dde wiring question...
Old Jan 17, 2006 | 04:56 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
i've read housecor's instruction on how to wire it to a switch... would it affect anything i was to run the switch on to the main ground wire for the dde's and run it to the switch with another wire already grounded...
it def. makes thing easier in my eyes...
any thoughts...
Old Jan 17, 2006 | 07:03 PM
KabirUTA13's Avatar
hmmm bump!
Old Jan 17, 2006 | 08:03 PM
housecor's Avatar
If I understand your explanation, yes, that should work as well.
Old Jan 17, 2006 | 08:13 PM
KabirUTA13's Avatar
ok great... now i tested out my dde's... jus for a test run i didn't tap the wire into the park lite... i grounded that one wire... and i had the power wire with the fuse on the battery post and the other wire that was supposed to tapped in... now the power wire with the fuse seems obsolete..... i came off but the thing was still on... wat do u think...
Old Jan 17, 2006 | 08:25 PM
housecor's Avatar
Did you try replacing the fuse?
Old Jan 17, 2006 | 08:36 PM
KabirUTA13's Avatar
fuse is good... jus don't understand why the ddes were still running even with tthat wire off...
Old Jan 17, 2006 | 08:40 PM
housecor's Avatar
The DDE's will light as long as the there's a ground and power - so you can hook them up directly to the battery and get them to light - even with the trigger wire off. Once the relay is brought into the mix, they'll only light when they trigger wire receives power.
Old Jan 17, 2006 | 08:47 PM
KabirUTA13's Avatar
arite... thanx for the info...
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
