autotrans problems please help
Old Dec 12, 2005 | 05:38 PM
SLICNIC's Avatar
have a 2000 max auto rebuild trans with less than 25k while shifting from 1st-2nd it over revs with a jerk while going into 2nd, I recently changed the fluid with valvoline dexronIII as well as tran filter or screen about 2k ago should i change fluids
Old Dec 12, 2005 | 05:59 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Are you going to change the fluid again? Is that your question? You should be fine with the 1 change.. you can run it up to 30K per the manual.....
Old Dec 12, 2005 | 06:05 PM
SLICNIC's Avatar
NO I HAD CHANGED THE FLUID ABOUT 2K AGO AND IAM JUST STARTING TO HAVE THIS PROBLEM WITH THE SHIFTS
Old Dec 12, 2005 | 06:13 PM
99 SE-L
I got the same problem, I want to know what is going on. ? Iam doing a 6 speed Swap in the Summer Anyway
Old Dec 12, 2005 | 06:29 PM
DonGfun's Avatar
VW = 30 MPG
If it was rebuilt it should have a 100K warranty. You should let the shop look at it
Old Dec 12, 2005 | 06:33 PM
Lontar1's Avatar
take it back to the shop for further analysis... don't tell them you did a fluid change......
Old Dec 12, 2005 | 07:57 PM
NewLoveI30's Avatar
Solenoid packs are a bit of a problem on the 00-01's. I had the dealer replace mine at about 25k. Fixed the problem right up.
Does it seem like the shift is very delayed from 1-2 and sometimes a rough 2-3? Those are the exact symptoms I was experiencing.
Old Dec 12, 2005 | 08:49 PM
icewake's Avatar
i put the valvoline in mine and it started doing it right after i put the new fluid in. i am probably gonna change fluids again around christmas
Old Dec 12, 2005 | 10:23 PM
huso1988's Avatar
how are you doing 6spd swap?
are you doing it ur self, or are you having some1 do it? if so, how much is it, ,and is it hard to do it. Where did u get the tranny at?
THANKS
Old Dec 13, 2005 | 07:02 PM
99 SE-L
THANKS
iam not doing it my self, tilleys 99 is doing it the trans is around $600 it self, Not really hard takes him about 2 days to do.. As he is very Knowledgble in Swaps....
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
