Maxspeed vs. H&R -- Part 2... with review inside.
Old Mar 28, 2006 | 04:14 AM
NYPD-Arnold's Avatar
Z
UPDATED:
H&R Review...stance: 26 1/4''
Ride Comfort: 9/10 -- This is about as close to stock as you'll get when you have OEM Tokicos up front paired with H&Rs, it just feels like a dream. The car glides over everything now. It's everybit as smooth the FX35, and smoother than my uncle's G35x. The spring itself is a stiffer spring, and it's obvious. It required more pressure to be compressed, where as the Maxspeed required quite a bit less pressure. This contributes significantly to the ride as it lets the struts do their proper job.
Twisty Roads: 8.5 -- I said before there was a lack of precision with the Maxspeeds, like this somewhat weird feeling that my front end will just lose it and whack itself into a wall. But the H&Rs get rid of most of that. The car feels so damn precise and controlled. It's almost like a knife cutting through butter. The steering response is astounding and the flex is quite minimal -- more so than the Maxspeeds. The only room left for improvement would be tie bars and an RSB. Otherwise, this is terrific.
Sharp/Looping exit in NYC: 8.5 -- At 30MPH the car used to lean over quite a bit with the Maxspeeds. But the H&Rs simmer all of that down and make it far less noticeable, and far more comfortable. The car is poised at all times and likely with just an RSB and FSTB (or perhaps just a stage 1 LTB), we've got ourselves a car that's got outstanding handling. At this point, with my setup I've got a great handling car and I intend to get it to that "outstanding" point.
Sudden Lane Changes: 8.5 -- This. Is. It. This is where the magic happened. This was the test that really sparked me and blew a fuse in my brain. I really didn't like the float when I would change lanes in the Maxspeeds, but now 3/4 of that is gone. Absolutely gone. You've got this ever tiny bit of lift if you whip the wheel hard enough, but it's nothing like what it felt with the Maxspeeds.
S-Turn: 9/10 -- Because the H&Rs prevent so much lift over the Maxspeeds, doing quick S-turns becomes far more effortless and a lot less scary. The car just slices right into them -- in and then out. There's just so much more composure and the car is so much more fun to drive. Basically, everything about this suspension is just "tight" and with a few more minor additions here and there, I think that it'll give most cars a run for their money.
Overall: 43.5/50
Clearly this setup with my H&Rs is far more dominant than having Maxspeeds all around.
At 2:30 my H&Rs will be installed up front and my Maxspeeds will be removed out of the front. I just measured my stance and my car sits from (ground to fender) 26 1/4'' with the Maxspeeds in the front.
I said I'd do some tests before I removed the Maxspeeds and here is what I came up with (all tests will be re-done for H&R at the same speed):
Sharp/looping exit in NYC: 7/10 -- decent amount of resistance from the chassis. And sharp rebound with no swaying side-to-side.
Ride comfort: 8/10 -- with the OEM struts sitting up front, the spring rate of the Maxspeeds seems to work a lot better that way, allowing the strut to do a fair amount of work. Certain bumps may be a bit harsh, but if I were to be honest, the car now is every bit as smooth as the FX35. I look forward to a progressive spring evening some more of that turbulance out, though.
Twisty roads: 7/10 -- it's not bad, but there's a certain lack of precision. The chassis is holding up, but the steering response seems to be putting a damper on things. But it's still not bad and can get quite enjoyable.
Sudden lane changes: 6.5/10 -- Meh. A bit too much lift, and I was keeping the changes mild too. Hopefully the H&Rs correct this -- this is probably my biggest peeve with the Maxspeeds.
Sharp S-turn 8/10: I have a very quick and tight S-turn here in my area. It's basically a 90-degree left with a 65-degree right. The suspension performs quite well on this quirky little turn (I'll take pics of it when I do it again with the H&Rs). At about 20MPH a quick throw to the left and then to the right feels absolutely solid.
Maxspeed Score: 36.5/50
Old Mar 28, 2006 | 04:16 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Tire pressure
Old Mar 28, 2006 | 05:38 AM
Z
Even all around. I doubt anything will change over the next few hours.
Old Mar 28, 2006 | 08:12 AM
shurik's Avatar
Oooooo... let's see if H&Rs will beat that score!!!
So your Maxspeeds are sitting at 26 1/4" in the front? I think H&Rs will be a bit higher than that though, mine were 26 1/2" in the front but who knows yours could be different.
Ohhh yeah bro don't forget to make some pics as well.
Old Mar 28, 2006 | 09:48 AM
Z
It will fluctuate between 26 1/4 and 26 1/2 all depending on if gas tank is full or empty. To be perfectly precise, with my gas tank at 1/4 I measured the drop today at 26 4/10. So it'll fluctuate between 26 1/4 and 1/2. I will definitely take pics of the differences -- but I'd think you need one very sharp eye to notice a difference. Thankfully these springs have been broken in a teeny bit, so settling shouldn't be an issue -- but we'll see.
