angel eyes from umnitza and 1 of my bulbs went out and I'm thinking about upgrading to these new ones. Umnitza doesn't have replacement bulbs so I'm forced to upgrade, I just want to make sure I want have any problems with these.
Old Nov 30, 2005 | 05:02 AM
bugbite77's Avatar
Hmmmmmmm usually when you have a connection problem, half the bulb will be PURPLE, not PINK. Have you tried the things i told you to do yet? If not, we will have to meet up so i can try to fix this, this sounds interesting.
Old Nov 30, 2005 | 05:34 AM
rkyat's Avatar
What part of LI are you at, ill probably be on LI either tomorrow or friday.
Old Nov 30, 2005 | 06:12 AM
bugbite77's Avatar
by the border of nassau and suffolk, north shore, pm me your # and ill call you.
Old Nov 30, 2005 | 07:01 AM
OOmaxSE's Avatar
LOL looks like there's a party in your headlight. hopefully it's not your ballast, which it doesn't seem like it is... i guess connection, like everyone else has said.
Old Nov 30, 2005 | 08:43 AM
crispykid717's Avatar
Bigger than Jesus
Straight from the Umnitza website
"Minimal Cold Climate Startup difficulty"
Old Nov 30, 2005 | 09:26 AM
50º is not a cold climate. Mine start up great until around the 30s or 20s.
Like I said before, CHECK YOUR CONNECTIONS!
matts95max
Apr 23, 2025 10:44 AM
minsbang
Sep 11, 2015 08:48 PM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
sdotcarter
Sep 2, 2015 09:53 PM
