H&R' fronts on 245/45/18's??
Old Jan 23, 2006 | 01:45 PM
2k0to2k3's Avatar
hey just wondering if any of you guys are running 245/45/18's and if i'll have enough clearance to drop my front with the H&Rs. Rear wheel = no way, it has no wheel gap with the 245/45/18's tires and i love the way the larger tires fill the rear wheel gap but front still has the dreaded nissan hideous gap why nissan, why? lol thanks to any that can help, best sight i've ever come accross bar none!!!
Old Jan 23, 2006 | 01:49 PM
NmexMAX's Avatar
dot dot dot ...
Wrong forum and too much sidewall.
245/40-18's FTW.
Old Jan 23, 2006 | 01:51 PM
2k0to2k3's Avatar
sorry about wrong forum, so they'll probably rub with H&R's???
Old Jan 23, 2006 | 01:53 PM
NmexMAX's Avatar
dot dot dot ...
I don't know, but they're larger than stock by ~1"
Old Jan 23, 2006 | 01:59 PM
FreshWes's Avatar
245/40-18's FTW.
Will 245/40s rub with the h&r's or the eibach kit?
Old Jan 23, 2006 | 02:01 PM
2k0to2k3's Avatar
yeah i purchased tires way before i knew about maxima.org, so forgive the ignorance, i figured the larger 245's would fill wheel gap which it totally did in rear but still left some in the front. After being here for 2-3 weeks and reading non stop i realize i just had to put the H&R's....oh well,maybe i'll just get them anyway and see.
Old Jan 23, 2006 | 02:06 PM
2k0to2k3's Avatar
well i know i should have got 235/40/18's to keep the same diameter as stock so i'm guessing anything lower profile than that would not rub but anything greater than that would with a drop, although with stock suspension i have no problem.
Old Jan 24, 2006 | 02:27 PM
shoman94's Avatar
245-40-18 is closer to stock than 235-40-18
Old Jan 24, 2006 | 02:51 PM
2k0to2k3's Avatar
nmexmax quoted me wrong from the beginning....i have 245 45 not 245 40's but either way if you have anything larger (side wall that is),than the recommended 235/40/18 there is uncertainty wheather tires will rub or not due to the fact you are increasing the stock diameter of factory rims. Your whole wheel is bigger which i already realized that's why i was asking if anyone had actually had H&R"s with my size tires. AS a side note when i bought these tires 2 1/2 yrs ago 245 45 had many more options/brands/year round tires than the 235/40's. Not sure if it's changed but all i could find in 235/40 was the summer/track/high performance which wear out in 10,000 mile if your lucky type. i purchased continental extrmes with a 420 tread wear rating i believe, compared to 200--something types of the 235/40's. I've put 20,000 miles on them and they still read 9/32 in rear and 8 1/2 in front so wearing unbelieveably well!!!! And because i got the plusher side wall the ride actually got smoother than stock. AS far as the tires raising my ride slightly i already had stillen kit on which makes the car look lower to balance it out. Rear gap totally eliminated but front still has slight gap. good set up if you have kids and care about ride quality,looks but do not race, as the larger diameter seems to have slown down my max. No problem for me though, as i want my car to last so i don't race or beat it at all!!!
Old Jan 24, 2006 | 08:36 PM
myktek's Avatar
i use to run 245/50/18 on a 18x8.5 in the front, dropped on eibach/tokico's w/o any rubbing...
Old Jan 24, 2006 | 08:42 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by myktek
245/50/18
Wow.. Pretty big tire.
Old Jan 24, 2006 | 09:52 PM
2001SE's Avatar
and a very very odd weird size tire lol
Old Jan 24, 2006 | 10:25 PM
Edward Lee's Avatar
No, not if you have the correct offset. However, mine rubbed a little on the right rear outside, at the tab where the bumper connects to the rear quarter panel.
Old Jan 24, 2006 | 10:46 PM
MaxBoost925's Avatar
Drug Money
Mine is 215/50/17 H
They're not huge... but then again, I'm 17X7
Old Jan 25, 2006 | 05:45 AM
NmexMAX's Avatar
dot dot dot ...
