Question about automatic transmission fluid level.
Old Apr 11, 2006 | 11:19 AM
Whtmax'01's Avatar
Last year i had constant slipping problems with the transmission. Often, when I would stop at a red light and then accelerate when it would turn green, the car would not shift at all for a few seconds and just act as if it was in neutral. After a few seconds it would jerk into gear really harshly. It would do this about few times a month.
I would check the A/T fluid level and it would always be within range. However, I would always check when the car was cold. So few months ago i started checking the level when the car was warm, and noticed the fluid level was slightly low. After adding the fluid, I dont have the slipping problem anymore.
Is it normal for a transmission to slip with a slightly lower fluid level? Also, did the harsh shifting cause much harm to the transmission? I think it jerked into gear maybe about 10 times at most. Other than that I never peel out or abuse the tansmission.
Old Jan 22, 2009 | 07:15 PM
mannetti21's Avatar
This is old, but I'm bumping it because I am currently experiencing the same exact issue....wondering if low fluid level would cause this problem
Old Jan 22, 2009 | 07:47 PM
fishforlife2007's Avatar
you hit the nail on the head my friend.......
there are some other possibilities of course. one thing about tranny fluid is that it not only lubricates but helps perform the hydraulic action needed to "go" if you will.....
Old Jan 22, 2009 | 08:39 PM
pmohr's Avatar
No more Maximas...
Yes, given that the trans completely relies on the ATF in order to function.
Old Jan 22, 2009 | 09:41 PM
Scottwax's Avatar
That's Mr. Detail to you
...and they get really weird when the fluid gets low.
Old Jan 22, 2009 | 10:29 PM
808MAX-SPEC's Avatar
From my experience trans fluid temperature is an issue. If the fluid gets too hot, the level goes down and my trans slips. After installing my B&M trans cooler, slipping has decreased. I also had to avoid bumper to bumper traffic and hard driving during the day. Nights are not a problem. Don't know anyone who has the same issue as me.
Old Jan 23, 2009 | 06:52 AM
Scottwax's Avatar
You might have an issue with blockage in the cooler lines or maybe your radiator isn't cooling adequately. The temperature gauges in our cars (and pretty much all modern cars) are dampened so they don't show temperature swings provided the engine isn't running excessively hot or cold. If the needle flucuated with every 5-10 degree temperature swing, people would panic and be running to the dealers constantly. It is possible your car is running at the high end of the acceptable range and that is enough to cause the tranmission fluid to get hot.
Regardless of the cause, what you are experiencing is NOT normal. Bumper to bumper traffic should not cause ATF to overheat if the cooling systems are working properly.
Old Jan 23, 2009 | 07:20 AM
njmaxseltd's Avatar
You got that backwards, as the tranny temp fluid goes up, the level goes up as well. That's why the cold mark on the dip stick is lower then the hot mark.
You should always set the tranny fluid level hot, the cold mark is for referance only.
Old Jan 23, 2009 | 10:33 AM
Based on what I've experience, I suspected something was up with my radiator. So late last year purchased the Koyo from the GD and I plan to change it soon.
You're right I do have it backwards. My bad.
Cotozic
Jun 28, 2017 08:01 PM
maxinout93
Oct 27, 2015 01:29 PM
cmpowell86
Aug 10, 2015 12:35 AM
