What other suspension parts are needed?
Old Feb 14, 2006 | 08:10 PM
Jokey6577's Avatar
My maxima now has over 150000 miles on it and I am begining to compile parts to change out the suspension. I currently have new Maxspeed springs and my illumina shocks are on order. I will also be changing out my front wheel bearings, strut mounts and also the front half shalfs because the CV joints are shot. I figured I would also look at the tie rod ends while I am there but I am not sure if there is anything else I should be looking at while I am doing the work.
Thanks in advance for the help
Old Feb 14, 2006 | 08:22 PM
NmexMAX's Avatar
dot dot dot ...
Why the bearings?
Are you LCA bushings doing ok?
Old Feb 14, 2006 | 08:26 PM
Deckdout2's Avatar
Play with my balls
Sounds like alot of work, but it's and interesting job. I got alot out of learning about my car, when I did my CV Joint. Did you hit something and damage most of these parts? I don't think I would change out bearings, tie rods, and control arm components if there wasn't an issue with them. Shouldn't they hold up pretty well?
edit: With Nmex's statement, you should do your bushings and mounts as well. That would be a good mod seeing with your suspension setup, you are working on the handling aspects.
Old Feb 14, 2006 | 09:00 PM
Jokey6577's Avatar
Unfortunately both CV joint boots have been torn for awhile and now have begun to make noise. When I took a look at them I noticed a lot of debris there soI figured it would be better to replace the CV joint instead of replacing the boot only and then find out I should have done the whole thing. The only reason I am replacing the wheel bearings is because I have a set of hubs with new bearing in them and I will have everything apart when I do the half shafts. How hard is it to change the lower control are bushing? Do I order them from Dave B or Energy Suspension ?
Old Feb 15, 2006 | 07:34 AM
djfrestyl's Avatar
Suspension Yoda
I suggest getting the poly bushings from ES. Cattman has them.
Old Feb 15, 2006 | 09:36 AM
Deckdout2's Avatar
Play with my balls
I ordered my complete set of bushings and mounts from Matt Blemhco. There's a gd going on still I believe.
I haven't tackled the control arm bushings yet, but all that probably needs to be removed.
Old Feb 15, 2006 | 09:48 AM
Puppetmaster's Avatar
I got my ES bushings from Steve G at www.sportcompactonly.com. There's an .Org discount if you give him your .Org name.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
laparka66
Aug 6, 2015 09:36 AM
