Info on European Maxima...
Old Feb 28, 2006 | 09:38 AM
dansmax2003's Avatar
Does anyone know what are the differences between the 2000-2001 Euro Maxima and the US Maxima, other than the exterior/interior look. (it looks like I30)
I am really interested in the differences under the hood. Why is the Euro Maxima rated at 200hp, when the US spec one is rated at 222hp? Same engine....different numbers. What could be the difference?
Any other major differences under the hood?
Thank you!
Old Feb 28, 2006 | 11:22 AM
jdmaxima89's Avatar
On the pedobear bandwagon
Someone said before that they are just detuned a bit for less hp. I could be wrong.
Old Feb 28, 2006 | 01:40 PM
P. Samson's Avatar
The Euro spec. cars have been sold for years with the DIN HP (German/Euro spec.) rating, which is equivalent to the new (2004) SAE HP specification used on the 2006 cars sold in North America. This has forced the manufacturers (especially the Japanese) to revise their HP figures, and in the case of the Japanese....downward. So the 222 HP VQ30, if it was rated under the new spec. would be more like 200 HP.
Old Feb 28, 2006 | 01:42 PM
SoonerFan's Avatar
Cletus
the diffirence is...its not a Maxima. its an I30, plain and simple
Old Feb 28, 2006 | 02:00 PM
P. Samson's Avatar
soonerfan.....The Maxis and I30s and I35s of the same year sold in NA have the same engines and the same HP ratings.
Old Nov 17, 2006 | 01:39 PM
brio_max's Avatar
Learning English...
Thank you!
The Euro Maxima A33 VQ30DE doesn't have the NVTCS - variable valve timing, so probably this is the reason...
Everything else under the hood seems to be same except the dual tip muffler - Euro model has just a single tip...
Old Nov 17, 2006 | 01:43 PM
irish44j's Avatar
retired moderator
he knows.....
NmexMAX's Avatar
dot dot dot ...
2000-2001 US Maximas don't have variable valve timing either.
Old Nov 17, 2006 | 01:53 PM
brio_max's Avatar
Learning English...
I thougth it has... after reading this info about Inifniti I30 00-01'
"Valvetrain DOHC, 4-valves-per-cylinder, NVTCS variable valve timing, mechanical lifters"
http://www.infinitinews.com/site_lib...30/specs.shtml
Old Nov 17, 2006 | 02:05 PM
NmexMAX's Avatar
dot dot dot ...
Even Nissan screws up. Here's the specsheet for the Maxima, which shares the same engine, identical, minus the engine cover.
http://www.nissannews.com/site_libra...ma/specs.shtml
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
