Any word on aftermarket plenums for our cars?
I heard there were some people trying to use a 350z aftermarket plenum but werent sure if it would fit under the hood. Is there anyone trying to talk a manufacturer into making one for our car. I think this is something we should start workin on asap because depending on your mods already this one mod could add as much as 20-30 whp.
vq30dek already flows very well with it's stock intake manifold....
and yesss! where is our vq35 IMs at!?! the altima and maxima communities combined is pretty large...i'm sure someones gonna be coming out with one !
It flows well but not good enough. Even with the power valve removed you can see the peak point
Most maxima peeps won't spend good money for a coilover system, let alone any sort of aftermarket intake manifold or plenum spacer. For example, the new 350z manifold made by SSR is about $1000 (IIRC). Just sit tight for one made on the altima platform and utilize the design.
Originally Posted by MaxBoost925
Where is this at, is this DIY? Like the TB restrictor?
Its been discussed and done by quite a few people on the org
I don't see a point of disabling VIAS. With variable intake you get the best of both world (peak hp and low end torque) By disabling this system all you gain is a very little increase of power between 4.5k and 5k rpm but lose low end torque.
http://www.motordyneengineering.com/G35.asp
Maybe contact them and get this started, or just buy a g35.
if you're going to ask them to make one for your 5.5 gen don't forget my beloved VQ30DE-K
Highly unlikely for either of us, with you having much less of a chance.
VIAS is already open over 5k rpm. Disabling the system will not increase top end power.
Originally Posted by Y2KmaxSE
in a 5.5 I think VIAS kicks in at 4100RPMS....so you have that extra power all the way to redline..right? why would u want to disable that to gain extra power for 500 rpms?
Dynos have proven that the top end is superior in comparison to a working power valve. Ask Jclaw, Sr20den, Tilleys99, etc
Originally Posted by Kiosk
yea but them I would want cams to take advantage of extra air and adjust the power curve!!!
IMs can shift the powerband just the way cams do.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
