Rim question....
Old Jun 13, 2001 | 12:17 PM
SFMax20SE's Avatar
Will 5 x 114 offset 18" x 8" rim fit on the Max?
A friend of mine has a set of Racing Hart Type C he wants to get rid of, but it was for a RWD. Thanks all!!!
Old Jun 13, 2001 | 12:19 PM
DenMax's Avatar
Not sure
Let me know if you sell your AE's rims.
Old Jun 13, 2001 | 12:29 PM
Jeff92se's Avatar
I'm needing a caw
Bolt pattern = 5 x 114 okay
18" x 8" = maximas can support this size. okay
offset = not mentioned. Should be in the 35-38mm range. Maybe you can fit less then 35mm but I'm not sure.
Center bore = not mentioned. If his center bore is too small(smaller then 66.1 mm) the wheels will not fit onto your hubs. You might be able to get different hubcentric rings though.
RWD / FWD. Doesn't really matter as long as all 4 wheels are the same size and the above specs are okay.
Old Jun 13, 2001 | 12:33 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Definitely FAQ'able stuff. Thanks for the info, Jeff.
Want to blurb out more FAQ'able info?
Old Jun 13, 2001 | 12:34 PM
Jeff92se's Avatar
I'm needing a caw
Ah okay.
1) My cat's breath smells like cat food
2) Kev eats bunny beans!
how's that?
Old Jun 13, 2001 | 12:53 PM
SFMax20SE's Avatar
Thanks for straigthening me out, Jeff92se!
He does not have the other info
But he did say the rims use to be on a Lexus SC400. Thanks guys!!!
Old Jun 13, 2001 | 12:54 PM
Y2KevSE's Avatar
Ah okay.
how's that?
I'll remember to credit you on those.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