Old Mar 28, 2006 | 09:52 AM
Z
Lane change score updated. Final score for Maxspeeds is: 36.5/50.0
Old Mar 28, 2006 | 05:21 PM
Z
Fellas...I'm back. And I'm astounded. Absolutely, positively, downright floored. The setup feels incredible, thus far. The entire car ride home I was squealing like a little ***** because I was so excited. A full review will come around shortly. Stay posted for a follow up reply on my ride stance -- to the naked eye the wheel gap looks pretty much identical -- but we'll see.
Dr Klop: By rebound I mean how fast the car evens itself out after it flexes left or right. And OEM only up front.
Old Mar 28, 2006 | 05:55 PM
RA030726's Avatar
I'm nutty for Nissans
youre suprised that the H&Rs are better than the Maxspeeds?
Old Mar 28, 2006 | 06:01 PM
Z
Not surprised....just excited that the differences are that vast.
Old Mar 29, 2006 | 06:42 AM
Z
Overall: 43.5/50
Old Mar 29, 2006 | 11:00 AM
Z
Bump. 10 chars.
Old Mar 29, 2006 | 01:32 PM
shurik's Avatar
Hahaha I knew Maxspeeds wouldn't stand a chance. People say they're so alike that it doen't worth buying H&Rs for like $100 more. Yeah right!!! The proverb "you get what you pay for" is realy a true thing in most of the cases huh. You just need to test it more deeply!!!
Well great job Arnold, great test and the whole write up is awsome. Not a bunch of ppl do that here.
Old Mar 29, 2006 | 01:34 PM
Ephraim's Avatar
nothing like a quality thread. i recently got maxspeed springs and i am going to be putting them up front only, so i will be looking at this again and comparing, probably not compare-posting, unless you think it would be helpful
Old Mar 29, 2006 | 02:04 PM
Z
Yup. Thanks, bro. Good lookin' out on the springs. I'm definitely happy with the selection and the setup. It's nice to also have a setup that no one else has, but also a setup that works this well.
Ephraim: Thanks for the words.
Old Mar 29, 2006 | 02:25 PM
shurik's Avatar
No problem bratok!!!! I agree you're the only person with this set up so far, don't know anyone else who runs it.
So you're running H&Rs in the front and Maxspeed in the rear? Tokiko blues all around right?
BTW do you have pics of this set up anywhere at this point?
Old Mar 29, 2006 | 02:32 PM
irish44j's Avatar
retired moderator
Don't you think some of these changes could also be attributed to putting new struts up front with the H&R's, as opposed to the old (original?) OEM struts with the Maxspeeds?
unless you did the H&R's with the old OEM struts
or
the Maxspeeds with the Tok Blues
then
invalid test found!
Not saying that H&Rs aren't superior to maxspeeds...they likely are, but still, a comparison test isn't really accurate if the struts are different in addition to the springs, IMO.
Old Mar 29, 2006 | 02:38 PM
MetaOrbit's Avatar
Got Projectors?
If I remember correctly, he ran the OEM struts with the Maxspeeds (up front) for a little while before switching the front springs with the H&Rs.
Old Mar 29, 2006 | 03:03 PM
Z
You remember correctly. Like I've said a million times, the only thing I changed this time around was the front springs. I've been running OEM struts UP FRONT for the past 2 months with Blues still in the rear. And now I have H&Rs up front. So this test is completely valid in every way imagineable.
Old Mar 29, 2006 | 03:35 PM
Z
Shurik...if I posted pics, you wouldn't be able to tell a difference. Trust me.
But I might make a run to a large parking lot and take some shots just for the hell of it.
Old Mar 29, 2006 | 04:29 PM
irish44j's Avatar
retired moderator
dude whatever, that 1/4" is a HUGE difference
Old Mar 29, 2006 | 08:00 PM
Z
I know you were being sarcastic...but both springs measured out to an identical drop, already. Both 26 1/4.
Old Mar 30, 2006 | 03:37 PM
Z
Bump.
(10 burgers)
Old Mar 30, 2006 | 03:51 PM
DrKlop's Avatar
Driving is the next best thing
Bump.
(10 burgers)
Arnold, you want to write a review in my thread and post a link to this thread from there?
Old Mar 30, 2006 | 04:25 PM
Z
Yeah, Rome. I'll do that.
Old Mar 30, 2006 | 04:42 PM
DrKlop's Avatar
cool, thanks! Here's the link: http://forums.maxima.org/showthread.php?t=459517
Old Mar 30, 2006 | 05:15 PM
Z
Done.
(10 Maximas)
Old Mar 30, 2006 | 05:23 PM
DrKlop's Avatar
Done.
(10 Maximas)
Thank you!
derekinthez
Nov 13, 2022 04:00 PM
MR2 T'd
Jul 9, 2021 05:06 AM
videomano
Sep 8, 2015 03:28 PM
Maxboy23
Sep 4, 2015 06:04 PM
Hailstatejig
Sep 2, 2015 06:52 AM
