Stillen Rotors Installed...question
Old Dec 23, 2005 | 09:58 AM
xmaltbeerxcp's Avatar
Hey I had my Stillen Cross Drilled Rotors installed along with the metal matrix pads and also SS lines. Now before i had major vibration from high speed stops under braking. Now that is gone but i am faced with something different maybe someone here can help me with. When I'm going between 60-90 the steering wheel vibrates a bit this isnt under braking just accelerating. Do you think this could be the tires? I torqued the wheels and everything. I dunno...
Old Dec 23, 2005 | 10:59 AM
bladerunr's Avatar
It's definitely a balance issue. Start with the wheels.
Old Dec 23, 2005 | 11:00 AM
R.I.P. Grandma's Avatar
Check if your wheels and tires are balanced properly, and if that checks out then i will have to believe you are in need of a wheel alighment. Usually when there is vibration when cruising at highway speeds its either one of the two.
Old Dec 23, 2005 | 06:01 PM
k2max_driver's Avatar
i know don't go past 59mph and you'll be good. Just kidding did you have this vibration before you replaced you old brake set? Did you swap wheels like put the left on the right? What did you torque down the wheels to?
Old Dec 24, 2005 | 07:09 AM
Heh..yea rite lol. Anyway yea come to think about it I did have my rear tires put to the front and didn't have them balanced. So that is probably what it is...I'll post back up when I have them balanced and I'll tell you guys what the deal is. Thanks for your replies!
Old Dec 24, 2005 | 11:10 AM
Well got back from having my front tires balanced and the vibration crusing at high speeds is now gone. Thanks for your guys help.
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Socalstillen
Sep 26, 2015 12:01 PM