You don't know tire sizes do you?
Your tire's overall diameter is 2.18" smaller than the 245-50-18.
Old Jan 25, 2006 | 02:47 PM
vsamoylov
i had the oem 6th gen maximas and no rubbing but the tires were soo huge. sidewall is not correct so get 245/40/18.
Old Jan 25, 2006 | 02:52 PM
Drug Money
Sorry, i was thinking of the height, not the width. 245 is indeed wider than 215.
Old Jan 25, 2006 | 03:01 PM
NmexMAX's Avatar
dot dot dot ...
I was talking about height.. You just proved that you don't know squat about tire sizes.
Old Jan 25, 2006 | 03:02 PM
Drug Money
you win.
Old Jan 25, 2006 | 09:27 PM
myktek's Avatar
i think i'm the one w/ the biggest tires on 18's on the org...or was...
18x8.5 245/50/18
18x9.5 275/50/18 ...
Old Jan 25, 2006 | 09:34 PM
2k0to2k3's Avatar
maxboost925, don't worry about it, some people get a kick out of flexing on others because they simply have more tire knowledge wtf ???, but instead of browl beating you down let me just give you a quick tire lesson. 245/45/18the first number is your tire width ex. 245, the second is a percentage of that first number, so 45% of the 245 and that is your side wall height. And finally the last # is your rim size,which mine are 18's. hope that helps you, it's really simple once someone breaks it down for you which is what i thought this site was for....to help others and share info, not beat each other down.....
Old Jan 25, 2006 | 09:37 PM
2k0to2k3's Avatar
myktek, did you ever have a problem with rear wheels hitting/scraping? only when i have rear passengers and hit a lg bump does it scrape but it does hit. if yours did not i'm thinking maybe my shocks/struts may need replacing. hummm....
Old Jan 25, 2006 | 09:43 PM
NmexMAX's Avatar
dot dot dot ...
275/50/18
Tires are over 4" larger than stock...
Old Jan 25, 2006 | 09:50 PM
Edward Lee's Avatar
That gotta make for one slow Maxima.
Old Jan 25, 2006 | 09:56 PM
NmexMAX's Avatar
dot dot dot ...
It's called aspect ratio
245 = width in mm
45 is the aspect ratio.
245 x .45 = 110.25 X 2 =220.5
X 2 because you have a bottom(between the road and the wheel) portion and top (between wheel and fender well) portion.
Convert to in. --> 220.5/25.4 = 8.68" + 18" (wheel diameter) = 26.68"
Who says I never help out.
Old Jan 25, 2006 | 10:05 PM
2k0to2k3's Avatar
no, tire rack said 235/40/18 is your stock diameter as you are esentially trading an inch of 17" tire for and inch of 18' rim thus creating a harsher ride theoredically. you have less side wall. choises in the 235/45's were very limited as well so i went with 245/45's which had many more options.
Old Jan 25, 2006 | 10:08 PM
2k0to2k3's Avatar
awsome, a much better and technical explanation than i gave, now you are getting it
Old Jan 25, 2006 | 10:15 PM
2k0to2k3's Avatar
i have the gle and when i put my stock 16" next to my 18" it's maybe an inch taller if that, but it really did slow down my max but again i don't race my car so it is certainly still fast enough to merge onto parkway etc. etc. just not as fast as it was by any means. anyway i have a ninja zx7r for when i want to go fast, my car is just for looks.
Old Jan 25, 2006 | 10:19 PM
NmexMAX's Avatar
dot dot dot ...
He wasn't talking about or to you.
He was referring to myktek
Old Jan 25, 2006 | 10:24 PM
2k0to2k3's Avatar
yes i realize that about his rear rim, which to be honest i don't know how that is possible. my 245/45 in the rear completely fill out the well. if i have 2good sized people in the rear tires hit the inside so??????how are those tire sizes possible for rear?????
