Darn PINK EYE AGAIN!!!
Old Feb 2, 2006 | 12:45 PM
Greeneyes's Avatar
Crap damn it!! this is the third time already stupid DDE's.... I dunno why this keeps happening I just got 2 new Ballasts for the DDEs and and 2 new rings that I put in like 3 months ago and now here we go again one damn ring wont light up all the way it stays pink! Yes I did leave it warm up and everything but still no go like the ones before.... Ima have to replace the SOB again.... bake the headlight and all for the 4th time!! Gah!!! It always seems to happen right after the temperature drops but then it wont come back it just stops working!? These are hardwired by the way, is anyone else having this problem?! Pics below
Properly working DDE's:
PINK EYE:
AGAIN:
Old Feb 2, 2006 | 01:21 PM
Deckdout2's Avatar
Play with my balls
It does suck....just get new rings, and buy extra this time. that's what i had to do. not really sure why it does that, but every now and again. hopefully i won't have to mess with these anymore and they start working right.
Old Feb 2, 2006 | 03:06 PM
MIXXMAX's Avatar
Ahh, man that sucks. I was planning on buying a set of these. Do they happen to do this all the time? Have others here had similar problems? I would hate to keep opening these up and having to deal with these problems. Greeneyes, do you run these when the outside temperature is cold? If so, maybe the cold has an effect on them when powered.
Old Feb 2, 2006 | 03:19 PM
djbonsu's Avatar
yea....that does suck....i was gonna get some too....but it looks like im not....good luck man....
question: have you checked your grounds??....make sure they are independent grounds....its worth a try if you already havent...
Old Feb 2, 2006 | 03:22 PM
GBAUER's Avatar
possibly low voltage? Just a guess.
Old Feb 2, 2006 | 03:25 PM
Italiano's Avatar
SWIFT_Navigator
yea i just ordered a new ring and ballast for the right side. my rings never stay attached to the headlights so they break. hopefully the glue i ordered from unitzma works this time. 2nd replacement ring in the past 4 months.
Old Feb 2, 2006 | 03:30 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
send an email to unimitza and complain about it... maybe they will cut you a break on the replacement
Old Feb 2, 2006 | 03:43 PM
Y2k2maxse's Avatar
I had my DDEs since october...saaame problem. i called them and they are sending me another ring for just $10 shipping. they covered the ring. but sometimes cold weather will make one of the bigger rings not light up, needs quite some time to come on. put ur highbeams on and let it sit for up to a half hour DRIVING or running and if it still doesnt come on than uy need a new ring. this is overall a great product though.
Old Feb 2, 2006 | 03:48 PM
Greeneyes's Avatar
Gah!!! Yeah I did leave my car on for like an hour with the high beams on to warm up the headlight still no go..... This is going to be the 4th time opening up that headlight!! I thought the cold start issues were solved according to Umnitza!? I still love the look of these on my car so yeah i want to fix them but I dunno how much more my headlights are going to last with all the times Ive been baking them. Yes this happened to me before and had to do the same change the ring...... Im just kinda mad I have to do it again.......
Old Feb 2, 2006 | 04:03 PM
housecor's Avatar
Email Matt at Umnitza - He's a stand up guy and I'm sure he'll work with you to get this resolved. I've been running mine with no issues for a year or so now. Couldn't be happier. So don't worry, there are plenty of happy customers out there.
Old Feb 2, 2006 | 05:16 PM
crispykid717's Avatar
Bigger than Jesus
Got tired of mine not working properly, which is why I got rid of them.
Old Feb 2, 2006 | 08:15 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Sorry to see man. I have been seeing more and more issues with them. Kinda weird becuase for the longest time I didn't hear anything bad about them.
Old Feb 2, 2006 | 09:04 PM
00MaxSE's Avatar
Pointy Elbows
pink eye! Yes, that happened to be before. The cold weather was the culprit.
Old Feb 2, 2006 | 10:12 PM
rkyat's Avatar
Ditto.
Dont mind the crappy camera quality, waiting for spring to reopen these headlights back up.
Old Feb 3, 2006 | 06:08 AM
jeepik's Avatar
its not the ring
its the ballast
Old Feb 3, 2006 | 06:11 AM
Mizike's Avatar
Same thing happened to me, but I know what happened to mine. I was wrapping the wires coming out of the headlight with electrical tape. Apparently, I tugged too hard on one and it completely came out of the ring. Since one wire is still attached, I have a half lit ring, same pink/purpleish color from the half lit side. Anyhow, I had covered my headlights with Lamin-X film before they started giving me problems, so now Im not sure how to open the headlight housing up without ruining the film. And to make matters worse, the inside ring on the other side will not work either, I believe its a bad ballast. Needless to say, I have left it alone for a while. I hate to not fix it considering the money and time Ive already spend on the setup, I just hate that they require so much maintenance. Quick question....have you been applying any additional "adhesive" to the headlight housing to make sure it seats properly since youve opened them up 3 times already? Good luck on your problem.
BobTX10
Oct 7, 2015 08:43 AM
The Wizard
24
Oct 1, 2015 08:47 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
carid
Sep 17, 2015 05:00 AM
coasterswim
Sep 2, 2015 07:43 AM
