Spark Plug color... running lean?
Old Feb 13, 2006 | 04:24 PM
carsarecool's Avatar
I posted a few weeks ago about my MAF maybe being bad again since i'm getting a stutter at cruising speeds- pulled the spark plugs last night and the electrode (not the tip, the groove for NGK plugs) is a whitish color, i know this means im running lean im just not sure why. If it has something to do with the MAF which was replaced 5 months ago, i also am pretty sure the coils have already been done as they have no dot and look fairly new. Plugs dont look too bad, electrode tip is regular gray color. Wondering if i should get new plugs but i dont want them to be fouled up too, if there is a problem. Anybody had the same thing happen?
Old Feb 13, 2006 | 04:28 PM
Ammi's Avatar
350 Detroit Muscle
A clean, white tip is often caused by over advanced ignition, timing, poor engine cooling system efficiency (scale, stoppages, low level), a very lean air/fuel mixture, or a leaking intake manifold.
Old Feb 13, 2006 | 05:04 PM
Hoooper
dont get new plugs, fix the problem.
Old Feb 13, 2006 | 05:13 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if possible, post up a pic. a grey/light tan color indicates normal use. typically when the maf goes array then the ecu will tend to run richer as a safety precaution. if you want to know if you are running lean then replace the plugs with some cheap ngk coppers and head to a dyno for a few pulls with a/f.
Old Feb 15, 2006 | 07:44 AM
How do i post pics?
Old Feb 15, 2006 | 08:20 AM
icewake's Avatar
host them on cardomain or something. then right click on the pic and go to properties and there should be a website there. then click on insert image in the text bog and insert that webpage
Old Feb 16, 2006 | 08:47 AM
Ammi's Avatar
350 Detroit Muscle
Originally Posted by carsarecool
How do i post pics?
host it on cardomain and then type
[img]your link goes here[/img]
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
sdotcarter
Sep 2, 2015 09:53 PM
