HotShot Headers
Old Feb 16, 2006 | 06:20 PM
  #41
03maxima1's Avatar
Originally Posted by upstatemax
car is prob running rich because of the headers, hence the decrease in mpg...
There is one solid peice of evidence you need to get the car on a dyno and tune it.
True.........
Old Feb 16, 2006 | 09:23 PM
  #42
Puppetmaster's Avatar
Originally Posted by 03maxima1
Does anyone know how Does anyone know how to figure out if the MAF is bad.
By searching....
http://forums.maxima.org/showthread....21#post1173121
http://forums.maxima.org/showthread.php?t=447467
Btw, I've been getting 16-19 mpg since the header install, even when driving "conservatively".
Old Feb 16, 2006 | 09:51 PM
  #43
Mass_Media's Avatar
Mass_Media™
Originally Posted by Puppetmaster
By searching....
Have you dynoed/tuned your car yet?
Old Feb 16, 2006 | 09:53 PM
  #44
No, haven't had time to install my AFC yet... once that's done, a dyno will be close behind...
Old Feb 16, 2006 | 09:57 PM
  #45
Hoooper
Originally Posted by Hoooper
how much of that cost is a new trans? i think my trans is going bad and if i get a new one i wont have to pay for the trans and the work for replacing, just maybe a little extra over the normal price to have it done. how much not including the trans and work?
straight pipe does make a little difference, it did for me at least. i notice that i get no traction at all in first gear if im trying to race, before it was no problem except just a little bit. its not the most obvious difference, but when paying attention i can tell. going to the track monday, can report the difference.
BUMP for an answer
Old Feb 16, 2006 | 09:58 PM
  #46
BUMP for an answer
Isn't this thread about headers and not trannies?
Old Feb 17, 2006 | 02:02 PM
  #47
03maxima1's Avatar
Thank You for the links.
Mine just dropped to 18.1 and it used to be 20.1. Wow yours went to 16? That sucks. I have to do something.
Old Feb 17, 2006 | 02:06 PM
  #48
03maxima1's Avatar
Don't you dyno and tune it the same time you install the AFC?
Old Feb 17, 2006 | 02:16 PM
  #49
steven88's Avatar
Need A Light?
i think puppetmaster wants to save his money...and install it himself...then take it to the shop for tuning....
i bet the shop would charge him alot just to install the afc
Old Feb 17, 2006 | 06:52 PM
  #50
Hoooper
seems to be about both
Old Feb 17, 2006 | 08:06 PM
  #51
03maxima1's Avatar
No. It is about headers.
Old Feb 17, 2006 | 08:19 PM
  #52
n3985's Avatar
大陆弟弟
Originally Posted by boondoxmax
As I said before. Its just my opinion. And even 550 is to much. Just my .02. I am not flaming or shooting down anyone who has headers or wants headers. I am just stating my opinion not a fact.......
www.ssautochrome.com has headers for $299
Old Feb 17, 2006 | 08:40 PM
  #53
rbrown81's Avatar
But why is teh Rum gone?
Get rid of that dammned injen. Crappiest mod I ever bought for my car. Berk intake FTW bishes!
Old Feb 17, 2006 | 09:13 PM
  #54
upstatemax's Avatar
Please dont bring that crappy stuff into this....
Old Feb 17, 2006 | 09:15 PM
  #55
n3985's Avatar
大陆弟弟
He wanted a cheaper alternative....
Old Feb 17, 2006 | 09:20 PM
  #56
Derrick2k2SE's Avatar
You can install it any time. It doesn't do anything till it's set up during the dyno tune.
I installed mine but the dyno shop offered to install it for $75.00. The install is pretty easy if you're comfortable with electrical soldering.
It sounds like you are running rich with those milege numbers. I'm running Hotshot headers, PR CAI and a B-pipe. I'm getting in the mid 20s for milege. I haven't been driving too conservatively since I put them in either.
Old Feb 18, 2006 | 07:00 AM
  #57
upstatemax's Avatar
That should not even be considered an alternative...
Who was it that put them on and quickly switched them out after the dyno?
Old Feb 18, 2006 | 07:08 AM
  #58
03maxima1's Avatar
Right, but don't you have the AFC installed and working? Does it even things out in terms of leaness and richness when you install the AFC?
Old Feb 18, 2006 | 09:26 AM
  #59
Yes, I have one in and working. Just installing it does nothing. It has to be set up manualy with the help of a dyno and AFR meter.
What it does is let you manualy adjust the fuel mix up or down at different RPMs by a percent. If you're rich between 4000 and 5400 RPM the tuner will lean it out by a few percent. Same if you're lean.
It comes set up at 0 percent so it can be installed safely.
