Gauges just flipped out...
Old Jan 30, 2006 | 05:37 PM
S00NR1's Avatar
OU > *
So my gf and I were on our way back home tonight when the gauges decided to flip out. We were driving down a local highway with the cruise set to about 50mph when all of a sudden, the gauges slowly started freaking out. Here is a pic I took while we were driving along:
The cruise "set" light in the bottom right corner was continuously flashing the rest of the drive home and the low fuel light also came on (I just filled up the tank this afternoon). Also, we had been driving the car for awhile, so pretty much every gauge in the cluster was fubared. Has anyone else had this problem?
Old Jan 30, 2006 | 05:38 PM
irish44j's Avatar
retired moderator
Call DAVEB, FTW....
Old Jan 30, 2006 | 05:42 PM
S00NR1's Avatar
OU > *
Here is what it looked like after restarting when we got home:
Old Jan 30, 2006 | 05:45 PM
merovi's Avatar
thats the fastest i've ever seen a max go
Old Jan 30, 2006 | 05:55 PM
Deckdout2's Avatar
Play with my balls
I had a similar issue with my 4th gen. Can't remerber the malfunctioning part, but will post when I do.
Old Jan 30, 2006 | 06:22 PM
Hoooper
how about the highest RPM? thats gotta be at least 9 there.
Old Jan 30, 2006 | 07:47 PM
bigEL's Avatar
That pic would make one awesome sig. Better put a watermark on it before someone steals it.
Old Jan 30, 2006 | 07:58 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Your car is still slow...
Old Jan 30, 2006 | 08:21 PM
designer485's Avatar
I had a similar thing happen, it ended up being a bad alternater. Go figure.
Old Jan 30, 2006 | 08:45 PM
MIKE2K2's Avatar
Custom User Title
9k rpm's you should be going faster. Or were you in 3rd gear??
Old Jan 30, 2006 | 09:19 PM
Hoooper
3rd at 9k would not equal about 175
Old Jan 30, 2006 | 10:18 PM
MIKE2K2's Avatar
Custom User Title
Ummm. he has an auto. 3rd is 1:1
Old Jan 30, 2006 | 10:25 PM
S00NR1's Avatar
OU > *
Well, I just got back from taking her home....when I started it back up everything was working but the speedometer. So on the way back, I floored it on a back road, and at about 90, the speedometer clicked back into place and seems to be working fine again. Who knows.....
Old Jan 30, 2006 | 10:36 PM
MaxBoost925's Avatar
Drug Money
hahaha, i guess the speedo had to do a "sit up" huh? You had to go more than half the circle to catch the needle again.
Old Feb 19, 2006 | 09:59 AM
S00NR1's Avatar
OU > *
OK, so a little update.
Since my last post, the problem has gradually gotten worse so today I decided to take the entire cluster apart since it's pretty much worthless anyway. I have yet to find anything of a clue but who knows. I talked to Dave B and a new cluster is $205, so I am praying that I can figure out the issue today. Here are some pics of the entire cluster taken apart:
Old Feb 19, 2006 | 10:06 AM
DrKlop's Avatar
Driving is the next best thing
something is wrong with the server. Instead on the pics I see those small "pictiger" banners.
Old Feb 19, 2006 | 10:13 AM
GBAUER's Avatar
OK, so a little update....
I doubt it was the cluster. Sounds like possibly the alternator voltage regulator going nuts. Try starting the car and taking a voltage reading at the battery before doing anything else. Just a thought.
BTW: your car is slow. Only 170?
Old Feb 19, 2006 | 10:14 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
... can't see them either
Old Feb 19, 2006 | 10:18 AM
GBAUER's Avatar
I right clicked it and went to properties, copied the URL and posted it in my browser. I know, it's a long way to go....
Old Feb 19, 2006 | 11:44 AM
Hoooper
still not 175, sorry.
also cant see the pics, but yes, like ^^^ said, probly not the cluster.
Old Feb 19, 2006 | 12:20 PM
whazzzzuup's Avatar
Were your headlights and other lights fluctuating during the gauge chaos? I hope you get the problem figured out soon, Lance.
Old Feb 19, 2006 | 01:50 PM
SoonerFan's Avatar
Cletus
So tonight my gf and I were driving down a local highway with the cruise set to about 50mph
so everyone else is just just letting this go to waste???
fine, i'll do it
so what was the gf doing? we all know why we use the cruise control at night when our girl is in the car
Old Feb 19, 2006 | 03:13 PM
S00NR1's Avatar
OU > *
Nope, everything else electrical has been working just fine.
Old Feb 19, 2006 | 06:16 PM
spreenyk888's Avatar
i had the same problem years ago in a 94 grand prix. for about 2-3 weeks the gauges were goin nuts, all the lights would flicker, the speedo would read 50 at stoplights, the rpms would go crazy. i didnt really care that car was a pos anyway it was my first car. finally after a couple weeks the alternator went out, and the mechanic explained to me that sometimes a failing alternator could cause weird things to happen in a car. my father also had a similar problem in a chevy where the radio would flicker on and off consistantly for about 2 weeks, then the alty went out. i would check your alternator if i were you.
Old Feb 19, 2006 | 09:18 PM
Maximaum Driver's Avatar
The only time I had my cluster hose up on me was when my charging system was on the blink. I had an open diode in the alternator and it was fixed and all the problems stopped.
Old Feb 20, 2006 | 03:58 PM
S00NR1's Avatar
OU > *
Well I went to AutoZone and had the battery system tested. Everything ran just fine (14.3 V for the entire test). The employee did pull a P0500 code -- speed sensor malfunction -- and DaveB said this is not possible since our cars receive the signal from the ABS or some such. The cluster does seem to be working much better after taking it apart and putting it back in though, all except the gas gauge which appears to be stuck at the very top.
Old Feb 20, 2006 | 08:27 PM
5thgenmaxima's Avatar
I'm going to provide a link to a few diagrams since they would be to small to read if posted here.
http://www.cardomain.com/ride/2195944/2---bottom two pics
If you notice the speedo/tach/temp gauge/odo/and fuel gauge are all tied together inside a "unified meter control unit"...Unfortunately alldata doesn't show the printed circuit very well so this is all I have to go off of..
Since your not throwing a dtc for any of your other gauges, I'm going to guess the problem lies between your VSS (Wire # 15 red) and your gauge cluster, possibly after your cluster going to your ecm...
I couldn't tell for sure, but even though your odo wasn't working it looks as though the light for it was on?
EDITING: the VSS isn't a resistor like older vehicles. It's a pulse Generator.
Copied and pasted from alldata
Component Description
The vehicle speed sensor is installed in the transaxle. It contains a pulse generator which provides a vehicle speed signal to the speedometer. The speedometer then sends a signal to the ECM.
Malfunction is detected when the almost (0 MPH) signal from vehicle speed sensor is sent to ECM even when vehicle is being driven.
Is the problem with the other guages only occuring when the speedometer acts up or is the problem with the fuel/odo/etc always a problem?
Also from alldata ". Realize also that the most frequent cause of I/I (intermittent)occurrences is poor electrical connections. "
I would pull out the vss, clean it off, pull the ecm haness off and look for any loose wires or corrosion, clean as needed, and since you already pulled the gauge apart I'll guess you cleaned/checked all connections there and tehy are good.
Old Feb 20, 2006 | 09:13 PM
Snolife's Avatar
What we have here is a failure to communicate
Sorry, kind of stupid question here, does that mean I can replace my "stock" black one on my GXE and get a nice white one like most of you have? And if so, what about the milage on it?Thanks.
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
