stillen rsb question
Old Jun 9, 2001 | 10:23 PM
serin's Avatar
i've got the rsb/fstb setup now. pretty cool. not as night and day as i would have expected, but there's certainly less body roll.
i had the stillen guys install it for me at maxima day just so i could drive it home. is the rsb in the stiffest position when it's mounted on the holes furthest from the ends??? i don't know if that's just a 'normal/moderate' setting they used.
if i could go stiffer, i'd like to try it out.
thanks guys... and gals
Old Jun 9, 2001 | 10:28 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
When I did it, the instructions said to use the 3rd and 5th holes (at the end). Did Stillen use the 4th and 5th holes for you?
Old Jun 9, 2001 | 10:32 PM
serin's Avatar
naw. the guy installed as per the instructions on the 3rd and 5th holes. textbook install.
Old Jun 9, 2001 | 10:39 PM
Y2KevSE's Avatar
That should work for you. I've always wondered why we had to use holes 3 and 5. Must be some logical reason behind that.
Old Jun 9, 2001 | 10:42 PM
serin's Avatar
oops. sorry. do you mean AT the end? or FROM the end?
i attached a REALLY ghetto drawing to illustrate where it is now.
Old Jun 9, 2001 | 11:02 PM
Y2KevSE's Avatar
Hehehe Long day... The picture you drew is correct. Check here to verify http://www.paulwendy.com/maxima/rsb.htm
Old Jun 9, 2001 | 11:11 PM
serin's Avatar
thanks kev.
i guess the only answer is to drive harder.
Old Jun 10, 2001 | 06:38 AM
UMD_MaxSE's Avatar
Got Bent?
I have messed around with the RSB settings and have found that the RSB works pretty well for me when it is right under the rear axle.
maxima-junky
Nov 10, 2015 09:12 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Stagnet04
Sep 14, 2015 11:28 PM
