Weird voltage problem, meter says at idle I'm at 15volts
Old Feb 23, 2006 | 07:27 PM
bigfatty's Avatar
Booyah grandma.... BOOYAH
My lights were doing some slight flickering so I hooked the meter up and at idle I am at a little over 15volts, 15.05 to be exact. Engine off, just the battery is reading at 12.05, and the battery is only 2 months old so thats not the problem. Any ideas, alternator, alternator belt, bad grounds? Any help or expirence would be appreciated. Thanks guys.
Fat
Old Feb 23, 2006 | 07:51 PM
WasatchY2KMax's Avatar
Doesn't really sound like a problem... A charging system always runs higher than 12vdc. However, I will say that 15vdc sounds a wee bit high but that may just be your meter being slightly inaccurate... It's normal to see voltage at the battery terminals with KOER at 14.5+vdc/.; What kind of meter do you have...? Digital obviously... But 'el cheapo or fairly nice? I prefer Fluke or BK Precision meters but I am an electronics tech so I am kind of picky and those are NOT the cheapest ones you can buy (also not the most expensive.. (just good middle ground choices)
Old Feb 23, 2006 | 07:59 PM
Just out of curiosity I just went out and measured mine and with engine running at slightly fast (cold engine) idle I read 15.16 vdc. That was with my BK Precision meter.
Old Feb 23, 2006 | 08:30 PM
5thgenmaxima's Avatar
alldata will set the light if over 15.5 or no voltage is produced, but it also shows regulated output voltage @ 14.1-14.7V..A little high, but you should be ok in this aspect...
I may be wrong here, it's been a long time since I had to check for bad diodes,(which can cause flickering of the lights and power surges to your electrical components which can become very costly very quick), but IIRC you should have no more than 500MV (1/2 of a volt) of AC Voltage at the battery. If it is higher than this than your diodes are bad.(IIRC)
Old Feb 24, 2006 | 05:28 AM
bigfatty's Avatar
Ok so if my voltage is within normal, any ideas why my lights are flickering?
Old Feb 24, 2006 | 08:08 AM
ryanjimz's Avatar
This probably isnt it but i noticed that you have a system..was it running at the time you noticed flickering, and do you have a capacitor?
Old Feb 24, 2006 | 01:06 PM
bigfatty's Avatar
Yeah I have a system, but a 1 farad cap is in line and this is a new problem, the system has been there 2 years now without any trouble. The lights will flicker if the system is booming or off, They dont dim at all when the subs hits, its just a steady flicker. Thanks for the help Ryan, any other ideas?
Old Feb 24, 2006 | 02:05 PM
alpinestars™'s Avatar
THIS IS...
hmm, maybe the capacitor is loosing its effectiveness...
Old Feb 24, 2006 | 03:34 PM
check AC voltage at the battery while the car is running and @ 2500 RPM
Is it ONLY the headlights or all the lights?
(I'll check mine to compare if you want)
Old Feb 25, 2006 | 03:07 PM
Just checked mine for chits and giggles to see what normal AC was at battery.
.0023 volts. So my diodes are doing a good job of converting AC Voltage to DC Voltage. That's with a Fluke 88 so I know it's right.
Also check your VD for alt ground to battery ground..
Mine was .120 V..IIRC anything under .5V is ok
AaronL
Nov 15, 2020 11:52 AM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