Old Jan 26, 2006 | 06:58 AM
PoLo's Avatar
2-Wheelin it...
i'll just give you my opinion.
i'm on 245/45/18 running on 2k5 SE wheels with H&R fronts/OEM rears.
my fronts clear completely. my rear rubs, but i think it's an issue with my car, cause only one side rubs. it's almost as if my car was in an accident, but it wasn't. weird. anywho, i think it fills out very nicely. and yes, i know it's not oem specs as far as wheel size, but who really notices 1-2mph difference. CERTAINLY NOT ME!.
so, with just me, i don't rub. with 1 person, i don't rub. and with 2 people, i don't rub unless i hit a fairly deep bump, then it'll rub from the bounce. do i care? not really. i've had 2 people, with a suitcase and i didn't rub at all. this is NYC. second example i drove with 2 people plus snowboard equipment and went on a 2 hour drive upstate....also did not rub.
let me add though, cause i totally forgot, that i have a 200+lb system in the trunk, so my rear is MUCH lower than most stock cars with OEM springs in the rear. so if you were to tell me that you have nothing in your trunk, then my answer to you is that you have absolutely NOTHING to worry about.
Old Jan 26, 2006 | 07:53 AM
vsamoylov
read this guys. http://www.mazda3forums.com/index.php?topic=10243
Old Jan 26, 2006 | 02:58 PM
2k0to2k3's Avatar
thanks to vsamoylov for all the technical reasoning. I wish i new about this site prior to buying my combo but at the same time i'm glad i had enough common sence to not go with the lower profile tire as i'm sure i would have had a bent rim or blow out , not to mention how harsh of a ride i would have had with the lower pro and i'd probably already be on my 2nd $800 set as they wear so quickly. As soon as i pulled out of the shop, i new what i had just done , maybe not as technical as the link you provided but i definately knew the car was working harder to move her and my braking was definately reduced but to be honest i don't know of any mod that does'nt effect b and c if you change a. No matter how small the mod, engineers spent ridiculous amounts of time and research to have all systems work with one another. You may be able to make it go faster or look better but it always comes at a price. As far as my max, i might have just extended her life by my rim combo because i can't help but think it's almost like she is towing something so i take it much easier on her than i used to. Last year i changed rims in winter back to 16" and just could simply not control myself and was beating the **** out of her because she was sooo much faster and nimble but decided against it this year because i could'nt stand to see her with those tiny rims, imo it does'nt even look like the same car, so it's worth it to me....just my .02
Old Jan 26, 2006 | 03:04 PM
2k0to2k3's Avatar
polo, thanks brother, now i know it will work and i must have an issue with rear shocks/struts unless your 02 has a stronger rear setup. mine is a 2k with nothing in the trunk and if have 2 passengers and hit any type of bump/dip you hear a quick scrape in the rear but when i have front springs installed i'll find out about it. thanks again
Old Jan 26, 2006 | 03:35 PM
vsamoylov
any time man. i do what you are saying though. that is what i found the best of both worlds by buying ssr comp-c and going with a 18inch rim that is 8.5 and the weight is only 16.2 for the rim. but that comes at a price like you said.
Old Jan 26, 2006 | 08:15 PM
2k0to2k3's Avatar
your ride looks good though, so who cares? i always liked the 4thers with our 5th 17" wheels but yours looks even better....nice mod
Old Jan 26, 2006 | 09:35 PM
Edward Lee's Avatar
Right rear tire scrape
It's gonna scrape no matter what. I have a set of H-Techs and Illuminas (set @ 4) and I get the right side scrape on big dips also. It's the tab where the rear bumper attaches to the rear quarter panel that is touching on my car. You can bend it a bit or shave it down with a dremel like I did.
Old Jan 26, 2006 | 09:41 PM
2k0to2k3's Avatar
even better, thanks, as soon as it gets warmer i'll probably do that.
Old Jan 26, 2006 | 10:30 PM
myktek's Avatar
oh man, my bad, i remember the wrong information.... sorry about that guys, went back and looked at the old pics and it's
245/40/18
275/40/18
sorry about that ..... it's been a yr since i sold the rims... =(
http://home.houston.rr.com/myktek/rims/
Old Jan 26, 2006 | 10:38 PM
NmexMAX's Avatar
dot dot dot ...
I figured and was wating for that correction.
