Maximun HP out of a Maxima
Old Jun 5, 2001 | 08:40 PM
maxse01's Avatar
When i am all finished with my maxima it will have a stillen intake, y-pipe, b-pipe, stillen supercharger, unorthadox racing underdrive pully, flywheel and high performance plugs and wires. What do you think my max hp will be? Once i get my short shift kit i am hoping to run low 5's and the high 13's in the 1/4. Thanks for the input.
Old Jun 5, 2001 | 09:14 PM
PhatGuy
Check http://www.avalonracing.net/maxima.htm
Go with the Place Racing Cold Air Intake instead of Stillen if you are real serious. Throw on a Random Tech Cat which might help and rear exhaust as well. You should have well over 300HP no prob!
I hope you are upgrading your suspension, clutch, tires and brakes as well?
PS I love the short throw shifter. I can't imagine having to drive with the stock stick again.
Old Jun 5, 2001 | 09:54 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
13's with a 5 spd is easy. You can't use the UDP with the SC and there's no need for the Stillen intake.
Old Jun 5, 2001 | 09:59 PM
Y2KevSE's Avatar
Originally posted by AznWontonboy
its easy for an auto too, slap on 120 shot of nos.
*BOOM*
Old Jun 5, 2001 | 10:02 PM
AznWontonboy's Avatar
Originally posted by Y2KevSE
*BOOM*
boom tranny or boom engine??
Old Jun 5, 2001 | 10:10 PM
RBa's Avatar
RBa
I'd say engine since he doesn't have auto...
Old Jun 6, 2001 | 12:16 AM
Desert Pearl's Avatar
Oh, come on Kev! Let him underdrive his SC if he wants too!
Maybe he was planning on getting a REALLY
REALLY REALLY small SC pulley!!!
Old Jun 6, 2001 | 06:55 AM
Y2KevSE's Avatar
I wonder how that would work... If you got the smallest SC pulley and slapped on a UDP with it. How would you calculate the lbs. of boost with that setup?
Old Jun 6, 2001 | 09:16 PM
I think this would work. As long as you get the pulleys sizes to the ratio you want, I don't think it should matter. As far as calculating boost goes, I would think the pulleys ratio would tell you this also, but...
Old Jun 7, 2001 | 01:35 PM
maxse01's Avatar
I don't understand. How am i going to blow my engine cause i have a stick, and how can i underdrive the supercharger? Please explain.
Old Jun 7, 2001 | 01:55 PM
Y2KevSE's Avatar
I was referring to WontonBoy's 120 shot nitrous on an auto statement.
With the UDP, you'll be underdriving the SC, meaning product less boost. You'll want to overdrive it for more power, i.e. smaller sc pulley.
Old Jun 7, 2001 | 02:09 PM
Jeff92se's Avatar
I'm needing a caw
Let us know when those 2000+ maxima high performance plug wires come in!
Old Jun 7, 2001 | 02:10 PM
Y2KevSE's Avatar
Blah blah blah... <- hehehe
Old Jun 7, 2001 | 02:44 PM
maxse01's Avatar
how can i overdrive the sc without causing damage to the sc or my engine?
Old Jun 7, 2001 | 02:57 PM
Y2KevSE's Avatar
You can probably somewhat safely boost up to 10 lbs. (smaller pulley), but I wouldn't recommend going over that because you'll need engine work (not to mention clutch, fuel system, etc).
BTW, how 'dem ***** doing?
Old Jun 7, 2001 | 07:29 PM
doublea's Avatar
Hey AznWontonboy, there is a misconception about NOS, it is less damageable for an engine than a turbo or SC, the reason for this being when the nitro get into the engine it temperature is around -127celcius, so it create much less heat than a turbo or SC, but it can cause some stress on the engine if abuse and perhaps more severe one on weak tranny.
A decent NOS system & installation on a 5spd Max would be ok. I would suggest some work on the auto tranny before going NOS.
Cheers
Double A
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
