Front stabilizer bar removal on 5th gens?
Old Dec 7, 2005 | 04:20 PM
MaxBoost925's Avatar
Drug Money
This question has not been answered yet. The only questions have been about stabilizer bar bushings.
I was just wondering how I can remove and replace my bent front stabilizer bar with a new one.
The problem is that apparently the hole is too small for bar removal, I tried to sqeeze it out to no avail. There is the steering cylinder thingy and the steering shafts that are in the way.
Maybe I have to take off both front subframes? That would suck.
Thanks org.
Originally Posted by bsetiawan
Your car will run fine without the stabilizer bar as long as your don't take corners thinking you're in a race car.
...I still want to take corners like a champ... But more careful of course.
http://forums.maxima.org/showthread.php?t=443655
Old Dec 7, 2005 | 05:06 PM
BEJAY1's Avatar
Conecarver
We had to drop the front subframe crossmember on mine when we removed my 4th gen one. Wasn't a big deal once the engine/tranny is supported.
Old Dec 7, 2005 | 05:31 PM
00SEMAX19's Avatar
I've been reading your other thread about your suspention damage and was wondering then and now about this. How did you bend the stabalizer bar? Are you sure you did? It's like a giant spring, same idea as torsen bars kinda. Not trying to argue or anything but throughout the probly 1000 suspention rebuilds I have done I've never had to replace one.
Sorry I didn't answe your question but just hoping to maby save you a little bit of time and money.
Old Dec 7, 2005 | 10:05 PM
Drug Money
Thanks though, but how it happened, imagine yourself standing in front of my driver side front wheel. The bottom right of the wheel got hit, the control arm was mashed in the right side, where it mounts to the stabilizer bar. At least thats what I think happened, it didn't hit the wheel square on the bottom, kinda at an angle, I think that's why.
I put a brand new OEM bar under the "bent" bar and compared it to both sides (driver and passenger) the passenger side looks exactly the same, the driver side is slightly bent. Now my concern is that it will effect my handling, but the darn thing is mounted by "pivotable" bolts so I don't think it does TOO much.
But thanks nonetheless.
Old Dec 8, 2005 | 08:27 AM
00SEMAX19's Avatar
I don't think it should cause any handling problems. Good luck with the repair though, hope everything comes out good...
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaxStock
Aug 14, 2015 10:03 PM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