Old Feb 18, 2006 | 09:45 AM
  #60
Gapp's Avatar
Does anyone know if you have to pull the motor to get to the back exhaust manifold?
Old Feb 18, 2006 | 09:55 AM
  #61
upstatemax's Avatar
No, if you remove the engine brace and front and rear mounts you can tilt the motor for more room. Or even pull the intake manifold, but you dont have to pull the motor.
Old Feb 18, 2006 | 12:19 PM
  #62
03maxima1's Avatar
Which one did you get?
Old Feb 18, 2006 | 02:46 PM
  #63
I have the Apexi S-AFC2. You can buy them new on eBay pretty reasonably. Just make sure you get a new one.
I had good gaines from dyno tuning with just intake and Y-pipe. Even tuned for that setup I was still rich with the headers. I think you will be pleased once you get the fuel mix straight.
Old Feb 18, 2006 | 03:04 PM
  #64
03maxima1's Avatar
Hopefully. I just don't know which one to get: Apexi V-afc or S-afc.
Old Feb 18, 2006 | 07:13 PM
  #65
Gapp's Avatar
This wouldn't tweak any lines in tilting the motor would it?
Old Feb 18, 2006 | 07:33 PM
  #66
abradic's Avatar
I might do it in the future. I just got a new engine so why not if the money is there.
With the cost of making the conversion to manual, wouldn't you be better off selling the auto and buying a manual?
Also, I am surprised to see that headers can take away from low end torque. I had an injen intake on my 99 Max and didn't really feel a loss of low end toruqe, so it probably is not too significant there, and I imagine the same for a 3.5. Anyhow, although there are some power gains with the intake, headers, and catback, you probably won't feel it. You'll probably just get a sweeter sounding car more than anything.
Old Feb 18, 2006 | 07:39 PM
  #67
upstatemax's Avatar
Did not on mine...
Old Feb 18, 2006 | 09:05 PM
  #68
spdfreak's Avatar
Would a VB upgrade help this out?
Dont think so... Thats more for faster shifting while racing. I really dont see it helping in an off the line situation
If I recall correctly, Level 10 VB's claim a .4 second off the 1/4 mile!
I think it would harden your shifts, and make it feel like a manual.
Old Feb 19, 2006 | 07:06 AM
  #69
Gapp's Avatar
Did not on mine...
Thanks for the low down!
Old Feb 19, 2006 | 11:55 AM
  #70
Hoooper
the 1/4 is not off the line, its after 1/4 of a mile. he means from the line...like OFF THE LINE. such as a faster launch and before shifting, in which case a VB mod wont come into play because its only for shifting.
Old Feb 19, 2006 | 12:50 PM
  #71
03maxima1's Avatar
Which unit is better the Apexi S-AFC II or V-AFC II?
Old Feb 19, 2006 | 02:08 PM
  #72
AJA_MAX's Avatar
vafc i believe but why are u jacking this thread lol
Old Feb 19, 2006 | 08:28 PM
  #73
That's pretty good. He's jacking his own thread?
Old Feb 19, 2006 | 08:32 PM
  #74
NmexMAX's Avatar
dot dot dot ...
Jacking oneself thread FTW
Old Feb 19, 2006 | 08:37 PM
  #75
BlackBIRDVQ's Avatar
drag racing is for wussies
V-AFC2 is better.
NmexMax I got a video to host and I am having some problems with it, its a 3GPP2 file- that I took with my phone. Quality is alright, it shows the sound of the HS headers in the car durring a WOT 0-80 run... know how to convert it or wanna host it ? I PMed Puppetmaster but I don't think he was online since yesterday as I have yet to get any response.
Old Feb 20, 2006 | 02:25 PM
  #76
03maxima1's Avatar
Originally Posted by BlackBIRDVQ
V-AFC2 is better.
Thanks Mike. I'm still waiting for the SIM to come in the mail.
Old Feb 20, 2006 | 05:41 PM
  #77
Jasonb1982's Avatar
With my auto after H/S Headers and Stage 2 VB I get 24.5 mpg on the highway; I used to get 27.
Old Feb 20, 2006 | 05:58 PM
  #78
NJ Devils Fan's Avatar
27 with an auto? Thats nuts, I'm like getting 18.6 which blows. I've always gotten bad gas milage since I bought the car. Oh well.
Old Feb 20, 2006 | 10:25 PM
  #79
NisMo-Max's Avatar
i get about 16.5 Mpg.....
Old Feb 20, 2006 | 10:28 PM
  #80
steven88's Avatar
Need A Light?
27 with an auto sounds fishy....
the 2k2-2k3 auto is rated at 20/26 city/highway respectively.....how are you getting higher than EPA ratings? you do know that EPA runs their tests in a labratory on a dyno...set at probably 55mph with no aerodynamics right?
